2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Prepping for first time on track?
      05-21-2016, 12:21 PM   #45
dphjr
Drives: Alpine White M235i
Originally Posted by Mywifes335 View Post
That's awesome. Next time you go out, def swap the fluid.
For my wife's X3, I just bought a pair of Porterfield R4S for better bite on the street and a liter on ATE 200. I got them for a decent (but not lowest) price from Zeckhausen Racing in Fairfield, NJ. I'm happy to pay a little more because Dr. Z at Zeckhausen is a great guy and will spend time to consult you and find the best brake combination for your intentions.
For my M235i, I'm probably going with the Ferodo DS2500. If I need something more aggressive, I'll get the Pagid RSL1 for the track.
Hope you find Dr. Z!
I might go with yellows, as I've seen a lot of people use them and it seems to be a good perf street/track pad
2015 ///M235i | Alpine White | 8AT | RW Carbon Front & Rear Lips | Autotecknic Paddles | MP Side Decals | AWE Axelback | Shifteck DP | MHD Stage 2+ | BMS Intake | FTP Charge Pipe | VRSF FMIC
      09-13-2016, 07:17 AM   #46
LDSM
LDSM's Avatar
Drives: ...
OP, inflate tire pressure to recommended psi (32F/38R) and adjust as you drive. Err on the side of lower since pressure will increase as you drive.
For any track event, you should've had your own mechanic do a tech inspection already. Then you must pass tech the morning of.
I can't stress enough...BRAKES, brake fluid, brakes!
Make sure you're running fresh, high boiling point brake fluid and track pads.
Street pads start melting after a few hard laps. And if they aren't, you're not braking hard enough.
i would run more like 38F 35R cold else you will destroy the PSS shoulders and even so you might still kill them with no extra camber
38F 35R cold, what would that be hot?
      09-13-2016, 12:43 PM   #47
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
I would start at 32f and they will climb to 40f.
www.nybmwcca.org
Current Cars:
      09-14-2016, 12:38 AM   #48
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
You will gain 5-6 psi depending on how you drive or even a few more...
The right way would be to use a pyrometer and see what the temperatures on different places on the tire are...
LDSM344.00
