05-30-2019, 03:37 PM | #1 |
Rep 310
AC stops cooling after cruising at speed
Has anyone experienced the AC reducing its cooling after cruising at high speeds ( 85mph plus?) I just drove 3 hours to the beach and during a one hour extended cruise at 85+ mph the AC all but stopped working. The outside temperature was 90+. Engine RPM was only 2600 in my 228i.
I finally turned it off. About 20 minutes later I turned it back on when cruising at 70 mph and everything was back to normal. Is there a sensor that adjusts the AC if the engine begins to run hot? Not sure if I need to go see the dealer before my warranty expires in July or not. Appreciate any advice / similar experiences. |
05-30-2019, 04:08 PM | #2 |
Rep 400
Most likely the freeze probe on the evaporator is not working properly and leads to freeze the evaporator.
If your warranty expires in July, visit dealer now. |
05-30-2019, 04:09 PM | #3 | |
Rep 6,027
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 05-30-2019 at 07:23 PM.. |
05-30-2019, 06:37 PM | #4 |
Rep 702
As others have said, not normal. Time for a service visit.
16 Audi Q5 3.0T (Wife's Daily Driver) 66 Porsche 912 (Project) 17 GMC Canyon Denali Long Bed 4x4 (Tailgatin, Haulin & Towin) various 'one design' sailboats / stinky hockey gear |
05-31-2019, 11:21 AM | #6 |
Rep 8,942
I was told that under aggressive driving the AC will retard itself as needed so as not to impact performance - per one of the instructors at SC performance center.
06-01-2019, 11:25 AM | #7 | |
Rep 351
mine, and others have had could freeze over which still makes cool are but very low flow coming out of the vents. the F30s had this issue too. |
06-01-2019, 05:06 PM | #8 |
Rep 310
Going to dealer
Freezing over after extended cruising sound like the culprit. The air still ran but the cooling degraded substantially. Called dealer on 5/31 and first appointment is 6/11.
Thanks for all the advice! Will provide an update once I hear from my SA. |
06-07-2019, 03:59 PM | #9 |
Rep 314
I've had a few issues with my a/c. First was a bad compressor/coolant pump issue, and 40,000 miles later it was a radiator issue. Both replaced under warranty. Took them 4 days to diagnose the first issue. It was over pressurizing, which caused the system to shut down.
06-07-2019, 06:55 PM | #10 | |
Just Copacetic!
177
Rep 616
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite Last edited by AndDown; 06-08-2019 at 08:23 AM.. |
06-07-2019, 07:45 PM | #11 | ||
Rep 314
06-15-2019, 05:37 PM | #12 |
Rep 1
Ralawren, what was the diagnosis of your a/c issue? Just drove 400 miles in the Florida heat with the last 175 miles without a/c. Appreciate your response.
06-16-2019, 11:52 AM | #13 | |
Rep 400
M240 has water cooled condenser and 428 has traditional air cooled condenser. In case of M240, there was some cases with electric coolant pump issue in secondary coolant circuit or punctured secondary radiator. In those case, AC would has high discharge pressure. For 428, it is likely the AC pressure sensor issue or compressor itself problem. |
06-16-2019, 03:08 PM | #14 | |
Just Copacetic!
177
Rep 616
'01 X5 3.0 AlpWhite
06-30-2019, 06:34 PM | #15 |
Rep 475
Just had the same thing happen to me. Cruise at 80mph. Air temp here in Oklahoma was 90+. AC pretty much stopped blowing about an hour in. Had it on max AC and could hardly feel any air. Gave up and turned it off and opened window. Car only has 8,000 miles...
07-01-2019, 01:31 AM | #16 | |
Rep 310
Thanks for all the feedback. It sounds like there probably will be an issue that needs to be resolved in the 48th month of ownership😀. |
07-10-2019, 09:38 PM | #17 | |
Rep 121
There are a few things that may help reduce the likelihood of this happening: -- turn up the intensity (fan speed) in auto mode (before the system ices up - once the air flow cuts off, you have to turn off the AC for a while to let it thaw out). -- switch recirculation to manual - recirculated air is less humid, so does not cause as much icing. -- drive in eco-mode (though who wants to do that?). |
07-11-2019, 02:06 PM | #18 | ||
Rep 310
Solution was update the software that controls the cold air flow. Apparently it allows the cold air to run too long and causes the unit to freeze. Just like you all reported. Now the new SW will prevent cold air unit from running so long that it freezes. Sounds logical but will not know until my next 2 hr plus trip in the heat. |
07-15-2019, 09:40 AM | #19 |
Rep 3
rlawren
It seems improbable that a software correction would resolve the evap-freeze issue. My car has 45,000 miles. I have driven it at freeway speeds in hot weather repeatedly w/o an a/c malfunction. Suddenly on the 4th of July, during a 50 mile drive, the evap froze and all air flow and cooling ceased. It just does not seem plausible that a software misprogramming would suddenly begin to cause a cooling problem. What about the 3 years and 40,000 miles plus with no problems? |
07-15-2019, 10:03 AM | #20 | |
Rep 400
AC control has a setting to 'reduce or turn off' the AC compressor. It's typically few degrees above freezing temperature (depends on manufacturer). They can simply just raise that setting couple of degrees to prevent the freezing. (downside is that you may lose AC performance a little) |
