09-12-2021, 04:01 AM | #23 |
Rep 3,070
This was to prevent ignition going off.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
maxfrompine4.00 |
09-18-2021, 09:08 AM | #24 | |
Rep 21
Drives: BMW M2C
09-19-2021, 06:40 AM | #25 |
Rep 21
Drives: BMW M2C
FOR FUTURE REFERENCE, if anyone has the same problem and cannot clear the Restrain Error
I finally SOLVED my personal issue For some very weird reason, the ACSM when coded needs to have the factory VO setup. I previously coded out my adaptive suspension, and 2VF was removed from the VO. This triggered the “coding don’t match equipment” and the errors with the central sensor that couldn't be cleared with Tool32 Solution: - Added back 2VF in the VO - Factory coded ACSM - Coded FDL to remove the airbag ONLY, Sitzairbag_Thorax_Fahrer --> nicht_aktive (I'm keeping the seatbelt buckle connected to the car) - Cleared codes with Tool32 0 Error Found in ACSM and no code at all anywhere in the car
F87 ///M2 Competition '19 Alpine White
09-21-2021, 03:19 AM | #26 | |
Rep 210
You can use "CAFD Tool" to see what a VO code removes / adds, so you can remove the adaptive suspension without triggering the error again.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger | LithiumNext Battery
