04-23-2019, 09:48 AM | #1 |
My car is less than a week old and on its 3rd tank
Rep 379
2018 230i coolant low
Got in the car yesterday morning and it had a check coolant level message. I drove to work but planned to call at bmw on the way home. When i got in the car to leave work the error was gone.
I dont see any coolant on my drive but could be wrong - is it possible that its just on the edge and the colder morning caused compression of the water in the coolant? does the 230 have the issue of a possible rock damaged radiator like the 235/40? The second issue (one week after I can no longer return the car ) is the front right tire has a big bulge in the side wall! i maybe hit a tiny pothole but of course, like my 135 it seems that the tires pop if you look at them wrong. I switched my 135 to none run flats after paying bmw for 2 expensive replacements but do recall one tore so bad that fix it slime was a no go - do people still suggest replacing RFTs? or just getting a better brand? |
04-23-2019, 06:02 PM | #2 |
Rep 2,067
My 2016 M235 had a low coolant alert come up about 1 year into ownership (which was 2+ years ago). Apparently not all that uncommon. Topped it off and no repeats since then (my son currently owns it).
So top it off with the overpriced BMW coolant and you'll be good to go.
2019 X2
04-23-2019, 09:02 PM | #3 |
Just Copacetic!
178
Rep 616
This was a current topic on the other board, you're not the only one with this alert:
https://www.bimmerfest.com/forums/sh....php?t=1315253
'01 X5 3.0 AlpWhite
04-24-2019, 12:20 AM | #4 |
Rep 1
I checked my coolant yesterday just out of curiosity and had minimal in there. No warning about the level. Topped it up. It's running at 109 degrees c and oil at the same. Is this about right?
04-24-2019, 12:40 AM | #5 |
Rep 368
Drives: 218i Coupe
Garage List 2016 BMW 218i Coupe [8.00]
2006 BMW Z4 M Coupe [9.00] 1975 BMW 2002 [5.50] 1985 BMW 635 CSi [5.00] 1974 BMW Alpina A2 ... [10.00] 2000 BMW Z3 Coupe [8.83] 1990 BMW 316i [8.00] 1993 BMW 850Ci [8.33] 2020 BMW X2 [5.25] 1994 BMW 318i [0.00] 2018 BMW X3 [0.00] |
BMW has a PuMA measure for it I’m attaching it below;
PuMA measure B38, B46, B48, B58, XB1H - Check Control message: Top up coolant 63482185-05 - 16/04/19 Complaint: Check Control message (ID 166): Top up coolant The coolant level in the coolant expansion tank of the high-temperature coolant circuit is below the minimum. There may also be traces of coolant in the engine compartment or where the vehicle is parked. Cause There are various possible causes: The cooling system was not sufficiently bled initially. While driving the cooling system bleeds and as a result the coolant level drops in the coolant expansion tank. The cooling system is leaking (impermissible coolant loss). Measure +++ Revision to the previous version of the PuMA measure: Note: Bleeder screw: Observe tightening torque of 2.5 Nm. +++ In the event of a customer complaint, proceed as follows: Attention: Only perform the following work on cooled-down components. 1) Check coolant circuit for watertightness: See repair Instructions 17 00 009. Check the high-temperature coolant circuit for watertightness using test for loss of pressure. Test pressure of cooling system (excess pressure): 1.5 bar test period: 10 minutes 2) Observe pressure: No pressure drop: Continue with point 4. Pressure drop present: Continue with point 3. 3) Search for leak. Check coolant pump. The coolant pump has a reservoir. During engine operation the slide ring seal of the coolant pump needs to be lubricated. The coolant required for lubrication is collected in the reservoir. Slight traces of coolant could be visible on the lid of the reservoir. Slight traces of coolant on lid of reservoir (see attachment, figure 1): Clean the lid. Check if coolant leaks again at the lid if excess pressure of 1.5 bar is applied. - If coolant is leaking: Replace coolant pump. - No coolant leaking: Do not replace coolant pump. Search for leak and repair accordingly. Excessive traces of coolant on lid of reservoir (see attachment, figure 2 and 3): Replace coolant pump. After repairing the leak: Bleed cooling system and check for watertightness: See repair Instructions 17 00 039. Note: Bleeder screw: Observe tightening torque of 2.5 Nm. 4) Release pressure: Adjust the filling level in the coolant expansion tank of the high-temperature coolant circuit. In doing so, it is imperative to follow repair instructions 17 00 039. The filling level in the coolant expansion tank is adjusted either to the maximum mark or 200 ml above it, depending on the model. Notes on factory filling of high-temperature coolant circuit: The initial coolant circuit capacity of the high-temperature coolant circuit was already optimised in the vehicle factories. The introduction dates are: F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36: 01 September 2017 G11, G12: 5 June 2018 G30, G31, G32: 01 February 2019 G38: as of series launch Invoicing: Processing and reimbursement must be conducted according to current warranty conditions. In case of defective cooling system bleeding, use the following defect code. Recommended defect code for GWK cases: 17 11 00 72 00 Use the following defect code for a leaking coolant pump. Recommended defect code for GWK cases: 11 51 07 48 00 For other leakages. Obtain the corresponding defect code from the "Commercial Service Data (KSD)". Validity information Model series:[F30, F21, F32, G31, F31, F20, G30, F23, G11, F34, F33, G32, F22, F36, F35, G12, G38] Engine range:[B58M, B48M, B46O, B48O, XB1H, B38M] Body style:[ALL] Fault codes:[] Production period:- |
Frack39.00 |
