2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Poll - Broke Charge Pipe?
View Poll Results: Have you broke the charge pipe?
YES 20 28.17%
NO 47 66.20%
DON'T KNOW 4 5.63%
Voters: 71. You may not vote on this poll
      07-17-2018, 04:04 PM   #23
TajoMan
TajoMan's Avatar
174
Drives: M240 xdrive, X3M40i
I guess it would be little more difficult to swap in M235 than M240.
https://www.realoem.com/bmw/enUS/sho...diagId=13_1795
https://www.realoem.com/bmw/enUS/sho...diagId=13_1500
Only if the CAC breaks in M240, then it's a trouble.
      07-17-2018, 07:08 PM   #24
Ruhnie
Ruhnie's Avatar
32
Drives: 2015 m235i 6MT
Lmao I just came to the forums to see if this was a common problem as my charge pipe just blew on the way to work today. What seems to be the recommended replacement that's more durable than OEM?
Originally Posted by Ron Jeffries View Post
You'd know, I think the car stops when it breaks.
I was able to drive just fine after mine popped off actually, it just felt like it was in semi-limp mode. I didn't know what had actually happened until I got home and took a look under the hood. Could I have done any damage driving w/o it connected?
2004 Imola Red 330i ZHP 6MT RIP
2007 Jet Black 335i 6MT RIP
8Bmw168.00
      07-17-2018, 07:30 PM   #25
koston
koston's Avatar
Australia
37
Does the charge pipe break frequently even without modifications? I know it becomes an issue once you start adding power.
      07-18-2018, 06:14 AM   #26
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
My exact question: how many folks without power mods have suffered this problem?
No manufacturer builds cars for modification.
      07-18-2018, 09:11 AM   #27
XutvJet
Yes, they do break even without power modifications. In stock cars, they tend to break with higher miles. Typically 3+ years. Those that track the cars tend to see higher failures. Probably because of the constant boost and high underhood temps.
BM235iW97.00
      07-18-2018, 09:57 AM   #28
cxp213
cxp213's Avatar
313
I promptly blew mine after flashing a tune on it around 48K, I think. Once the chargepipe breaks, you're still able to drive but you won't have boost.
BM235iW97.00
      07-19-2018, 08:12 PM   #29
fstcars
fstcars's Avatar
I upgraded charge/boost pipes prior to tuning because this is a known weak point.
I will now tell you with experience, this should be be done before adding more than factory boost tables. If you haven't yet, do it! your on borrowed time.
My buddy has a 15 X4 35i 19k on it. We loaded bootmod3 stage 1 on 91 octane. 3 days later the top of the charge pipe- throttle body side blew a chunk out of the end.
Don't be cheap, spend the additional $$ up front and upgrade the charge pipes. not a matter if, but when...
      07-20-2018, 12:34 PM   #30
pz619
Drives: F87 M2C 6MT, Tesla 3
Yep, it basically become naturally aspirated. You'll likely be able to get around but at much reduced power. Basically no positive pressure will make it to the intake valves.
      07-20-2018, 01:15 PM   #31
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
You think it'd be an issue with just a Dinan Sport Tune with boost set at +3?
BM235iW97.00
      07-20-2018, 03:50 PM   #32
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
theres no way to tell.
www.nybmwcca.org
Current Cars:
      07-20-2018, 04:38 PM   #33
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
Mine must have been built on a Wednesday. Survived 3 years on JB4 Map 2, and a couple weeks on Bootmod3. Replaced both when I did my intercooler swap.
      07-20-2018, 09:08 PM   #34
ScrappyDoo
135i - charge pipe blew about 15000 miles. Running 400hp at crank.
M235i - charge pipe blew about 12000 miles. Stock.
Both times, same situation. Ground was slightly wet, grip wasn’t optimal. Did a kickdown and the rpm shot up. Heard a loud “pop” and that’s it. Could still drive but could feel the significant loss of power.
      07-20-2018, 10:16 PM   #35
dradernh
dradernh's Avatar
4399
Drives: 2017 M240i
Originally Posted by Jimbo230 View Post
Is this a problem on 228/M235 or also on 230/M240.
Anyone know? IIRC, I read somewhere here that the M240 has a metal pipe, but that might just be wishful remembering on my part.
      07-21-2018, 01:52 PM   #36
Questofthetune
Questofthetune's Avatar
446
2014 BMW 235i  [0.00]
Originally Posted by Sportstick View Post
I don't understand why anyone would break their chargepipe. I have read that they may deteriorate and break over time on their own. Mine is not broken, but I did just order, and am about to have installed, the VRSF Chargepipe upgrade kit from Mike at Extreme Power House, along with the Active Autowerke Intercooler. Doing both at the same time saves a good bit of labor and the VRSF version should be much more durable.
I have a 235 amd am pushing e85 added boost. You have a 228 so I wouldn’t imagine they blow them as much. I have 3 blown pipes sitting in my storage unit.
2014 AW M235i Sold
2013 BLK GT500 track pack/ perf pack/ recaros
      08-06-2018, 11:01 PM   #37
overcoil
Drives: M235i 6spd
One more day under original warranty - stock 235 - charge pipe blew under relatively modest boost while passing on the highway.
      08-06-2018, 11:38 PM   #38
BM235iW
BM235iW's Avatar
Drives: 2015 Black Sapphire M235i
I would say yes. My charge pipe self destructed at 27,000 miles. I have the Dinantronics Performance Tuner Stage 2 with Dinan Cold Air Intake.
The BMW dealership service writer said charge pipe failures are becoming more common around the Las Vegas area.
BTW I would like to say thank the Los Vegas BMW service writer and mechanics for their excellent work and professionalism.
hwntime272.00
      08-07-2018, 09:54 AM   #39
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
So I'm assuming under hotter conditions when air expands there is a greater chance of failure? I'm in the NW where the the heat doesn't get too bad save for 2 months of the year.
      08-07-2018, 09:59 AM   #40
aozer
aozer's Avatar
995
blew mine a few weeks ago. im at 35k miles, still under warranty.
it was at full throttle on a long straight away, 3rd gear around 6k RPM. outside temp was around 105 degrees F. my car is completely stock.
      08-07-2018, 10:30 AM   #41
overcoil
Drives: M235i 6spd
Interested ? http://www.vr-speed.com/vrsf-chargep...0-f30-n55.html
      08-07-2018, 10:30 AM   #42
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
Did the charge pipe actually crack or bust? I'm curious if it just breaks from the seal or the actually pipe cracks.
      08-07-2018, 10:48 AM   #43
overcoil
Drives: M235i 6spd
/Users/scottsinger/Desktop/thumbnail_IMG_6709.jpg
hwntime272.00
      08-07-2018, 11:39 AM   #44
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
Damn! Looks like it cracked and separated at the connection point.
