03-20-2016, 10:33 PM | #199 |
Rep 647
Yes, my driver side rear is definitely way off for some reason... I might pittle around a little but other than that no heavy driving thats for sure. Ill give it a little time to settle but need one fairly soon.. The rear wheels are lined up very nicely with the rear fenders. Love the stance and the 255's are considerabley wider... Cant wait to give her the beans..
03-20-2016, 10:51 PM | #200 | |
Rep 178
-roger
Current: '15 F22 EB 228i | M Sport | 6MT | Dinan | Rotiform | 35% tint | CF side mirrors Gone: '11 B8 A4 | '08 Infiniti G37 Coupe 6MT | '04 E46 M3 6MT |
03-20-2016, 11:51 PM | #201 |
Rep 1,091
This has been done on purpose - the lugs keep better if in no painted holes.
previous: 2003 E46 330i SMG
03-21-2016, 08:28 AM | #204 |
Rep 647
03-21-2016, 08:34 AM | #205 |
Rep 647
Thnx Jm, i kind of left them on for the time being.. I like the blue accent for some dumb reason... Are you still planning on lowering with Dinan's..?
03-21-2016, 12:21 PM | #206 | |
Rep 1,184
Realistically not till the middle or end of summer. By then I hope there is a little more info/reviews on the camber plates. Also do you or does anyone here know the size of the HRE cap, and if BMW has a cap in the same size? |
03-21-2016, 03:43 PM | #207 | |
Rep 417
Lug recesses are unpaintedI don't know HRE's practices, but it is done on purpose by some manufacturers. Although in your case there is clearly a problem with either one wheel or three wheels.
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport |
03-21-2016, 07:00 PM | #208 | |
Rep 647
03-21-2016, 09:13 PM | #209 | |
Rep 1,184
Any rubbing with the dinan drop? Are you planning on doing lca or camber plates? So did you end up going 235/255 or 225/255? |
03-22-2016, 10:12 AM | #210 |
Rep 647
I thought about doing LCA's but decided against it for now. No rubbing with the Dinans and love the feel.. Car feels light on its feet and planted. Much like the first time i drove an evo x. For some reason thats the car that stands out to me. No real loss of comfort either. (In comfort mode) No bouncing, in sport more aggressive for sure.. I ended up with 255 30 19's PSS and s 235 30 19 PSS. I bought the 235 30 19 due to it being discontinued and it was $85 cheaper per tire..
03-27-2016, 10:57 AM | #211 |
Rep 1,184
235/265 no rubbing and no modifications needed. Front is off the shock by about the thickens of my licence at full lock. Back has plenty of inside clearance.
I think it may even be possible to fit 275s with this offset. however you'd have to go up a rim size and then adjust the offset accordingly. Overall I am very happy with the fitment. All of my friends love it! I think I will space the fronts out 3mm when i get a chance though. |
03-27-2016, 12:35 PM | #212 | |
Rep 5,262
03-27-2016, 12:42 PM | #213 |
Rep 178
I think he mentioned earlier in the thread that its 18x8 ET40 and 18x9 ET44.
-roger
03-27-2016, 01:33 PM | #214 | |
Rep 1,184
I think the perfect offset for 265s with 9" wheel would be 50. Wouldn't poke as much and youd still have clearance. |
03-27-2016, 01:46 PM | #215 | |
Rep 5,262
I have a square 17x8 et42 on 245 all around... and it's pretty close to the strut but no rubbing so on 18x8 et 40 you should have even more room against the strut and also the bigger wheel diameter and shock angle should give you even some more room to fit a 245 i would think |
03-27-2016, 04:44 PM | #216 |
Rep 1,184
I'd love to fit a 245 up front. Maybe next time around I will go for that. I do think that I will need a 5mm spacer.
Here are pics I just took. Flushness is shown with wheels straight obviously. For the shock pictures I had wheels at full lock and stuck my smartphone in there. In a couple pictures you can see i wedged 2 credit cards in the gap. My dialed caliper tells me they were 2.04 mm in thickness combined |
03-27-2016, 07:18 PM | #217 | |
Rep 5,262
03-27-2016, 09:12 PM | #218 | |
Rep 1,184
I don't think 5 more mm of poke would be too much either. I am not sure if Michelin would recommend a 245 on an 8" rim though? Messing with ride height, camber and fender rolling I'm sure will all be key components. |
03-27-2016, 09:16 PM | #219 | ||
Rep 5,262
Well the rear stock is an 8" wheel with 245 |
03-28-2016, 07:46 AM | #220 |
Rep 1,184
