02-17-2016, 06:25 PM | #1 |
Rep 130
Drives: 2015 M235i xDrive
My Journey to Stereo Bliss
After several weeks of research, along with trial and error, I finally have came up with what I consider a decent system for the 2 Series. I'll preface this with saying that I'm not an audiophile or a sound engineer (at least not the sound part). However, I do demand a certain level of performance from my sound systems; whether they be in the home or in my vehicle.
We all know the 2 Series HK sound system is very lacking. Unfortunately it's one of those things I didn't scrutinize when I test drove the car. My wife's '15 X5 with the HK option sounds incredible. The fidelity is very pleasing to me - even at higher volumes. My old '08 335i's BMW Professional system with the Logic7 was pretty darn good too. The 2 Series, not so much. For some reason it just lacks any depth and separation. The output seemed pushed too forward and centered with the factory HK amp. What I ended up doing was purchasing and installing the below and after several hours of tuning, I'm overwhelmingly satisfied with the outcome. I tried the HK tune from Nelson@Bimmertech and while I do appreciate his efforts, it didn't quite suit my needs. I'm sure it's related to the different components I now have installed. Being a neophyte when it comes to audio tuning, I had hoped to use it as my baseline. I ended up creating my a really good tune just by using my own ears and tailoring everything to what I feel sounds best to me. Amplifier: Bimmertech PP82DSP Positives: Definitely a solid product and highly recommended. Negatives: Worthless without a customized tune. You will spend hours tuning yourself if you have varying components out there. Speakers: Bavsound Stage 1 (for the F80). Yes, I rolled the dice on these. Positives: Incredible clarity, more so than the factory HK speakers, especially when paired with the PP82DSP. No regrets with the purchase. Negatives: This may be a tuning issue which took me a while to work out but they definitely don't seem to handle a lot of power very well. Speakers: Bavsound Ghost Subwoofer Positives: Not entirely sure to be honest. I wasn't overly impressed with them. The factory HK subs just seemed more stout/heavy and provided a deeper base response. Subwoofer box: JL Audio ACS112LG-TW1 Positives: I wanted a little more oomph out of the low end of the spectrum. Not so much that things in the car rattle or the car next to me can hear. I just wanted a little more punch to the sound. I'm mid-40's and mostly listen to alternative rock and metal. This definitely did the trick. I'm very pleased with this sub box. Final thoughts: As I mentioned, after several hours of tweaking the PP82DSP and sub box, I finally got things to where I wanted them. The sound is amazing and I'm very pleased with the results. If anyone has questions, shoot me a PM! I've attached my tune file for those interested. Just rename the file to .afpx Thanks....
Current: 2015 M235i F22 BSM (FBO)
Current: 2015 X5 M Sport CBM (hers) Previous: 2008 335i E90 Tiag (FBO) Last edited by jetvet; 02-18-2016 at 05:10 PM.. |
02-18-2016, 07:49 AM | #2 |
Rep 146
Awesome! That's great that you found your setup. I have the Bimmertech amp and ghost subs installed. I am waiting for Bavsound's F22 set. The latest tune is a little harsh. It sounds treble and mid heavy to my ears but it fills out nicer than the F30 tune. I will use it for now until a better tune comes along. Could you share your tune and some pics of the install?
2015 ///M235iX | Mineral Grey | Dakota Black | Premium | Tech | Cold | Driver Ast | HK Sound | Black Kidney Grilles | M-Performance Exhaust | Front Splitter | Carbon Fiber Mirror Caps, Rear Spoiler and Exhaust Finishers
02-18-2016, 08:31 AM | #3 | |
Rep 832
02-18-2016, 12:41 PM | #4 |
Rep 1,753
how'd you connect the sub?
02-18-2016, 05:04 PM | #5 |
Rep 130
Thanks for the response Nelson. I'm sure the tune file is pretty solid and has everything to do with the different components I have now. Not trying to discourage your efforts or anyone else from using it. The amp itself is a fantastic product for sure.
I impulsively went a la carte on the speakers from Bavsound and replaced the front/rear tweeters and front/rear mid ranges (along with the Ghost Subs) along with the JL powered sub. After I installed those I felt I needed to dial out more mid-range and base for some odd reason. The highs were crisp but not over the top like the HK speakers. I'm probably OCD when it comes to things and I spent hours tweaking everything to the point my car said the battery was going to die. I ended up spending at least a few hours with the car running in a random parking lot (to not piss off the neighbors) tuning things
Current: 2015 X5 M Sport CBM (hers) Previous: 2008 335i E90 Tiag (FBO) |
02-19-2016, 07:53 AM | #6 |
Rep 146
Yes, I set the treble on the tone control to flat and subsequently dropped it a bit lower. I totally understand that it's the tweeters. I think you guys did a great job on the tune. Those tweeters just give it a bright, harsh, boxy sound.
