2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Oil pan gasket "seeping" oil
      10-10-2018, 10:42 AM   #1
Bimmer Pleaser
Bimmer Pleaser's Avatar
205
Drives: nothing
I had my 228i for an inspection at the dealer because factory warranty is about to run out. They said oil pan gasket is seeping oil but it is not bad enough to require replacement. Once seeping becomes leaking they have to fix it. I don't really care TBH because it is CPO and I'll definitely get rid of this thing before CPO runs out. But I'm still wondering if anyone has had the same experience? Dealer saying repair is not needed because it's is seeping not leaking? And also, what is really the difference?
      10-10-2018, 12:07 PM   #2
hwntime
hwntime's Avatar
270
Drives: F22 Raptor
A seep is a very small amount of oil that is probably lingering around a seal or gasket. It will "seep" very small trace amounts over the span of months and maybe even years and isn't a cause for issue. It's bound to happen to every car over time because metals expand and shrink with heat and cool downs over and over again. Your car will be ok and there's no need to worry since it's documented and you have CPO.
      10-10-2018, 12:24 PM   #3
overcoil
Drives: M235i 6spd
Just curious, are there any suspension pieces or structures that the prevent the oil pan from being simple unscrewed and dropped ?
      10-10-2018, 01:21 PM   #4
Bimmer Pleaser
205
Drives: nothing
I am not familiar with 2 series but I know dropping the oil pan is a huge pain in ass on e90. 2 series is probably similar.
I am kind of surprised though, in my experience VCG and OFHG are more susceptible to failure than OPG.
      10-11-2018, 11:01 PM   #5
oregondonor
Drives: 2016 435i
Very common issue on the E9X.
2016 435i MSport ZHP #85
      10-12-2018, 07:25 AM   #6
celsdogg
E4 Mafia
323
Drives: E30, E36/5, E46, F22, F30
1990 BMW 325i  [0.00]
1998 BMW 318ti  [0.00]
2003 BMW 325i  [0.00]
2015 BMW 335i  [0.00]
2015 BMW M235i  [0.00]
seeping probably means the gasket is wet. it'll probably just make a mess after a long time.
the overall basic design of bmw's has been the same forever. to pull the pan and change the gasket you'd have to support the motor top side, then remove the subframe which has at a minimum the steering rack and control arms attached. not to mention the motor mount on it. they probably can't justify the work for the amount of seep.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k)
Bring back the purple M stripe
      10-18-2018, 04:06 PM   #7
MarcoZandrini
Drives: 2018 M240i
OP, you've documented with the dealer that the oil pan weeps oil. I think that that means that BMW NA is on the hook to fix it when the seep increases to an unacceptable level.
