08-16-2015, 04:40 PM | #1 |
Rep 32
Oil change
I am planning to do an oil change for my M235i. How much oil should I plan to buy? I read 7qt somewhere.
Btw, this is my first car without a dipstick so once I start adding oil after I drain the old oil out, when do I know I have added enough? Is the only way to get in the car, start the engine and wait for the electronic dipstick to perform a check? |
08-16-2015, 05:05 PM | #2 | |
Rep 5,262
08-17-2015, 04:07 PM | #5 |
Rep 886
The BMW branded oil is now sold in liter bottles. Buy 7 liters, put 6 in, get the engine warm and check the level. Odds on, you'll find it reads at Max.
The sump is 7 quarts. There's some holdup when you drain it, especially if you do it on ramps, and 6 liters will usually do just fine. Put the leftover liter in the trunk.
08-17-2015, 05:00 PM | #6 | |
Rep 32
Having no dipstick is just weird. I am coming from an Audi S4 that also had an electronic dipstick, but there was an actual dipstic slot in the engine and you could buy a dipstick for $15 and plug it in. I am surprised that this is not an option for the Bmw |
01-31-2016, 08:04 PM | #7 | |
Rep 71
Thanks. |
01-31-2016, 08:16 PM | #8 | |
Rep 5,579
01-31-2016, 08:48 PM | #9 | |
Rep 5,262
else when the oil starts to drip it will start falling onto the cover liner... |
01-31-2016, 11:12 PM | #10 | |
Rep 5,579
http://formafunnel.com/ |
02-01-2016, 03:26 AM | #11 | |
Rep 886
