06-12-2023, 11:25 AM | #1 |
Rep 182
What Limited Slip Diff are you using? (or recommend)
Hello I purchased a '17 m240i about a month ago. It is a manual with rwd and I have gotten it to stage 2 already (Stage 2+ Tu pump next) and don't necessarily catch myself having too many issues with the open diff. My main issue is I'm planning to DD this car through winter (with proper tires and wheels of course) I know a LSD will improve the performance and handle, and make the car act more proper in unideal conditions. I would go right away with the M performance LSD but the price is a huge drawback. Is there anyone using a different brand LSD they promote and give some good feedback on. I also don't want to cheap out and get something for cheap that doesn't do the job well. Thank you in advanced love the platform and I know a LSD will make it even more enjoyable as a proper RWD car.
06-12-2023, 11:41 AM | #2 |
Rep 444
An LSD won't help that much in winter. It dictates what the wheels do when they're spinning at different rates (i.e. you've already lost traction in one wheel). The best thing to do is swap to proper winter tires for the conditions you expect to encounter so you don't lose traction in the first place. Perhaps also consider adding bags of sand in the trunk to provide better traction.
That said, an LSD is one of the best upgrades for these cars for performance driving. You won't regret putting an LSD on the car, even if its not the winter game-changer youre looking for. The M-Performance/Drexler unit is one of the more accessible units because its a straight swap - old pumpkin comes out, new one goes in, hook up a few sensors, plug the axles and drivetrain back in, and its done. They even come pre-filled with the right oil by BMW. The other options (take a look at DiffsOnline or similar for more info) all require machining out and replacing various bearings and seals or using a deposit + exchange system that adds to the net cost. Last edited by 230iZTR; 06-12-2023 at 11:51 AM.. |
kamilbaran138.00 |
06-12-2023, 12:05 PM | #3 | |
Rep 182
Either way overall though, all the other branded LSDs you can run end up adding up to the M performance one in terms of price? Is there not a kit that would provide all the bearings as the M one does but just not the M brand or will I have to source bearings and seals to swap with the aftermarket LSD? Thank you for the quick response and feedback too! |
06-12-2023, 12:08 PM | #4 | |
Rep 1,201
2024 M2
2019 M240i- Sold |
kamilbaran138.00 |
06-12-2023, 12:44 PM | #5 | |
Rep 318
In my (50 years of) prairie winter driving experience, an LSD on RWD improves a car substantially, to the point that it's just about as good as FRD with an open diff. Winter tires help a bit more, but I've never driven anywhere where they were necessary because good allseason tires were adequate. If I hadn't moved to a place that gets very little snow or ice, I would have added an LSD to my M240i for winter driving and accepted that it would make the car a bit less fun in the twisties (because it takes more power to induce oversteer with an LSD).
18 M240i RWD auto
Previous: 01 Z06, 99 323i |
06-13-2023, 10:01 AM | #6 | |
Rep 182
06-13-2023, 09:09 PM | #7 |
Rep 442
Hard to go wrong with the M Perf LSD. Other options are not going to be cheaper, and it works well. I recommend it to anyone looking to improve the performance handling of the car. And if you are tuned I see it as a requirement. I only wish it had an M on it or something so it was obvious you have the LSD.
As for LSD in winter, living in Minnesota, I find it a bit of a mixed bag. Yes, it will absolutely provide better traction than the open diff. But, it also has the issue that if one wheel starts spinning, they both spin. I've had instances where on a highly crowned road the back will break loose on both sides and start slewing sideways down the crown. Not cool if there is another car there in the lane next to you. The traction control on the open diff does a decent job of controlling wheel spin in really dicey conditions, without both sides breaking loose. I would still say to get the LSD, but don't think it will solve all your winter driving woes. |
JMcLellan2067.50 kamilbaran138.00 |
06-14-2023, 09:30 AM | #8 | |
Rep 182
JMcLellan2067.50 |
