01-26-2015, 01:19 PM | #67 | |
Rep 2,337
Upgrade = Harmon Kardon/Top HiFi Using treble to compensate may be enough to smooth out the tweeters on your new speakers. I still think that, knowing you want more bass out of the system, an amp may be in your future. A set of new subs will sound better than the stock subs, but the stock amp only gives you so much power. To increase volume you need power. You could look at a set of Earthquake 2ohm subs which are supposed to drop right into the stock sub locations and they even have a harness that fits the stock wiring. But I think the stock amp is 240w and it's likely that's a peak wattage rating and not the continuous power rating. That means you're giving little power to that sub - maybe 50w max, so 20w RMS? That's a tiny amount of power for a driver trying to produce sub level frequencies.
01-26-2015, 02:31 PM | #68 | |
Rep 30
The HiFi stereo is the base system. The upgraded system is the HK system ( OEM from Harmon Kardon). The best upgrade for the base system is to replace the amp, the speakers and add a DSP unit to tune the system to the car. The next best is to upgrade either the speakers or the amp (which has some DSP built in). My personal preference is to upgrade the speakers as the factory speakers are about as low performing a 4 inch that you will ever see. If you leave the speakers and upgrade the amp you will have to add a separate DSP unit. A decent amp and DSP will run you between $8oo and $1,500 depending on the level of performance you are seeking. All of this said you may get away with upgrading the door and back deck speakers for say $400 and use the base and treble control to minimise the differences in speaker efficiency between the remaining center channel/sub combo and the new speakers. I have done that and like the result. Knowing that I can replace the amp also is inviting as I have some extra amps kicking around that I can now use. |
01-26-2015, 02:45 PM | #69 | |
Rep 2,337
Someone on Bfest said they went this route with the stock speakers and says he likes it so far. We're still in contact though as he said there may be an issue with a turn-on pop that he's working out with Helix support. I'm waiting for that to get sorted out.
01-27-2015, 05:57 AM | #71 |
Rep 181
ok, posting this question again bc it got buried. Can anyone help. I'm basically looking for the best pair of speakers I can get for under $50. Also, should I be looking at speakers that have an attached tweeter for the rear. I have Focals with attached tweeters in the front. I do not plan to upgrade the amp.
What's up everybody. I'm just entering the world of stereo upgrades, pretty much learning by reading these forums. I picked up a pair of FOCAL Access 100AC that I am now thinking I will put in the doors. I am looking for a cheaper (under $50) set of speakers to put in the rear deck. Ive been looking around on EBAY and found these kickers and these Audiobahn and these Pioneers. I am assuming something with a built in tweeter is better since I dont plan on replacing the amp. Thanks in advance for your help. |
01-27-2015, 04:04 PM | #72 | |
Rep 2,337
Of those three speakers, I suppose I would probably go with the Kickers. No idea about Audiobahn and I absolutely hate those tweeter+micro tweeter 3way combos. So yeah, the Kickers... but only if you forced me by putting a gun to my dog's head. Otherwise I'd just leave the rears alone.
01-27-2015, 06:07 PM | #74 |
Rep 6,934
Drives: 2018 M2 AW DCT
01-27-2015, 07:21 PM | #75 |
Rep 56
UPDATE
I'm just back from my install (front/door speakers). The installers at Car Toys said that they could not fit the Focal ICS 100s without bowing out the door panel a bit. I went with the JL Audio C2-400Xs. I think I liked the Focal sound in the studio a bit better but not enough for a hassle. As for the post-install sound... I would say it's a 50% improvement over the base speakers. They did just one side first so I could hear the different and it was substantial. One side (OEM) sounded like it was covered by a bucket while the new side sounded fresh and bright. Definitely worth the upgrade (about $300 w/ labor). One side effect, I think the "active sound" got disconnected or is greatly diminished with the new speakers. I think I'm ok with that as I can now enjoy better sound and a quieter ride in "sport" mode. I'm surprised how loud the active sound really was. I'll try it for a few days before I decide if I want it turned back on. I might try to disconnect the center speaker in the dash just to see how that sounds. I've read it's easy to do and some think it's an improvement. |
01-27-2015, 11:23 PM | #76 | ||
Rep 765
Highly recommend disconnecting or pulling it out. Since the center channel is not a true separate channel from the HU, it combines left/right out to simulate a channel. It muddies sounds clarity. I miss the 5.1 sound in my Audi, but after removing the center, the directional accuracy (knowing which speaker is playing) is much improved.
01-28-2015, 12:31 AM | #77 | |
Rep 2,337
01-28-2015, 09:42 AM | #78 | |
Rep 809
I found the JL AUDIOŽ C2-400x (not Xs) is it the same? http://www.ebay.com/itm/NEW-JL-AUDIO...item2eda7b04c0 Thank you for your response. |
01-28-2015, 01:45 PM | #79 | |
Rep 272
The main issue for me was the midrange glare I heard due to low quality of the midrange and likely due to large portion of sound reflecting from windshield. I've gone back a forward connecting the center channel and I still much prefer without it. I also tweak balance control a little to right to get a more center image. This will reduce total SPL since the right side will clip or reach saturation point earlier. I wanted to experiment replacing center channel speaker but I'm unable to find one that fits there. |
01-28-2015, 05:47 PM | #80 | |
Rep 30
Does the 4 inch focal (IC100) fit in the center spot? Thanks |
01-28-2015, 05:50 PM | #81 | |
Rep 30
thanks |
01-28-2015, 06:17 PM | #82 |
Rep 181
Ok, I just finished installing the driver's side front speaker, Focal AC 100. When I put the volume up and switch the output between left and right (front speakers only), the stock speaker is louder but more muddled. The Focal is lower but def with a crisper sound. Have others found the stock speakers to be louder as well? I ask because this is my first audio upgrade and I now im worried I may have wired it incorrectly. Thanks. BTW, I'm going to post a DIY on removing the door panel. That screw behind the door latch threw me off.
01-28-2015, 06:41 PM | #83 | |
Rep 56
I found the Focals to be a more rounded sound in the studio whereas the JLs were more pronounced in the high and low ranges. That was in the studio though...once in the car, things generally change. I'm happy with them. Last edited by MrBallooKnot; 01-28-2015 at 06:44 PM.. Reason: Type |
01-28-2015, 07:24 PM | #84 | |
Rep 181
01-28-2015, 07:28 PM | #85 | |
Rep 2,337
You do want to make sure your speakers are properly wired for polarity. Again, I need to get in there with a multimeter and note the color so I know for sure which wire is positive and which is negative. I just relied on my ear to listen for any reduction in volume at lower frequencies. When you send a signal from two speakers which are wired up inversely (one has the + lead going to the + terminal and the other has the + lead going to the - terminal), their sound waves will start to cancel each other out a bit. I wish I would have had more time to document my door install. It would have saved you some heart ache.
01-28-2015, 07:35 PM | #86 | ||
Rep 181
01-28-2015, 08:55 PM | #87 | |
Rep 56
That said, I found the stock speaker "more offensive" in that is seemed so one-dimensional that maybe it could be seen as louder. The new speaker was "less offensive" in that the sound seemed distributed in a more pleasing way. Kind of like if someone was talking to you through a cardboard tube vs. open air. I couldn't tell you on a decibel level if they were different. Someone once told me, "Good speakers sound good at any volume". Shitty whiskey is "loud". Good whiskey is subtle but complex. Cheers! |
