02-22-2015, 03:53 PM | #1 |
Rep 39
Sport + with 8 speed auto
Forgive me if this has been covered but I've searched the forum and my owner's manual for an answer with no luck. Does sport + automatically put you in manual mode? In sport I can stomp on it and the tranny will upshift automatically right at redline to the next gear. In sport + the tranny does NOT upshift unless I physically do it with the paddles or by moving over into manual mode with the console shifter and upshifting that way. Is this normal?
02-22-2015, 05:21 PM | #5 |
Rep 855
02-22-2015, 06:18 PM | #6 |
Rep 5,262
No.... in sport the full DSC is active... in sport+ DTC is on....
Sometimes people confuse what DTC on means... DTC is a less intrusive version of DSC Also above 31mph DTC gets deactivated automatically.... so basically in sport+ over 31mph all DSC functions are off (eDiff on) The other way to get DSC off is to hold 5 secs in which it goes into a mode on itself that's different from sport or sport+ that is: DSC fully off (eDiff on) with sport suspension, louder exhaust but comfort throttle response |
02-22-2015, 06:58 PM | #8 | |
Rep 5,262
also always remember that DTC gets deactivated above 31mph.... so in Sport+ over 31mph you are actually driving with DSC OFF |
02-22-2015, 07:50 PM | #9 |
Rep 855
02-22-2015, 08:56 PM | #10 |
Rep 535
Drives: BMW 228i Mineral White M-Sport
I'm pretty sure the question the OP is asking is more about the transmission than about DTC vs DSC...debating that topic is something we could get stuck on all day.
While in Sport+ mode, if the gear lever is to the left and you start manually shifting, be it with the paddle shifters or the gear lever, the car will not downshift for you if you push the gas pedal all the way down (and I mean all the way, pressing that button after full throttle). Inversely, the car will also not upshift for you at the redline. This is because manual shifting in Sport+ mode is really meant for being on the track when you want to be in full control of the transmission and not have it make the 'optimal shifts' for you. I find Sport mode to be the best choice on the city/highway when sometimes you want to make a quick change, you floor it and the car will automatically put in the optimal gear, and can shift through several gears at once, sometimes going from M8 to M5 or whatever. Is that the question you were having?
2015 F22 Mineral White Metallic M-Sport 228i 2007 E92 Sparkling Graphite Metallic 328i |
02-22-2015, 09:02 PM | #11 | |
Rep 5,262
02-22-2015, 09:05 PM | #12 |
Rep 862
Drives: '19 M2 '21 X5
Fun fact, activating cruise control knocks you out of sport+ down to sport as well.
I find that if you use sport/sport+ and keep the transmission in D the Rpms tend to linger real high when coming off throttle within 2000 rpm of redline. S mode fixes that mostly. Quite irritating. |
02-22-2015, 09:12 PM | #13 | |
Rep 5,262
if you are in sport (with drivetrain enabled) or sport+ the transmission is already in sport mode putting the lever to the left in sport (with drivetrain enabled) or sport+ does nothing but to momentarily downshift 1 gear.... a few moments later it will upshift again |
02-22-2015, 09:17 PM | #14 | |
Rep 535
I know you've coded your car to the max, maybe thats something that got modified. Or maybe the 228i transmission is different than the M235i?
02-22-2015, 09:22 PM | #15 |
Rep 5,262
Ok I'll double check.... usually I don't redline mine much and as far as I knew the only diff with sport+ was DTC... but if you say you have checked this, i believe you, then maybe only M in sport+ has the auto upshift disabled....
No I don't think this is something can be coded... also I think 228 and M235 share the same auto transmission oh well... time for a test drive......you learn something new everyday Last edited by pikcachu; 02-22-2015 at 09:30 PM.. |
02-22-2015, 09:30 PM | #16 | |
Rep 535
02-22-2015, 09:40 PM | #17 | |
Rep 765
In Manual mode (any setting), the 8AT will not shift up or down unless told. In Sport or Sport +, left in auto, the car will run to redline and shift aggressively. I would suggest a visit to a dealer?
02-22-2015, 09:47 PM | #18 | |
Rep 535
If I was on the track, then yes I would keep it use Sport+ exclusively because you want to keep it in certain gears and RPMs around the corners, but for street use the auto shifting (even while in manual mode) is an excellent feature, and distinguishes Sport from Sport+. If you're suggesting there is a bug in my brand new car's transmission software, then I'll keep it that way. Can we please get more people onboard to replicate this. I am truly curious now.
02-22-2015, 10:14 PM | #19 |
Rep 535
Afterall, this 'bug' was the ultimate reason I decided to go with the 8AT over the 6MT. I went for the 6MT on my E92 because the 0-60 times on that were better than the Auto SMG they had in 2007. Come 2015, BMW really stepped up their game on the F22's auto transmission and made the 0-60 times faster for the 8AT than 6MT. So I figured, if on his best launch BMW's best test pilot can't even beat the 8AT, on which the 0-60 time will essentially always be the same, I would never be able to beat it either. So when I test drove the F22 and got a feel for the nuances between 8AT's Eco Pro, Comfort, Sport, and Sport+ there was really no going back to the dinosaur which is 6MT. There is no comparison between the 8AT's abilities to automatically downshift through several gears, and upshift at the optimal RMP versus a 6MT where you first have to push the clutch in, enter your desired gear, and then smoothly pull the clutch out and engage that gear. I guess we have reached the age where computers are better than humans lol, and for that there is a point of no return.
This is just my indivdual opinion, and in no way am I bashing 6MT, I loved every second of it on my E92, but I was immediately won over by the F22's 8AT...bugs and all haha
02-22-2015, 11:50 PM | #20 |
Rep 349
In manual mode and sport mode, my car will shift up at redline (full throttle).
It will only downshift when I come to a stop and fail to downshift. Replicating the same situation above, but in sport+ mode, it will not shift up and the car will feel like it fell on its face. |
02-23-2015, 01:08 AM | #21 | |
Rep 535
But you say it will only downshift when you come to a stop...Now try this scenario, in manual mode while in Sport or Comfort mode with high gear at a low RPM and speed, lets say M6 or M7 at 55 mph, go past full throttle and hold it there and it should shift automatically shift into M3 so that you can get the maximum power. The key for this to work is to push the button beyond the end of the gas pedal. You know, the one that also activates launch control.
02-23-2015, 02:01 AM | #22 | |
Rep 1,091
As to another post about DTC switching off above certain speed: it doesn't mean it gets you into DSC off mode, but to the contrary: it turns all nannies back on (i.e. DSC ON, DTC OFF). This way you're protected above the certain speed threshold; remember that DTC on is mainly for allowing *some* wheel spin on loose surface for better acceleration/traction; when the car already have the momentum and you don't explicitly turn off the nannies by the long button press, you're reverted back to normal (i.e. protected) mode.
previous: 2003 E46 330i SMG
