2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Audiotec-Fischer MATCH 7UP BMW Amp
      04-25-2020, 11:05 AM   #1
MarcoZandrini
Drives: 2018 M240i
I took the final step and installed the HEC/MEC USB module in the Audiotec-Fischer MATCH 7UP BMW amp. The results are astounding! Here’s the link to my post at bimmerforums:
https://www.bimmerforums.com/forum/s...-MATCH-7UP-amp
      04-26-2020, 12:39 PM   #2
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
Don't get why you have to cut tabs in the OEM amp connector to plug the Match amp harness. The only 42-pin connector that requires to cut tabs to fit in the OEM amp connector is the ASD OEM connector.
      05-03-2020, 11:08 AM   #3
MarcoZandrini
Drives: 2018 M240i
Great question! All I know that there were 2 vertical "bars" in the AF connector. I contacted Doug Dobson and he said to cut them out. So I used a dremel to sharpen a narrow screwdriver blade and slowly removed them, like a wood smith would use a wood chisel.
      05-03-2020, 11:16 AM   #4
Encanto
Encanto's Avatar
Are you sure that you are plugging the UP 7BMW to the OEM amp harness, and not to the ASD harness?
Those tabs are cut only if the ASD harness connector is used.
      05-04-2020, 06:20 PM   #5
MarcoZandrini
Drives: 2018 M240i
No, the the MATCH's connector was/is plugged into the chassis harness. I didn't touch the ASD. It's coded out, btw. Doug is with MSC-America. That company is providing tech support for Audiotec-Fisher in the US.
