11-28-2019, 03:49 PM | #1 |
Rep 322
Springs from KW V3
Front progressive springs (2041) [1]. 60 mm at the coilover perch, 80-something (for the stock struts) at the top. KW doesn't specify the effective rates, but they're definitely firmer than stock (still quite ok on the street though), but lower than the 90 Nm that I replaced them with. Rear main linear spring. 110 Nm, 200 mm free length [2]. Some scoffs on the paint, if you care about those things. $100 + shipping. [1] https://www.kwsuspensions.net/produc...ories/60210271 [2] http://docs.kwsuspension.de/ga-KWGFw...-G_1223-15.pdf |
11-30-2019, 12:20 AM | #5 |
Rep 322
An M240i. KW uses these in many other V3s as well, depending on the weight of the front axle. The second link I posted has the details.
Unlikely. The OEM front springs are much shorter than these. The non-adjustable perch on the OEM struts sits quite a bit higher than the one on any coilover shock. Last edited by msendit; 11-30-2019 at 10:08 AM.. |
