2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB PCV Breather Hose Removal TIP
      05-22-2021, 07:14 AM   #1
123Britt
Drives: 15 M235i AT
I have struggled in the past in removing the brittle hose off the Valve Cover and have watch several videos where a screwdriver and pick tools were used.
Here I used a ZIP-TIE to remove with great success. A little technique involved but works great & without breaking any tabs.
Photo does not show much. The small zip-tie (size unknown) is used to simultaneously open up & unlock (3) of the tabs (bottom and side tabs) -- then with a small flathead lift the top tab and pull hose of VC connection. Actually all (4) can be unlocked with the zip-tie. Hope this helps:
Polo088161610.00
OR02130.00
      12-04-2022, 09:09 PM   #2
rgsauger
Drives: BMW 435i, Ram 2500, CJ-7
Britt, YOU ROCK!!!!! SMOKING idea! Thanks for sharing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
