2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB 230i Battery Replacement
      03-05-2022, 10:28 AM   #1
bensanford
Drives: Grey '18 230i & Grey '21 330ix
My '18 is about 4.5 years old. Battery seems fine, but I don't want to wait for it to fail before replacing it. How long do these typically last?
I see that Costco has an Interstate Battery for sale for $177.99. It is an AGM battery. Battery is car is marked S:61. Is this the same size as Group size H8, since apparently European sizes are marked differently? It seems to measure the same size as the OEM battery in the car.
I feel comfortable in doing the replacement and understand the need for battery registration - I could purchase the "registration service," or perhaps buy the diagnostic tool necessary to do it myself.
Does this Interstate battery seem good, and what about suggestions on the best way to do the registration?
Information from Costco/Interstate on their battery is as follows:
YOUR BATTERY INFORMATION
Item Number 1355853
Group Size H8 (49) AGM
CCA 900
CA 1000
Voltage 12
RC 160
Ah 95
Length 13 15/16
Width 6 15/16
Height 7 1/2
Weight 59
Termination Code POST TYPE
Wet/Dry D
Footnotes
Valve-regulated AGM battery.
Battery is vented outside of vehicle.
CCA is an EN (European Norm) rating.
Vehicle computer system must be reset. Contact your service specialist.
Various group size batteries used in production.
EXCLUSIVE FOR COSTCO
Group Size: H8 (49) AGM
$177.99*
*Refundable core charge of $15.00 not included
36 Month Limited Warranty Replacement
Please visit your local Costco Wholesale as availability may vary.
__________________________________________
'18 m230i, Mineral Grey, MT, M-sport, Track Handling, Premium, H-K audio, CarPlay, no Moonroof,
'21 m330ix, Mineral Gray, Navi, Driver Assist, Park Assist, 19' orbit grey wheels (wife's car)
      03-05-2022, 12:09 PM   #2
123Britt
Drives: 15 M235i AT
Registration & Coding
Yes - the New battery will need a registration process & if the 95ah is different that the original battery it will also need coding.
Well coding in that there is an amp hour range ( I don't remember the ranges but there is like 90-94 ah and then like 95 ah and above or something)
Many tools out there to accomplish in easy fashion. I use an Autel MX808 scan tool for this purpose. If the battery ah matches the new battery then no coding is required and only the registration.
When I was in the market for a battery, I found I was able to save like $40 by going aftermarket and decided to just stick with OEM.
