2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB P0444 code
      04-12-2022, 02:31 PM   #1
2015F31
Drives: Black 2015 328i Sport Wagon
2015 BMW F31  [0.00]
P0444 code
2015 228i: P0444
Already replaced Vent Valve - BMW (13-90-7-636-145) and gas cap. What else could be throwing the code?
Thanks
      08-03-2022, 01:31 AM   #2
Knhattingh
Knhattingh's Avatar
Drives: BMW 230I
heyo! Had the same issue a little bit ago. I replaced the vent valve located on top of the engine…
What i've found from my research is that it could also be a vacuum leak in the fuel system. An indie shop should be able to help out by using smoke and pumping it into the system. They let it sit for a little (for the car to do another vacuum test once turned on) then look at all the areas for visible smoke… this shows them where there could be a hole in the system which causes a vacuum leak.
I am sure you did, but when you replaced the vent valve, did you reset the CEL?
