2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes 2018 m240i Dinan Lowering Spring Bolt/Nut Part List with Tq Figures
      02-05-2019, 09:52 PM   #1
helloelectro
Drives: 2018 BMW m240i
Hey All:
So in researching the Dinan lowering spring install process, I was acquainted with Torque To Yield bolts, what they are and why they need to be replaced. With that, I began looking around for a comprehensive list and though I found bits and pieces here and there, and some with similar models, I decided to try and catalogue everything for my car while I was putting together my part list I need to order.
I know there is some debate on if you need to replace these. I am choosing to because I drive aggressively, and enjoy the comfort of driving on 4 wheels.
It would be great if these numbers could be checked by others who may have an OCD itch and free time. I'll update as required. I probably could use some help with naming the connection points more properly, etc as well. Hopefully this helps others and saves them some time.
Google Doc List With Clickable Links
FRONT SPRINGS
10x Strut Bearing Screws (3 per side)
- Part Number: 31306869931
- BMW Part Name: Hex bolt with washer
- Length: m8x30 10.9
- Where to Order: https://www.bavauto.com/bmw-mini-bolt-31306869931
- TIS Reference: 31*31*1AZ
- Renew: YES
- Torque:
- 8mm (30Nm +90)
-10mm (56Nm +90)
2x Front Strut Lower Pinch Bolt (1 per side)
- Part Number: 31 30 6 798 530
- BMW Part Name: Hexagon screw with flange
- Size: m10 x 85mm
- Where to Order: https://www.bavauto.com/bmw-mini-31306798530
- TIS Reference: 31*31*3AZ
- Renew: YES
- Torque: 44Nm +90
2x Front Strut Lower Pinch Bolt Nut (1 per side)
- Part Number: 07119905032
- BMW Part Name: Hex Nut
- Size: M10-10-ZNS3
- Where to Order:
- Renew: YES
- Torque: 44Nm +90
2x Shock Absorber Top Nut (1 per side)
- Part Number: 33326760668
- BMW Part name: Self-locking collar nut
- Size: M12X1,5-10 ZNS3
- Where to Order:
- TIS Reference: 31*31*2AZ
- Renew: YES
- Torque: 64Nm
2x Front Strut brace mount torx bolt (1 per side)
- Part Number: 07147270121
- BMW Part Name: Torx screw with collar
- Size: ASA M10X20
- Where to Order:
- TIS Reference: 51*61*1AZ.
- Renew: YES
- Torque: 56nM +90
2x Lower Control Arm Bolts (1 per side)
If removing one end of LCA
- Part Number: 07119906489
- Size: M12X1,5X67-10.9
- Where to Order:
- TIS Reference: 31*12*3AZ.
- Renew: YES
- Torque: 100Nm +90
2x Lower Control Arm Nuts (1 per side)
- BMW Part Name: Self-locking collar nut
- Where to Order:
- Renew: YES
- Torque: 100Nm +90
REAR SPRINGS:
2x Anti Roll/Sway Bar End Link Top Nut (1 per side)
- Part Number: 33 32 6 768 884
- BMW Part Name: Hexagon nut with collar
- Size: M10
- Where to Order: https://www.bavauto.com/bmw-mini-nut-33326768884
- TIS Reference: 33*55*2AZ
- Renew: YES
- Torque: 56Nm
2x Roll over Strut Bolt (front, first position)
- Part Number: 07119908024
- BMW Part Name: Torx-bolt with washer
- Size: M14X1,5X85
- Where to Order:
- TIS Reference: 33*32*10AZ.
- Renew: NO
- Torque: 165 Nm
2x Roll over Strut Bolt Nut (front, first position)
- Part Number: 33306760349
- BMW Part Name: self-locking collar nut
- Size: M14X1,5-10 ZNS3
- Where to Order:
- Renew: YES
- Torque
2x Roll over Strut Bolt (front, second position)
- Part Number: 07119907372
- Size: M12X1,5X90-10.9
- Where to Order:
- TIS Reference: 33*52*3AZ.
- Renew: YES
- Torque: 100Nm +90
2x Roll over Strut Bolt Nut (front, second position)
- Where to Order:
- Renew: YES
Shout to this guy for this awesome write up. Was a HUGE help in getting ready to do this upgrade:
https://www.2addicts.com/forums/show....php?t=1412603
Maynard3848.00
stvward133.00
      02-08-2019, 12:51 PM   #2
helloelectro
To add to this: I got a great deal on the parts by contacting Brian Keller at Sun Motor Cars BMW. He was recommended on a few bmw forums. They are up in PA but he will ship to you. He was able to beat any internet price I found.
Maynard3848.00
