2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Driver side air vents blowing no air at all
      08-18-2022, 11:45 PM   #1
Hydro
Hydro's Avatar
27
Drives: F22 M240i 6MT
'17 M240i 43,XXX miles
Both driver side vents have stopped blowing completely. Passenger side still works perfectly. Without taking anything apart I can't see anything broken or closed inside of them.
I've tried:
Toggling AC
Toggling the Hot/Cold slider on the vents themselves
Toggling blowing modes through every combination
Closed passenger side and turned it all the way up (I can feel air moving in front of them but they definitely aren't blowing)
Any help would be appreciated!
F22 M240i 6MT
      08-19-2022, 08:24 AM   #2
MarcoZandrini
Drives: 2018 M240i
You're going to have to scan the automatic climate control module (IHKA in BMWspeak) for codes.
      08-19-2022, 08:29 AM   #3
overcoil
Drives: M235i 6spd
I have no idea.
What happens when you run the defroster ? are the driver side window aimed vents blowing ?
Same no driver action in AUTO and Manual mode ?
Maybe disconnect battery for a while.
or
Run the heat on hot maximum blower setting,
And chk the cabin filter it it's clogged maybe the system shuts down partially.
