2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack RW.437M - Low-Pressure Cast Lightweight 19's
      04-04-2017, 04:15 AM   #155
Vyruz Reaper
Reverse Homer
Vyruz Reaper's Avatar
Drives: ///M240i
Originally Posted by Joe240 View Post
Originally Posted by fbsm View Post
Thank you very much for posting the photos and putting my mind at ease
np, sorry for the potato quality. Only way to downsize pictures on iPhone was to crop them which made them essentially zoomed in pictures.
You could try screenshotting the image and it will make em low rez
      04-07-2017, 08:24 AM   #156
tinyTIM
tinyTIM's Avatar
Drives: 2016 m235 xdrive
2016 BMW M235xi  [0.00]
Well, Spring is here and since I put winter tires on my stock wheels this year, I need to get some new Summer wheels now. Really like the looks of this style on the 2 series. I was considering some other replica 437's that came in 18x8 but they have been out of stock for awhile. I would like to do a square setup on my x-drive on stock suspension. Thinking of going with the 18x8.5 with 39 offset to minimize the poke. Does anyone know if I can get away with 245-35-18 square with these? I assume the fronts would be pretty close to the suspension. Been playing around with the calculator on Will They Fit but not sure how much clearance I need. Or should I stick with 235 square? Any help or suggestions would be appreciated. Thanks.
      04-08-2017, 11:21 AM   #157
DSTRAKD
Drives: 2016 MBS M235i
shorter lug bolts for shaved wheels?
So with the wheels shaved 4mm for ideal fit, can they mounted using stock lug bolts?...or do they require new shorter lug bolts? Sounds like the wheels still poke a wee bit with 4mm shaved. OEM has stated 4 - 5mm, why not go straight to 5mm (I know that's shaving hairs). Is it crazy to even suggest 6 or 7mm? Love these wheels...and Joe the car looks great.
Forgive me, I'm learning a ton here. When installing will these require hub centric rings? (M235i)
You guys are awesome for sharing all this info. The education is invaluable. Thanks
      04-08-2017, 11:52 PM   #158
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
No hub centric rings needed. These have the correct center bore already. Also the oem lugs worked 100% fine for me.
I'd measure the inner clearance on my 235s to see if 245s would clear in the front, but my wheels just caught a nail the other day so I put my factory ones back on until I get a replacement tire. My judgement though says it might end up rubbing on the lower part of the strut, but again can't confirm at the moment.
tinyTIM33.00
      04-10-2017, 02:12 PM   #159
crabu2
Drives: Truck and ...
So how much are the 18" machined?
'20 240ix convertible
      04-10-2017, 02:47 PM   #160
tinyTIM
tinyTIM's Avatar
Thanks Joe240, was hoping you would chime in. Will probably just go with 235 square. Would be nice to fit the 245 under there though and I don't really want to go staggered.
      04-19-2017, 09:21 PM   #161
kohlzor
Drives: 2017 M240xi
Probably to be on the safe side until you see how they sit with the lowered car. If the 255s for fine and you think 265s could squeeze in after that, you can always go bigger on the second set of tires
Joe,
If I don't plan on lowering the car would the MPSS on 265 be a problem?
      04-20-2017, 12:27 AM   #162
Joe240
Joe240's Avatar
Originally Posted by kohlzor View Post
Joe,
Yes, 265s regardless of brand will fit the 9.5s without issues (44 or 40 offsets) when staying on stock suspension. Lowering is where the issue would come in.
      04-20-2017, 02:44 PM   #163
SupremeHustle
Drives: 2020 X4MC 2021 F-Type R
I think these wheels would look great on my car in 19s. Would someone please recommend the size I would buy for a square setup? And should I go with 235 or 245 for tires?
Much appreciated. Love, love, love this forum.
      04-21-2017, 01:19 AM   #164
Joe240
Joe240's Avatar
If going square, only option would be 8.5s et 35-39. Tires depend on your ride height. If stock suspension, then 235 or 245 would work. If lowered, 235 would be your only option unless you have coilovers or camber plates in the front, then you might be able to clear 245, but safe side would be 235.
