02-26-2016, 06:20 AM | #1 |
Rep 42
Another Audio system source? -- Integral Audio
I have the Bimmertech amp and Bavsound woofers installed in my M235. While they sound better than the stock HK system I do not feel it was worth the expense. The sound is somewhat harsh and the woofers distort when certain songs are played and I usually am listening to it at 90% volume just to get some bass out of it. I previously own a Mini Cooper with the HK system (looks like the same speakers as in the M235). Not being satisfied with it I replaced it with the Integral Audio SoundStage. It sounded awesome. Everyone who rode in it commented on how good the stereo is, even my wife had positive comments on it and that is saying something. You can read about the system on the Mini Forum (www.northamericanmotoring.com)The system came with a subwoofer and enclosure, replacement door and tweeter speakers, crossovers and the wiring harness. It is plug and play.
I contacted Integral Audio about a system for the 2 series. They said they just completed the Soundstage system for the 3 series but have not thought about the 2 series but if enough people (15 – 20) would commit to it they would design a system for the 2 series. I am not an audio geek and therefore cannot speak to the specs of the system but if you would like more information please contact them or go to their website www.integralaudio.com. If interested in the system please contact: Kevin Bennett Integral Audio, LLC O: (646) 926-0011 F: (646) 585-1350 kevin.bennett@integralaudio.com www.integralaudio.com I am not affiliated with Integral Audio or any of its employees, I just want a well sounding system. Thanks, Gary |
02-26-2016, 07:34 AM | #2 | |
Rep 886
Past that, though, there's something funny going on if you're able to listen to it at 90% volume. My ears will start ringing if I get over 70% or so. At 90%, I think they'd be bleeding. What are you using for a source?
02-26-2016, 07:54 AM | #3 |
Rep 42
I usually listen to an Ipod, the SAT and HD FM have a little more volume but not much more. To get the best sound it needs to be around 90% for a lot of music (anything with a lot of bass) but others I don't need it at that volume. My issue is to get the bass to respond I need to turn it up then the tweeters are way to harsh. I have been wondering if it is possible to hook up the Match PP 8E-Q or PP 10E-D sub woofers to the match amp in the M235, not sure how it connects or if one would have to splice in the wires.
02-26-2016, 09:49 AM | #4 | |
Rep 2,942
Are the Bavsound woofers 4 ohm or 2 ohm? Something to also note: the OEM subs are 2 ohm, which means they need about 40 percent less power to generate the same SPL as a 4-ohm sub. BMW did this on purpose so they'd work reasonably well with the underpowered OEM amp (either HiFi or HK).
02-26-2016, 10:25 AM | #5 |
Rep 42
Interesting you should ask that. When installing the Ghost woofers I noticed it said 8 Ohm which I thought was odd as most car speakers I have seen have been 2 or 4 ohm. Don't quote me on that but I am pretty sure that is what they said.
02-26-2016, 11:10 AM | #6 |
Rep 1,753
Are you running the F22 tune that came out about a week ago?
02-26-2016, 11:16 AM | #7 | |
Rep 2,942
Sounds to me that both those subs operate off of a single channel at 4 ohms (The rule: if you run two speakers of an equal given ohmage in parallel from the same power source, they will operate together at half that ohmage. So: 8ohm--->8ohm = 4 ohm). Bavsound probably did this to eliminate issues with aftermarket amps, most of which cannot drive channels at different ohm ratings -- and the vast majority of aftermarket car audio speakers are 4ohm. Either way, yep: they're plainly underpowered compared to the rest of the system. That's your bass issue.
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 02-27-2016 at 04:21 PM.. |
02-26-2016, 12:46 PM | #8 |
Rep 42
Yes, I am running the F22 tune. It made a big difference over the tune that came with it but still not the quality of sound I expected for the cost. I am a little nervous about replacing the rest of the speakers as I will have a lot $ into it and am worried that I will not be satisfied with it.
02-26-2016, 02:55 PM | #10 |
Rep 42
Thanks for the reply. I was aware of that and was already thinking about switching back to the oem speakers to see if that is it. The system is still better than stock.
02-26-2016, 11:54 PM | #11 | ||
Rep 118
My logic would make me think that the HIfi setup is series and HK is parallel. Both situations I just listed would result in a 4ohm load for the amp. If series or parallel the subs would not fade left to right with the balance. Have not checked myself. I remember someone a while ago said that they do fade left/right. If they are series/parallel it will make the tap for my real sub easier. |
02-29-2016, 05:30 AM | #12 |
Rep 42
I swapped the Ghost speakers out for the OEM speakers. The audio is a quite a lot better then with the ghost Speakers, the bass no longer distorts, more solid bass and the volume seems to be greater then before. I would suggest until their is a tune to go with the Ghost speakers you are better off using the OEM woofers. I would still like to see someone produce a complete system for this car.
