2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Oil change
      10-26-2022, 01:11 PM   #23
Kernel Kurtz
Kernel Kurtz's Avatar
347
Drives: 2020 M240i xDrive
I can only drink Scotch with cola
      11-02-2022, 08:32 AM   #24
MarcoZandrini
Drives: 2018 M240i
This what I use: https://www.ravenolamerica.com/passe...vmp-sae-5w-30/
It's a full PAO (group IV) base oil. And it's BMW LL04 certified.
      11-02-2022, 04:26 PM   #25
jordan24c
jordan24c's Avatar
128
Drives: '21 EB 240, G87 M2 (preodered)
2021 BMW M240i  [10.00]
I run MolyGen 0-20. 24k miles over the last 18 months with probably 100-150 miles on the track without issue.
2021 EB M240 6MT: TC Kline Camber Plates & Coilovers, Eventuri CAI, AA Catted DP, Remus Non-Res Catback, FTP CP; M Front Lip, Rockers, Mirrors, Spoiler, Interior
      11-07-2022, 07:54 PM   #26
ggggbmw
Drives: 2017 M2 Manual
Not useful to the OP, as he's in the UK. But I just buy the Castrol Euro 5w-40 at Walmart. It is LL01 listed, and you can't beat the price. ~$27 for a 5 qt jug. It may not be as good as some others, but it's not bad, and at that price I just change it out every 5K miles.
On the upside, it's the same oil for my wife's Golf, so only have to stock one type.
The Walmart near me has also started carrying the 5w-30 as well, but seems to always be low/out of it.
      11-11-2022, 10:09 AM   #27
BigSteel
Drives: BMW 235i
Hi all thanks for the help . I ended up with motul x-clean gen 2 5w-40 and a man filter . Gonna do the change this weekend . See how it goes it did cost a good chunk of change which made me wonder . If I pay 100£ for oil only and garages offer oil change for 110£ including air filter and labour what horibllle oil would they even use ... I'm glad I'm doing this on my own
      11-11-2022, 12:33 PM   #28
cooolone2
cooolone2's Avatar
625
You will always get better quality when DIY and saving on labor... That is why it's worth DIY if you are able. +Satisfaction!
I recently took the wife's car in for a quick oil change because I didn't have time. Was before we made a few road trips. Well, after a few thousand miles and a few trips I decided to drop the oil. Man oh man ... I needed a breaker bar to pop the drain plug and that's not ok. Is the last time unless I'm physically unable, that I'll allow someone else to touch my vehicles.
      11-11-2022, 12:37 PM   #29
cooolone2
cooolone2's Avatar
625
Originally Posted by edycol View Post
What does it mean true synthetic? That is absolute nonsense. Mobil1 0W40, ESP 5W30 etc. contain combination of PAO, POE, AN, Group III and GTL. No oil is 100% synthetic. It cannot be. Especially oil that has BMW approvals which require lower oxidation.
Well, no it's not nonsense just because you are unaware of what it means. Do your research and you'll learn a little bit about the oil you're putting in your car. Oil with a lower oxidation velocity? Hmmmmm, oh, ok, why? Because they want it to sit in the engine for 10k miles? Gimme a break because that oil is oxidizing long before then.
Drop your oil at 4-5k intervals and be happy!
      11-11-2022, 07:35 PM   #30
edycol
Drives: 2011 328i xDrive
Considering I worked on oil development, I did that research prior someone, somewhere said: here is check for your work.
True synthetics were attempted in 70's. It turned out that they really, really didn't do well with gaskets. It was very hard to develop usable synthetic oil that doesn't actually damage certain parts in the way or leave excessive oxidation (and no, 5k in true synthetics won't cut).
It was in 90's when Chevron came up with hydrocracking mineral base stock that they realized it can serve either as base stock for oils not intended for performance vehicles or as stabilizer for oils with high % of PAO and POE. Also, Group III is more soluble, oxidize less etc. So, it has some advantages that actually improve performance of oils that have high % of PAO or POE.
Key is finding that balance.
In my BMW is Pennzoil Platinum Euro 5W40 which has high % of GTL. Gas To Liquid is probably most important leap since PAO application in oils. It is extremely clean, but more importantly it has very low volatility and very high HTHS, which is the most important variable protection wise. It is balanced with Group III and bit of PAO.
Add to all this additives, and you will get in most extreme case (Nulon, Motul 300V, Redline, HPL) POE or PAO levels at some 20% POE and perhaps 60% PAO. Your regular synthetic oil that is advertised as "true synthetic" has at best 50% PAO. And it absolutely doesn't mean anything. Amsoil advertise their oils as true synthetic but they are average in every aspect.
Cos270608.50
Resoelg244.00