      04-21-2017, 05:03 AM   #165
Raincity_G87
Raincity_G87's Avatar
Drives: G87
Originally Posted by OEMconcept View Post
RW.437M
Finish: Black Machined Face
Specs: 18x8.5 ET35 - 18x9.5 ET35 - 19x8.5 ET35 - 19x9.5 ET35 - 19x9.5 ET40 - 19x9.5 ET44
- Low-Pressure cast
- Powdercoated Finish
**INCLUDES BMW CENTER CAPS AND ///M DECALS**
Hi, can you sent me a quote for a set of 18 x 8.5 ET35 square shipped to Vancouver BC? Thanks
      04-21-2017, 08:18 AM   #166
OEMconcept
OEMconcept's Avatar
Drives: BMW
You've got mail!
      04-21-2017, 09:58 AM   #167
SupremeHustle
Thank you, Joe.
The hunt for wheels continues...
      05-11-2017, 09:59 AM   #168
crywolf
crywolf's Avatar
Drives: 2015 M235xi
pm sent
2015 m235xi
Enzo Tune/Dinan intake/VRSF dp/Evolution FMIC/MPE
*Someone once told me "Badass ain't cheap and cheap ain't badass"*
      05-20-2017, 03:52 PM   #169
Chris_B
Chris_B's Avatar
Drives: Melbourne Red 2016 M235i
2010 BMW 128i  [0.00]
Pricing to 92127 on the 19" staggered?
Much appreciated!
      05-22-2017, 04:50 AM   #170
AlexM235i
AlexM235i's Avatar
Germany
Could you please send me an PM for two pcs. 8,5x19 ET39 and two pcs. 9,5x19 ET44? I'm from Germany and don't know how high the customs charges are. Have you already sent some wheels to Germany? Thanks in advance!
      05-22-2017, 06:23 AM   #171
Joe240
Joe240's Avatar
Got my wheels shipped to me in Germany through UPS. Shipping was a little high, customs was 1200 Euro the first time. I asked them to reevaluate and they came back with 1600 Euro. However, the German customs website says the customs charge is only supposed to be like 30% or something like that of the cost of the product. So UPS was trying to shaft me, or they paid to much themselves and tried to pin the costs on me.
If you're US Military in Germany, you can fill out a form that allows you to not pay the import fees.
      05-22-2017, 06:58 AM   #172
AlexM235i
AlexM235i's Avatar
Germany
Thanks Joe! So you paid 1600€ for the set including customs and shipping? "Unfortunately" I'm just a german civilian :P
      05-22-2017, 07:27 AM   #173
Joe240
Joe240's Avatar
Nope, $1600 USD for the wheels and shipping to Germany from Canada almost a year ago. Customs fees would have been an additional 1600 Euro if I didn't have the tax exemption form.
      05-22-2017, 08:55 AM   #174
AlexM235i
AlexM235i's Avatar
Germany
wow, that's insanely expensive...
      05-22-2017, 11:52 PM   #175
Joe240
Joe240's Avatar
Indeed. Like I said though, I think UPS was trying to take advantage of me thinking I didn't know the law about the import fee percentage.
      06-05-2017, 06:58 PM   #176
bowhun2r
bowhun2r's Avatar
Drives: F22/B58 M240xi
Extremely helpful posts Joe240 Thank you...
I just paypal'd (yes.. that's a verb) a down payment to Anthony for a square 18x8.5 et35 shaved to et39 for my yet to be completed M240.
My question(s)... I had originally planned on 245/35/18 Conti's, but after many PM's to Anthony and reading this entire thread (a few times) looks like that isn't the safe bet for a stock xdrive M240 setup. I do not plan on lowering the car and will keep the stock height. So leaning towards the safe/no rub/no poke setup I was going to pull the trigger on PS A/S+3 in 235/40/18. With the 18x8.5 et 39 square setup on a stock F22 xdrive suspension.... this should work?? No rub or poke?
A little of 2K in a wheel/tire package, I just want to ensure when the goods get delivered I'm not with a setup that doesn't fit my bill.
FWIW I was going to do the Alutec driven 18x8 40et in 245/35/18 square setup until I saw the 437M wheels.
TIA
Scott
