12-30-2016, 03:37 PM | #23 | |
Rep 5,372
Sure, he can buy some bushings but it's not going to help those tires plant in those acceleration situations. He'll see. There's good reason why Vettes, Vipers, Camaros, and Stangs run really wide rear rubber. .....not just for cornering. |
jpnh1424.50 Mywifes3351631.00 |
12-30-2016, 10:55 PM | #24 | |
Rep 1,422
12-31-2016, 08:08 AM | #25 | |
Rep 957
Super sports are worse in cold but not that bad, I drove sport cup 2s on a c7 z06 from fl to ny in March, ended up 500 miles in sub freezing and snow. Yeah not optimum traction, but still did 85-90 most of the way, once you have heat in them your fine, provided road is clear of snow. If the wheel is spinning then traction control would engage and then It's time to look at tires. If not its suspension. The stock arms, bushings, springs and shocks are close to there limit with stock power. Add more and youll need upgrades to plant it. Bigger ties put more grip, which means more load and forces on the suspension. I would do the outer lca and any other bushings you see fit. If that does not solve I would do th subframe a diff bushings, mine as well throw the LSD in then as you have to drop rear subframe to do bushings. All of the bushings in these cars are soft, and very complaint, exact same as in a 3 series. They are not sport oriented. With 5 link rear you would have to disassemble to check bushings, you can't just grab a part and shake it, unless the bushings are falling out. The bushings I removed looked fine, once removed I could move them around with a bolt in the hole, new was not possible. I noticed mine on highway, felt loose under acceleration, sometimes like wobble, sometimes like car wanted to go left then right like no traction. The bushing when worn allows the tire to toe in and out quite a bit independently on each side making for odd handling traits. Honestly I would do the lca bushings on a stage one car. Last edited by Pparana; 12-31-2016 at 08:19 AM.. |
Mywifes3351631.00 |
12-31-2016, 08:26 AM | #26 |
Rep 957
I may still have them at shop, but they look fine visually however you can move them around a few mm with a bolt in the hole, a new one has no movement. You won't have any additional nvh with outer lca bushings. Really any suspension bushings until you do the subframe, as the subframe bushings are extremely soft and compliant, like jello cups from a nusing home.
12-31-2016, 05:51 PM | #27 |
Supreme Allied Commander
3847
Rep 54,378
Drives: F80 M3
Sounds like temperature related since you mentioned it's colder now. Most performance tires don't have much traction in low temps.
Even a stock car should be LSD equipped. Do you have one on the car? |
01-02-2017, 02:21 PM | #28 |
Rep 1,422
No LSD... on my "to do" list for 2017. $2,100 is the best price I found and the local shop wants $600 for the install. Cost more than my Pure stage 2, LOL.
01-12-2017, 10:55 AM | #29 | |
Rep 1,084
You've tried FCM, Superpro and now you're on Powerflex, right? Can you speak to your experiences with each?
01-15-2017, 08:40 PM | #32 | |
Rep 957
With upgraded power, the bearing wears out of spec quickly allowing a lot of movement, and undesirable handling traits like the op has. I tried the fcm because I could not find an aftermarket poly one. By going poly and eliminating the bearing, you have very little compression and almost no movement. The superpro parts are not listed for our cars, but the same oem part number is used in other makes so I searched for them using other makes. The Superpro are the diff and subframe, I did not use them in the lca. There is no noticeable difference in NVH, esp. if you have oem subframe mounts. You could change every bushing to poly if you have the oem subframe, it will not transmit much as they are very soft. I use this car mostly at track, but is by no means a race car. My rule for license plate cars is they have to pass the wife sleeping test. If she can't fall asleep while I am driving at speed, I am not smooth enough or the car is setup wrong. You do not have to give up comfort for feel, you just have to setup properly. |
Dylan861330.00 |
04-27-2017, 10:24 AM | #34 | |
Rep 1,541
04-27-2017, 05:08 PM | #35 | |
Rep 2,214
I have the M-Performance LSD already, but I can feel the slop in regards to rear end weight transfer especially down shifting on the off camber sweepers to and from work. I have a 4% downhill grade on my way to work and when going 4-3-2 downhill heavy on the brakes, is when I notice it the most. Would just like things to feel more crisp and less "sloppy" so to speak. It's really quite minor, but to me, noticeable enough to want to mitigate.. I was hoping the sway bar, diff bushings and rear sub-frame bushings would compliment my KW Clubsports and remedy some of that slop. I'm really only doing the rear sway bar because I'll be doing the diff/sub-f bushings, thought I'd take of everything while my rear end is down.. Should be tackling all of this mid May, provided work slows down and I get a weekend to myself D |
04-27-2017, 05:26 PM | #36 | |
Rep 1,541
I used to run a rear only bar set to siffest (whiteline bar), but that was in my Evo. Popular with AWD (like the Audi's you mentioned) and FWD cars (VW's you mentioned) because it helps the back end rotate (generally). Not usually suggested for RWD cars. Are you AWD? Still on a stagger wheel/tire setup? I run the KW Clubsport also and square 255s. With your DA coilovers adjusted correctly and LSD I find it hard to believe you're getting much "slop" in the rear. In my opinion the factory sways on this car are more than adequate when the rest of the car is properly setup. Unless you're trying to get that last few percent out of the car and ROI is a non-issue. Even then I'm not sure how doing a rear only bar would benefit the actual handling of the car. From your description it sounds like it could be how you're driving the car. No offense, just sounds like you might be unsettling the car by your driving technique.
Dylan861330.00 |
04-27-2017, 06:05 PM | #37 |
Rep 4,518
Powerflex now have assorted bush inserts to tighten up rear subframe and diff mountings for Bmw F2x anf F3x.....
https://www.powerflex.co.uk/road-ser...s+-3189/1.html |
04-27-2017, 06:14 PM | #38 | |
Rep 2,214
And it's more or less drive line weight transfer between shifts (as if I had worn diff or subrame bushings) that I'm talking about. It's not noticeable unless I'm really digging. And since I'm getting this feedback on my weekend mountain tours, I figured it would be amplified with R compound tires and the KW's on track. I'm currently on Dinan springs, and the car needs to be stiffer, hence the Clubsports. They are going in same time as sway bar, bushings and all that. I am still getting familiar with the car, but my shifting (heel/toe) is smooth as silk and have penciled that out as being my issue, lol.. |
04-28-2017, 06:27 AM | #39 | |
NewFinishColumbia/detailer
604
Rep 2,096
[QUOTE=Pparana;21037964]
04-28-2017, 09:43 AM | #40 | |
Rep 1,541
Dylan861330.00 |
04-28-2017, 10:37 AM | #41 | |
Rep 2,214
D |
04-28-2017, 10:39 AM | #42 | |
Rep 1,541
Dylan861330.00 |
05-02-2017, 03:54 PM | #43 | |
Rep 2,214
That said, am I safe to go ahead with Superpro F30 rear sub-frame bushings? SPF3946K Doesn't say anywhere that it fits F22, but from what I've learned it's all the same? Any help would be great, these are the last bits to the puzzle for me. D |
05-02-2017, 08:53 PM | #44 | |
Rep 957
