04-06-2018, 11:02 AM | #1 |
Rep 1,091
Battery drainage or lights left on?
Today with my car in the garage, I've received the following text message on my cell phone:
From: BMW ConnectedDrive [mailto:bmwconnecteddrive@bmwfin.com] Sent: Friday, April 6, 2018 6:27 AM To: p.wozniacki@wp.pl Subject: Note: The battery in your vehicle V226928 is low. Dear BMW ConnectedDrive Customer, There is a risk of not being able to start the engine of your vehicle V226928 because the lights are switched on. Please check whether the lights are still needed. Kind regards, BMW ConnectedDrive www.bmw-connecteddrive.co.uk Please do not print this email unless you really need to. Thank you. I rushed to my garage, unfortunately didn't think to wait till the rolling-up door is completely open and pressed the Open button on my car fob. Sure enough, the tail lights were on - but it might have the result of my just having opened the car. Anyway - the engine started, but there was a message in the dashboard about the battery being drained... I'm now charging it, but would like to hear your opinions on what the problem has been. I always have the switch in the A position, so even if I - for any reason (distraction etc.) - didn't shut the car off with the fob last night, there is no way for the lights to stay on all through the night - or is there? Even if they indeed were on, after more than 12 hours after closing the garage behind me the battery would probably have been already too week to even start the car, no? Anyway, I'm quite a bit nervous about the incident. Would the battery be already going, and the Conned Drive message about the lights has just been one of those general sort of messages, actually only meaning that my battery discharge rate has suddenly increased? With the switch in A position, the lights would go off even if I didn't actually close the car with the fob... Opinions welcome, Piotr
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 04-06-2018 at 11:10 AM.. |
04-06-2018, 11:20 AM | #2 |
Rep 2,010
There are a number of factors that could cause a depleted battery.
1. Too many short trips. 2. Time between trips. 3. Old battery. I believe our cars draw a small amount of power while sitting, so long time parking could eventually drain the battery (this has happened to my M235i). Back-to-back short trips don't allow enough time for the alternator to fully recharge the battery. And lastly, batteries don't last forever, so you might have it checked out at your favorite servicer.
2014 BMW M235i
2024 Mercedes Benz GLC300 Expert ultracrepidarian |
04-06-2018, 12:00 PM | #3 |
Rep 1,091
Yeah, we all know these factors. My questions is: since I don't have many non-driving periods, and yesterday was one of usual days (actually, over 200 km on a motorway) - is it heard off that the headlights really stayed on over the night? Or is this CD message about the results (low battery) rather than causes (lights on over the night)?
Piotr
04-06-2018, 12:13 PM | #5 |
Rep 1,091
The evening before (last night); I got the message today around the noon...
04-06-2018, 12:29 PM | #6 |
Rep 5,582
There is the possibility your battery is going bad. If it's the original battery 4 years approximately.
If you have a BMW dealer nearby then they can use a more sophisticated battery diagnostic tool. I understand what your saying about the message being generic and the light switch positions and you being concerned. |
04-06-2018, 12:32 PM | #7 |
Rep 1,091
In the worst scenario: gone battery, do I have better options that just have my BMW dealer sold me a new one and program the car? Can it be done safely (and considerably cheaper) by an in dependent shop? Of course I assume my extended warranty doesn't covet this - or should I be fighting for free (warranty) replacement, considering noone can prove a negligence to me (I'm driving long trips only, like 600km minimum, at least once a week)?
Piotr PS. And again: is it technically possible that with the fob with me, some 200m away from my garage, and with the selector switch always in the Auto position - the lights were on indeed? Nobody even tried to address this basic question so far; my technical knowledge tells me it should never happen - so if it happened, isn't it a malfunction which (unlike a dead battery itself) should in fact be covered by (even the extended, i.e. with lots of exclusions) warranty? I've been trickle-charging the battery for some 6-7 hours now, and it's still not full according to my rather high quality Bosch charger! Piotr
04-06-2018, 12:35 PM | #8 | |
Rep 1,091
Piotr
04-06-2018, 01:17 PM | #9 |
Rep 151
Temperature changes can also cause the battery drain message. I'm not sure how it is in Poland for weather but I know in the years of ownership with my 2015 335 if the temp goes from above 0 C to -26C or colder it is guaranteed I'll get a battery drainage message. I talked to the service adviser at my dealership and they said its just the sudden change in charge from the temperature, they get tons of calls at the start of winter every year.
Those temperatures are my estimates, it might not even need that big of a drop to be impacted. |
04-06-2018, 01:51 PM | #10 |
4131
Rep 3,829
When you left the car, if the indicator stalk was accidentally hit, the parking lights would be turned on on one side (I believe this will trigger a dash message to the effect they are on). When the car sent the low battery message, the lights would have been switched off. As the indicators are electronically activated and there is no mechanical stop for them, there would be no evidence this had been the case.
04-06-2018, 02:01 PM | #11 | |
Rep 5,582
Couldn't really find anything good in lifespan https://auto.howstuffworks.com/under...r-battery1.htm Last edited by overcoil; 04-06-2018 at 02:36 PM.. |
