05-19-2021, 07:25 PM | #1 |
Rep 864
Thermostat Hose Flange to Block
I removed the (2) 10 mm flange bolts which provides access to the Oil Cooler / OFHG bolt without issue. The flange was black on the outside and the part was unbroken. The seal was intact. However, inside the line appeared to be light brown and speckled with minor surface cracks. This part is know to fail and I plan on replacing the flange with an aluminum Rein flange from FCP Euro.
Pictured is the part after I removed it from the hose per Rein instructions. I recommend replacing this part as preventative maintenance & during WP/Thermostat R&R. |
05-20-2021, 08:57 AM | #2 |
Rep 1,264
Yikes!!!!! How often do you change your coolant? Are you using BMW coolant and distilled water? I had the dealer change mine at 3 years. I provided the distilled water.
05-20-2021, 10:26 AM | #3 | |
Rep 3,947
05-22-2021, 09:45 AM | #5 |
Rep 864
HOSES / REIN & Coolant
Changed Original Coolant at year 3 and now again during this refresh.
Using ONLY BMW Coolant at 50/50 distilled. This Micky mouse flange and color distortion is normal and this part was all intact & only broken up on removal of the factory hose clamp. Look around -- this is a normal wear pattern on this part & the reason several offer an improved flange. . . ECS / FCP and others offer + many Youtube videos on this subject. . Ordered replacement WP / Thermostat hose -- was sent wrong hose from my favorite vendor : (their website is WRONG) The correct part # for the M235i is : 11 53 7 628 010 Coolant Hose |
05-26-2021, 08:50 AM | #7 |
Rep 1,264
05-26-2021, 01:24 PM | #8 |
Rep 864
Found Here:
06-02-2021, 11:30 PM | #9 |
Rep 7,432
Here's what I did preventatively on my m2 to prevent this from ever happening: https://f87.bimmerpost.com/forums/sh....php?t=1773412
123Britt289.00 |
06-03-2021, 09:35 AM | #10 | |
Rep 864
Great Job & Write UP
F87source7253.50 |
06-03-2021, 12:42 PM | #11 | |
Rep 7,432
07-18-2021, 05:24 PM | #12 | ||
E4 Mafia
325
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
