2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Bumper guard removal
      04-18-2019, 09:06 AM   #1
trangatrang
Drives: 2016 BMW M235i xDrive
Hi all, I recently purchased a 2016 M235i. The car originated from the NYC area and the previous owner had what appear to be OEM bumper guards installed. While I can appreciate the utility they probably had for the original owner, I'm not in a situation where they will benefit me. I'm curious if anyone has any experience removing these.
      04-18-2019, 09:31 AM   #2
aldenaldenalden
Drives: '19 M2C
If it's installed using 3M tape, which my guess is that it is, then running some fishing line underneath it should do the trick.
Once the strip is removed, try to rub off as much of the remaining adhesive residue on your bumper as you can using your fingers or an adhesive eraser wheel. Anything left should come right off using 3M general adhesive remover spray, or something similar.
      04-18-2019, 10:26 AM   #3
hwntime
hwntime's Avatar
270
Drives: F22 Raptor
As mentioned, run fishing line to remove. The adhesive should be sprayed with Goo Gone and left for an hour or so to make removal way easier. If you don't let it soak, it'll be a b*tch to get the adhesive off and you'll wear down your fingers in the process.
BTW that is one ugly bumper guard! Get it off ASAP!! LOL
      04-18-2019, 11:24 AM   #4
BEM-S4
BEM-S4's Avatar
3M makes a wheel that mounts in your drill - think power eraser to get gunk off.
      04-18-2019, 04:00 PM   #5
Marmugmotleocay
Marmugmotleocay's Avatar
Drives: 2021 BMW X3M Competition
I have used the 3m eraser wheel and it works well and is definitley a time saver.
