11-21-2019, 11:48 AM | #23 | |
Rep 2,653
In the rear we generally recommend the 18x9.5 ET58 rather than the ET43. The 2 Series chassis has pretty high offset requirements and the ET58 helps fit the larger rear wheel and tire size without issues. ET43 may require some rear fender modifications or negative camber in order to clear. Our recommended fitment for your car with tire sizes looks like this: Front: 18x8.5" ET35 with 225/40-18 tires Rear: 18x9.5" ET58 with 255/35-18 tires -235/40-18 front tires can also be used, but we strongly suggest dialing in front negative camber to prevent rubbing. Amount of camber varies depending on tire brand and ride height. -265/35-18 rear tires may also be used, but may require 3mm or larger spacers, or trimming fender liner and shock dust boot. -xDrive requires 225/40-18 front and 255/35-18 rear tires. If you'd like to consider additional fitment options, check out our fitment guide: https://support.apexraceparts.com/hc...-Fitment-Guide Let us know if you have any additional questions! Thanks -Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
11-26-2019, 01:15 PM | #25 | |
Rep 6,799
Thanks -Tom
12-11-2019, 12:49 PM | #26 |
Rep 6,799
Strong, light, affordable.
Choose three.
