02-13-2016, 10:57 PM | #1 |
Rep 21
Got a mirror wire kit but the pins seem too short...
I got a mirror kit for my radar detector, but the pins don't seam nearly long enough to do the job.
View post on imgur.com View post on imgur.com and the little boots the pins sit in are too thick to go inside the connector channels. i'll probably need to send it back. the design of the cable got me thinking though. i'm going to kid of miss the remote from the cable i had previously http://www.bestbuy.com/site/escort-a...&skuId=8412372 and i was thinking of buying another one of these, cutting the tips and crimping my own pin terminals on the end and installing it the same way. thoughts? |
02-14-2016, 01:40 AM | #2 |
Rep 15
From the looks of it, I got the same wires you did.
Do you have auto-dimming mirrors? My car didn't and I tried tapping from the same connections. But it didn't work, So I tapped from the windshield wiper sensors instead and it worked without any problems. |
02-14-2016, 09:52 AM | #3 |
Rep 248
I hard wired mine using the passport kit from Bestbuy you posted. I ran the mute button to the right of the steering wheel under the dash. The power I ran under the door molding to the dash and into the fuse box in the trunk.
02-14-2016, 11:56 AM | #4 |
Rep 21
do you have any more details on where you put the pins? i do have the auto dimming mirror if that makes a difference.
02-14-2016, 11:59 AM | #5 |
Rep 21
do you have any pics? how long did this take you?
02-14-2016, 04:55 PM | #6 | |
Rep 248
02-14-2016, 05:06 PM | #7 |
Rep 21
02-18-2016, 10:30 AM | #8 |
Rep 15
Sorry for the late reply. Here's the pics, the pins i got are so short, they popped out when i pulled off the cover lol. But i got it zip tied to the other cord and it keeps it secured just in case i tug on it with the cover on. btw, if you route the wire out from the top, you'll have limited space to where you can mount the radar detector because the wire is pretty darn short.
having trouble with uploading pics. so uploaded it here View post on imgur.com |
02-18-2016, 10:50 PM | #10 | |
Rep 21
just to confirm, that connector has 3 pins and you have the ground in the far left black/brown and the positive in the white/red on the far right? also, if out the top is too short, how did you end up routing it with the cover back on? |
02-18-2016, 10:51 PM | #11 |
Rep 21
02-19-2016, 12:56 AM | #12 | |
Rep 15
02-21-2016, 12:42 AM | #13 |
Rep 21
