06-11-2020, 04:21 PM | #23 |
Rep 4,130
This is false.
Mods: Yes.
06-12-2020, 10:11 AM | #24 | ||
Driver - Autocross
74
Rep 178
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
06-12-2020, 10:34 AM | #25 |
Rep 864
400 At Wheels
WOW! 400 WHP is a lot.
I would simply like to see about 350-360ish at the wheels and maintain that smooth progressive OEM power. Actually, my plan is to only run : BM3 Stage 0+ VRSF CP VRSF 5" HD I/C BMC Panel Filter. Think that will get me to 350 at wheel? |
06-12-2020, 02:15 PM | #26 | |
Rep 5,364
Personally, I think it's silly though. If you want 400whp+, get a used M2C/M3/M4. The S55 is designed for that level of power and has all the necessary fueling and cooling capacity needed. 380-400whp/420-450wtq in a 3,500lb M235 would outrun most other more standard naturally aspirated sport coupes (Mustang GT, Camaro SS, Charger/Challenger). The uninformed tend to look at just the peak numbers. They don't understand that power under the curve is the true factor in dictating acceleration. A FBO EWG N55 has a very wide and thick powerband compared to something like a late model Mustang 5.0. The average power across the powerband is impressive. It's why a 330whp/360wtq N55 M2 is capable of 12.5-12.7@110-112mph in stock form.
06-13-2020, 07:00 AM | #27 | |
Rep 130
I also wouldn't mind a "tuned" M2 Stage 0+ map adding more boost at the high end, let's say after 4000rpm. Anybody seen such a map? It would basically add what stage 2 does but only at high rpm. Can you even do that - safely? Sorry for hijacking the thread.
[FONT="Arial"] M235i 6 speed, MGM. Wavetrac LSD with altered final drive ratio, MPE, MPK Airbox, side skirts, diffuser, Dinan springs, LCAs.
06-13-2020, 11:13 AM | #28 | |
Rep 4,130
06-27-2020, 02:35 PM | #29 | |
Rep 439
Drives: 2016 M235i Xdrive 8A
Building my own setups the rest of my life once I learn ignition timing, air fuel and boost tables to do it...
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
06-27-2020, 03:41 PM | #30 | |
Rep 439
I feel like pushing heavy boost at the highest RPMs should be fine for how little time ( like seconds or minutes per year) the car spends at the very top of the rev range...guess this could be subjective as to what is "dangerous" or "risky". I actually really like the Stage 0+ map and didn't see a big difference adding a downpipe, IC and Stage 2. I opened the map editor earlier thinking I was ready to start tuning but there are so many tables for the same concept, IE boost, timing, lambda etc. I thought it was just like "the boost table" and "the ignition timing table" and the "air fuel table" etc. not a family of interconnected and related sub tables.
07-11-2020, 08:14 AM | #31 | |
Rep 130
I wonder though if there are other things that can be tuned separate from torque curves. I know this from motorcycle tuning where environmental regulations make it hard for manufacturers to create smooth on and off throttle response for example. Tuning helps a lot with things other than power. Is driveability and throttle response worth getting a tune for? Or is this already baked into all BM3 off the shelf maps? Just wondering...
07-11-2020, 02:52 PM | #32 | |
Rep 4,130
They may free up some power, but most people report the benefits I listed above, and they should provide extra headroom for a custom tune.
Mods: Yes.
