2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning N20 with Full Bolt ons...and Meth??
      05-10-2016, 10:21 PM   #23
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Becareful heard horror stories with M1, use boost juice instead
Csmoove195 would be great to have you join us at the drag-strip and our spirited cruise against some of my friends M235 Luminous M2TROLL bryan_f22 to compare
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      05-11-2016, 12:53 PM   #24
Csmoove195
Csmoove195's Avatar
Drives: 2013 335is AW/CR 6 Speed
@ROBNYC I haven't seen or heard of any drawbacks on M1, I just wouldn't run 100% methanol at any given time for sure. Wouldn't 50% Meth and 50% distilled water act as the same as boost juice without the red dye added? That's what I plan to start with as a baseline.
      05-14-2016, 05:49 PM   #25
Csmoove195
Csmoove195's Avatar
Now that all the parts are on,of course there's a problem with the wiring. There's 2 wires that need to go into pins 3 and 14, and there's already a wire going into the #14 pin hole. Anyone have any ideas? I know for a fact I have a ewg board.
Update:I emailed Terry and you're able to splice the purple wire(#14) in with the wire which I'm assuming is the power for the pump.
      05-15-2016, 09:17 AM   #26
Csmoove195
Csmoove195's Avatar
Update: So the kit comes with a 1 gallon tank and a separate threaded brass connection, and you have to drill and tap into the tank to make the connection. The 2.3g tank option has a built in connection to hook right up to. I was talking to Terry back and forth and I'll be returning the 1 gal in exchange for the 2.3. My performance guy and I both agreed that it was too sketchy and seemed unreliable to just tap into a plastic bottle when we're dealing with flammable liquid in the trunk. Not to mention on the 2.3g there is a spot to hook the pump onto instead of finding a place and making a bracket to screw somewhere in the trunk.
      06-14-2016, 01:16 PM   #27
Csmoove195
Csmoove195's Avatar
The wait is finally over, I got it installed over the weekend and all i can say is wow. I don't really know how else to explain the feeling but its like having another turbo kick in after the first one lol
I do not regret returning the 1 gallon in exchange for the 2.3 gallon just because it's of a much higher quality(sadly it's a little bit of $$$) a simple and safer attatchment for the vinyl tubing hookup, and no brackets for the pump which is now conveniently tucked away under the backside of the tank for stealth. There's backfires, more gurgles, viscous downshifts, and a hell of a pull when you get past 3k rpm. As for how long it takes before I run out of my first tank, I'll figure that out when it happens. I'm currently running 50/50 mix and no problems after driving for a few hours last night.
      06-14-2016, 01:19 PM   #28
Csmoove195
Csmoove195's Avatar
As it sits in the bay
      06-14-2016, 01:22 PM   #29
Csmoove195
Csmoove195's Avatar
Sorta dirty charge pipe
      06-14-2016, 04:26 PM   #30
e46m3lol
e46m3lol's Avatar
Drives: F30 FBO, E70 X5D, W204 C63 FBO
Be careful with the mixture otherwise you will be kissing your motor goodbye like I did with mine
      06-14-2016, 07:35 PM   #31
Csmoove195
Csmoove195's Avatar
Is there any mixture you know of that I should stay away from?
      06-18-2016, 10:07 PM   #32
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Thanks for the update.
78' Honda CB400A project
      06-18-2016, 10:32 PM   #33
Csmoove195
Csmoove195's Avatar
So I just ran out of meth today, there's definitely a noticeable power difference between map 2 and 3, and I thought map 2 was quick for what it was beforehand lol. I definitely like the fail safe that switches maps for you when you're empty.
      06-21-2019, 06:55 PM   #34
bimmer_6uy
follow my instagram @bimmer_6uy
bimmer_6uy's Avatar
Drives: BMW 328i F30 Full bolt on
Reviving this post. I'm running a 328i with full bolt on. I plan to run meth kit for my car as well.
BMS stealth kit 3 gal tank with the CM7 nozzle.
I've been on the edge on this option after reading from the forums. Im curious if you can run a e30 mix along with meth?
If so, who would provide the safest tune for this kind of set up? I just bought a flex fuel it upgraded pump for my car. Haven't installed it yet. Having troubles finding a tuner.
Could use your guys opinions on this!
      06-28-2019, 07:31 PM   #35
NolanB
Drives: 2015 BMW 228i
Parts
I'm new to the BMW scene, i have a 228i also and i wondering where do you get your parts from, because for some reason I can't seem to find them anywhere.
