03-03-2016, 08:12 PM | #1 |
Rep 85
Alcantara Interior Piece
After a year of M235i ownership it was time for an interior change. I had a look at the M Performance interior however was not a fan of the matte carbon fibre. So my search continued until I stumbled upon the M4 GTS with its luxury Alcantara pieces. From that point forward I set out to recreate this look on the long console piece that holds the iDrive.
Here is my finished result using genuine Alcantara (9002 - charcoal) and v92 bonded polyester thread. Hope you all like it: |
03-03-2016, 09:08 PM | #3 |
Rep 85
Thanks!
Just this bit for the moment, I do have plenty of Alcantara leftover as they only sell it by the yard (JPM Coachworks). I take a piecemeal approach to these sorts of things, I do what I definitely know I want, then I sit back and assess. So we will see... |
03-04-2016, 06:48 AM | #4 |
Rep 5,105
Man, that's well done. I wish I had the skill to do stuff like this.
03-04-2016, 07:34 AM | #5 |
Rep 101
Drives: 2016 m235 xdrive
That does look nice. Awesome job man. I really like the look and feel of the Alcantara material. Thinking about purchasing some and doing the visors. I already have the M Performance carbon fiber/alcantara trim.
03-05-2016, 12:09 AM | #7 | |
Rep 85
I measured it all up and drew where the stitch holes would be on the back of the fabric. Then it was simple to just follow the pattern I made. I also drew a pencil line on the original piece (brushed aluminium) that followed the line from the iDrive. When gluing, I used this line to slowly roll the fabric down so the line was in the middle of the stitches. |
03-07-2016, 07:53 PM | #9 |
Rep 386
FANTASTIC. I may have to copy you ... I have alcantara seats so i am thinking this interior upholstery you are doing will go perfectly with my seats. How many yards would you say I'd need?
03-07-2016, 08:56 PM | #10 |
Rep 85
Depends on what you want to cover. I ordered 1 yard and after doing those 2 pieces I still have plenty left.
03-08-2016, 12:54 AM | #11 | |
Rep 3,320
Op I may be copying you too! Looks amazing ,would you mind sharing where you picked up the genuine Alcantara from? Also what adhesive you went with?! Thanks I appreciate any info! |
03-08-2016, 03:24 AM | #12 | |
Rep 85
http://store.jpmcoachworks.com/ To cover the pieces I have you will be after Alcantara Pannel (no backing). I used Sika contact adhesive. Any contact adhesive should do, just be wary as some take 20 mins to dry before they grip and you want it to dry quicker than that (5 mins is good). And whatever you do DON'T use a spray contact adhesive. This work needs to be done in small sections at a time for the best result, so use a paintbrush to spread the glue accurately. Here is my inspiration, this guy is a master: https://www.youtube.com/watch?v=IaSm3zoWrAo |
03-09-2016, 04:50 PM | #13 | |
Rep 647
03-10-2016, 03:13 PM | #14 |
General
2042
Rep 25,989
Those little touches look really good! Plan on doing any other bits?
VMR|Wheels | 714.442.7916 |
03-10-2016, 04:50 PM | #15 | |
Rep 85
I was considering doing the door handles as well, but not sure how people's grubby hands (read: my grubby hands) would go on the fabric. I also quite like the contrast between the aluminium door handles and the Alcantara. Sometimes less is more... |
03-10-2016, 10:34 PM | #16 | |
General
2042
Rep 25,989
Maybe the e-brake handle?
03-16-2016, 01:31 AM | #20 | |
Rep 85
For the centre console, you can overlay the material directly on the trim already installed (brushed aluminium for me). There is enough room to fit the additional thickness of the Alcantara. For the two dashboard pieces, you will need to separate the piece of plastic with the existing trim glued to it from the rest of the pieces it is attached to. This means you will need to break the moulded plastic rivets holding it in place at the back (you can put a self-tapping screw in afterwards to hold it). Once you have the piece of plastic the trim is glued to separated from the rest, bake it in the oven at 125 degrees celsius for 20 mins. This will heat up the factory adhesive and you can separate the existing trim from the plastic piece so you can cover it with Alcantara. I originally tried covering the dashboard pieces without moving the existing trim but found the added width of the fabric didn't make it sit as nicely. Personal preference really. P.s. don't put muffins in the oven with the car parts unless you like the taste of adhesive |
03-16-2016, 03:25 AM | #22 | |
Rep 85
A regret of mine is not taking the Alcantara for the large dashboard piece to an embroider and having 'M Performance' sewed on. While I love how the completed project looks it is a bit neutral (I realise some people like that). I now understand why BMW included the embroidery on their OEM Alcantara piece, regardless of what it says the colour breaks everything up by just the right amount and it is perfectly positioned. Anyway thought I would include that as an idea for anyone thinking of doing the same. |
