2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics ConnectedDrive : New Software update available 10/2015
      10-11-2015, 02:47 PM   #1
H_BMW
France
Drives: F30 LCI
Arrow ConnectedDrive : New Software update available 10/2015
Check the bmw website with your VIN, there is new software update :
http://www.bmw.com/com/en/owners/con...re_update.html
Version for Next system : UPD05073
One of the following versions will be installed depending on which vehicle you have:
MN-002.055.071, TN-002.055.070
MN-002.039.071, TN-002.039.070
MN-002.034.070, TN-002.034.070
MN-002.027.070, TN-002.027.070
MN-002.018.070, TN-002.018.070
MN-001.037.070, TN-001.037.070
MN-001.023.070, TN-001.023.070
MN-001.021.070, TN-001.021.070
Very long change Log !
http://www.bmw.com/_common/shared/ow...D05073-ENG.pdf
      10-11-2015, 03:04 PM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
nice
      10-11-2015, 09:29 PM   #3
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
Looks like mine is up to date, strange...
      10-12-2015, 01:01 AM   #4
H_BMW
France
Drives: F30 LCI
Probably over the air update. (If you have connected drive)
Or simply that BMW has distributed the update on the new 2015 vehicle first.
      10-12-2015, 07:42 AM   #5
jrstech
jrstech's Avatar
78
Drives: '21 M550
Tried to update but get "Update on USB device not suitable for this vehicle..." Car was recently worked on at DLR, was told software was updated so I not sure this message is related to that.
'17 F80 (RET)
'14 F22 M235i (RET)
'11 E90 335i (RET)
'07 E92 335i (RET)
'89 E30 M3 (RET)
      10-12-2015, 10:15 AM   #6
BoomWasabi
Drives: M4
Interesting, when I've tried this site before it never recognized my car (VIN is incorrect). Now it says that my software is up to date. I guess that's an improvement. ;-)
      10-12-2015, 01:33 PM   #7
juniortabak
juniortabak's Avatar
47
Drives: M135i
same thing:
The Vehicle Identification Number you entered is not correct. Please check your entry.
      10-12-2015, 04:01 PM   #8
CONTROL ONE
CONTROL ONE's Avatar
70
Drives: 2014 BMW M235i
Thanks. Update worked perfectly for me. Whole process took about 8 minutes.
      10-12-2015, 04:35 PM   #9
MrBimmerM235i
What's new?
      10-12-2015, 05:02 PM   #10
H_BMW
France
Drives: F30 LCI
Originally Posted by MrBimmerM235i View Post
What's new?
First Post :
      10-13-2015, 11:53 AM   #11
azw131
Drives: 2011 335i Xdrive M Sport Coupe
Will updating software wipe out any FDL Coding changes?
Current Vehicles: 2007 911 Turbo 6MT, 2011 335i Xdrive M Sport Coupe
Past Vehicles: 2014 Porsche Boxster S,1983 Porsche 911 "RSR", 2013 Audi S4, 2011 335i Xdrive M Sport Coupe, 2015 M235i, 2011 335i Xdrive Coupe, 2006 330i, 2012 WRX, 2011 Camaro V6, 2004 325Xi
      10-13-2015, 11:54 AM   #12
FIRST1
Drives: '15 M235i Melbourne Red
Model Year 2015 car here and I don't have an update available to me either. I have ConnectedDrive but I had Office (Enhanced Bluetooth) added via coding, might that have anything to do with it?
      10-13-2015, 12:02 PM   #13
isthar
Drives: M235i xDrive
Looks good... but as I think I posted elsewhere my car recently came back from dealer for an idrive replacement and I recall its software starts with 003. putting it newer than any of these... oh well I'll try anyways. "fixed podcast" and "better audio quality" for iphones is what has me wanting this.
edit: indeed, my car reads 003.001.002.011.007 for bluetooth as an example...
Can anybody "lend me" the last 7 digits of their car, say an m235 car that got produced after June 2015? I'm starting to suspect I need to start entering info such that it presents me sw updates for idrives newer than that date. One that has the upgraded audio.
//M235ix Alpine White
      10-14-2015, 06:00 PM   #14
ggabriele3
Drives: 2015 228i Msport
I wonder if Apple CarPlay will ever be an option here. Distributed via software update based on customer choice.
      10-14-2015, 06:18 PM   #15
wjjkoevoets
Bright Sky
wjjkoevoets's Avatar
Netherlands
1164
Drives: BMW M235i (8AT)
2014 BMW M235i  [0.00]
For those of you wondering why your iDrive firmware is newer than the one BMW publicly offers, I'm guessing it has to do with the integration level of your car.
I recently asked my dealer to perform an integration level update and as a result went from NBT_B to NBT_K. This process also updated my iDrive firmware from MN-002.033.002 / TN-002.034.001 to MN-003.001.002 / TN-003.001.002.
Folks that are at NBT_G or below (or something like that) can probably upgrade to these latest MN/TN-002 versions, while NBT_K folks should probably stick to MN/TN-003 as it appears to be newer.
Before integration level update:
After integration level update:
Note how the NBT_K has the "Opt" options button to the right whereas older versions don't have this.
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive.
      10-15-2015, 05:25 AM   #16
Nahlem
Nahlem's Avatar
Sweden
1144
Drives: None atm
2022 BMW i4 m50  [10.00]
Mine says its updated. Had it at the dealer yesterday but for the replacement lamps, Don't know if they also did an software update ...
      10-17-2015, 05:33 PM   #17
Oyinko
Got my car worked at the dealership 3 weeks ago and asked a firmware update to fix some ongoing BT issues.
As a result went from NBT_B to NBT_K. This process also updated my iDrive firmware from MN-002.033.002 / TN-002.034.001 to MN-003.001.002 / TN-003.001.002.
The last update is therefore not compatible.
      11-03-2015, 10:56 AM   #18
mvallido
mvallido's Avatar
Philippines
70
Drives: M235i Estoril Blue
Successfully updated mine, Thanks.
2014 M235i {Dinan P1 Power Package}
2015 F30 320i
2006 E90
2004 C240
97 E39 VF5 Supercharged
      11-23-2015, 04:02 PM   #19
moltenfire
moltenfire's Avatar
Drives: 2015 M235i EBII Coral Red
2015 M235i  [0.00]
Came back from the dealer last week and got software updated to NBT_L. Also at version 003.003.001 now.
      12-11-2015, 01:21 PM   #20
isthar
Someone with a 2016 MY car care to share their last-7 vin? (pm it if you worry)... i want to know if their site would offer a newer version then...
      01-26-2016, 03:41 PM   #21
cbbplanet
Drives: space shuttle
just wondering, for all those that upgraded, does your spotify (or any other bmw connected app) track/cover art updates when played over bluetooth?
      01-26-2016, 06:33 PM   #22
BMWZ4
BMWZ4's Avatar
1910
I don't get jacket images when I play via Bluetooth
