02-22-2016, 01:26 PM | #1 |
Rep 1,040
Speaker replacement
Hi Guys,
I wanted to get your opinion on whether upgrading speakers would make a notable difference. I have a base system on m235xi which I believe is HiFi. I can spot 5 speakers, 2 front doors, 1 front center console and two at the back. How involved is the setup and what kind of money I am looking at roughly? Thanks in advance |
02-22-2016, 02:27 PM | #2 | |
Rep 2,942
In the time that it likely took you to type your post, you'd have found several threads that talk about this on this subforum. In the past month. :: sigh ::
02-22-2016, 06:11 PM | #3 |
Rep 1,040
My bad for missing some of the previous posts.
Anyone knows professional installer in Toronto area, ideally someone who already worked on 2 series and bavsound? |
02-22-2016, 06:21 PM | #4 |
Rep 5,105
I can't speak to replacing the speakers but the subs you can do yourself. they're a breeze to do.
02-22-2016, 09:17 PM | #5 | |
Rep 1,040
02-23-2016, 12:00 PM | #6 |
Rep 1,753
I'd start with the amp. Crappy amp pushing better speakers is still crappy.
02-23-2016, 12:36 PM | #7 | |
Rep 2,942
Conversely, better speakers with separate drivers will allow you to hear more of the inherent biases of the OEM amp -- the mid-humped DSP, poor S/N ratio, etc. -- but also makes what little tone adjustment 2-series systems have more effective. Here's the thing: it is an improvement that can be delivered to your ears. That one fact is why speakers should be done first.
02-23-2016, 12:41 PM | #8 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
02-23-2016, 12:59 PM | #9 | ||
Rep 1,753
02-23-2016, 01:04 PM | #10 |
Rep 3,256
Just keep in mind an amp upgrade means you will likely need to code ASD out or get the bypass harness. So if you like ASD, take this into consideration. I'm not exactly an audiophile, but I had planned on doing both speakers and amp. After replacing the speakers I was content enough to leave the amp alone.
For now. Maybe. |
02-23-2016, 01:23 PM | #11 |
Rep 1,753
I don't plan on upgrading the audio for quite some time. I pretty much only listen to podcasts and I like ASD. On my list of mods audio is pretty far down the list. i have heard of people being happy with just replacing speakers, but I'll have the base system. I haven't seen many people with that option and only replacing speakers. I just assumed that if the base amp is even crappier than the HK amp then I'll need to replace both amp and speakers.
02-23-2016, 08:55 PM | #12 | |
Rep 1,040
02-24-2016, 10:48 AM | #13 | |
Rep 3,256
Maybe. |
02-24-2016, 11:17 AM | #14 | |
Rep 1,040
Thanks so much for the feedback.
Now I need to find a decent installer. Quote:
02-24-2016, 11:18 AM | #15 | |
Rep 1,040
Almost forgot. Did swapping speakers affect ASD in any way?
02-24-2016, 11:35 AM | #16 |
Rep 70
No
The better is probably you because you want to take care of your 235i. Only one hour per door with insonoriation, separate midrange and tweeter, probably less time with coaxial speakers. |
02-24-2016, 11:50 AM | #17 |
Rep 3,256
Good luck and let us know what your results are!
ASD really wasn't effected. Technically it was but in a minor way. The sensitivity for the focal AC I think it a bit less than stock, so it takes more power to hit the same volume of sound. It's imperceptible though, at least to me. |
02-24-2016, 11:56 AM | #18 |
Rep 1,040
I do want to take a good care of my car, hence the search for professional installer.
I can do certain things on my own but somewhat hesitant when it comes to "gentle" work such as plastic clips. |
02-24-2016, 11:57 AM | #19 | |
Rep 1,040
Thanks. Will report back after the swap.
02-24-2016, 01:07 PM | #20 | |
Rep 1,753
02-24-2016, 02:16 PM | #21 |
Rep 272
There are two factors that affect ASD volume after an amp swap.
New amp's gain and input sensitivity. Amp gain is usually fixed and higher powered amp tend to have higher gain. Input sensitivity is the only parameter that can be adjusted. Setting this parameter at lowest setting for rear channels (or setting that will allow highest input voltage setting) will reduce the effect of ASD. Amp with DSP is little bit more trickier as amp gain adjusted and increased rear channel outputs and increased ASD effect. |
02-24-2016, 02:59 PM | #22 | |
Rep 1,753
