2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Suspension / Brakes / Chassis / Spacers ▀▄ eas | Dinan Suspension Line Up - Authorized Dealer
      04-01-2016, 05:02 PM   #1
chris @ eas
274
Drives: BMW
Now available from EAS is Dinan's complete line up for the F22. As an authorized dealer we are ready to handle all your Dinan needs whether it be install or shipping.
PM today for pricing and details!
Dinan - Adjustable Anti-Roll Bar Set - BMW F22/F23 2-Series, F30 3-Series, F32/F33/F36 4-Series
Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner.
Front Anti-Roll Bar
Add a 28mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable up to 45% to 97% stiffer than the stock bar*. This 3 hole bar can be mounted in 3 different positions with stock BMW end links.
Rear Anti-Roll Bar
Add a 19mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time.This anti-roll bar is adjustable up to 84% to 474% stiffer than the stock bar*. This 3 hole bar can be mounted in 3 different positions with stock BMW end links.
Features:
- Less Body Roll
- More Mechanical Grip
- More Stable At Limit
- Front: Large 28mm size // Rear: Large 19mm size
- Front:
-- Stock bar is 22.2 mm on the M235i which means the new bar can be adjusted from 45% to 76% stiffer than the stock front sway bar.
-- Stock bar is 24.2 mm on the 328i w/ M-Sport which means the new bar can be adjusted from 50% to 81% stiffer than the stock front sway bar.
-- Stock bar is 21.2 mm on the 335i/435i which means the new bar can be adjusted from 63% to 97% stiffer than the stock front sway bar.
-- Stock bar is 22.2 mm on the 335i/435i w/ M-Sport which means the new bar can be adjusted from 54% to 87% stiffer than the stock front sway bar.
- Rear:
-- Stock bar is 15 mm on the M235i which means the new bar can be adjusted from 84% to 130% stiffer than the stock rear sway bar.
-- Stock bar is 12 mm on the 335i/435i which means the new bar can be adjusted from 359% to 474% stiffer than the stock rear sway bar.
-- Stock bar is 13 mm on the 328i/335i/435i w/ M-Sport which means the new bar can be adjusted from 243% to 329% stiffer than the stock rear sway bar.
- 3 hole bar with 3 possible positions on the bar
- Tubular (Hollow) Construction
Models Supported:
BMW 2014+ F22/F23 228i & M235i
Dinan - Performance Spring Set - BMW F30 335i
Suspension systems that not only transform the stance of the vehicle but also maintain ride quality and improve upon handling are what Dinan® suspensions are known for. This is accomplished by pairing springs sets with bump stops, spring perches or both to maintain suspension travel resulting in a smooth ride while also improving mechanical grip and handling. This is what makes Dinan suspension systems unique. While we are able to sell each component separately it is highly recommend that both the spring sets and the supplemental ride quality and handling kits are used in tandem in order to maintain the Dinan quality standards our customers are used to. Experience the Dinan difference with this combination and enjoy the ride it provides.
Dinan's Performance Spring set for the F30 335i provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan® lowers the 335i by a 3/4" in front and 3/4" in the rear for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The 30% increase in stiffness will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at speeds as low as 20 mph, up to the top speed of the vehicle.
Features:
- 30% increase in spring stiffness
- Lowers the vehicle 3/4" in front and 3/4" in the rear
- Preset to prevent spring sag
- Compatible with both conventional and factory electronic shocks
Models Supported:
BMW 2014+ F22 228i
BMW 2014+ F22 235i xDrive
Dinan - EDC Suspension Tuning - BMW F30/F34 335i & F32/F33/F36 435i
Just as Performance Software dramatically changed the world of engine tuning, Shockware™ will forever change suspension tuning and now its available for all F30/31/32/33/36 3 and 4 series vehicles. With the wide spread use of the Adaptive M Suspension, throughout its most powerful models, DINAN® has tuned it for ultimate performance. Match DINAN® Shockware™ with a DINAN Performance Suspension System for superior handling in all driving conditions.
Since the introduction of the Adaptive M Suspension system, DINAN® has embraced the flexibility and performance that can be achieved by a suspension upgrade that leaves the Adaptive M Suspension system in place. With the addition of DINAN® Shockware™ this solution takes another large step forward by also reprograming the damping curve of the damper itself. The Adaptive M Suspension system works by monitoring sensors measuring all aspects of the BMWs behavior then analyzing them and adjusting the actuators in the shock absorbers, which, with the help of magnetic valves change their characteristics in a fraction of a second. DINAN® Shockware™ reprograms the software making the adjustments to respond in a way that would have recently required purchasing a new performance set of dampers, thus drastically reducing the cost of a suspension upgrade.
The Driving Dynamics Control switch is fully functional with the setting upgraded for each mode. Each setting has become more performance based in how it reacts to changing road and driving conditions. The "Normal" setting is now tuned to be the "Sport" setting. The big change is when the BMW is set to "Sport" as that is the new DINAN® high performance programming.
DINAN® Shockware™ can be used as a stand alone upgrade. However, your BMW performs best when paired with the DINAN® Performance Suspension System or any performance spring sets. The suspension upgrade software is loaded into the BMW the same way BMW loads and updates stock software. This software upgrade falls under the DINAN factory matching new car warranty of 4 year / 50,000 mile coverage.
Ordering:
Phone:
You can reach us directly by calling 866.669.0705 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM-2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x26
Email: chris@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
      04-06-2016, 04:56 PM   #2
chris @ eas
274
Drives: BMW
Improve your car's handling with Dinan suspension!
PM for pricing and details.
      04-08-2016, 11:46 AM   #3
chris @ eas
274
Drives: BMW
Get your Dinan adjustable anti-roll bar today!
      05-07-2016, 03:05 PM   #4
chris @ eas
274
Drives: BMW
Improve your handling today with Dinan springs.
PM for more details and pricing!
      05-08-2016, 01:11 PM   #5
sakitnyatudisini
Drives: ford f150
Interesting to it,how much is it?
      06-02-2017, 04:58 PM   #6
kevin @ eas
General
kevin @ eas's Avatar
Drives: 2015 BMW M4
Thanks for the inquiries
Dinantronic tunes in stock and ready to ship
PM today to get yours
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      09-27-2017, 01:32 PM   #7
chris @ eas
274
Drives: BMW
Dinan Springs and the Dinan Stainless Steel Free-Flow Exhaust found their way onto this M235i on a recent visit.
Please shoot a PM to order Dinan parts!
