brake pads change; reuse brake pad expansion springs and caliper guide pins? |
04-15-2020, 10:43 AM | #1 |
Rep 119
when changing pads, do most people reuse the caliper guide pins and the expansion springs? wear sensors too (provided they havent tripped yet)
guide pin front/rear part#: 34116850934 / 34216857152 expansion spring front/rear part #: 34116862801/ 34216857151 buying these parts essentially about another $100 since multiple sets have to be bough for front/rear sets my 2016 M235x is approaching 40K miles. this will be my first time doing brakes on any vehicle. after watching some videos, the process seems pretty straightforward. i measured the brake pads when i recently rotated my tires and they are ~6mm so plan on doing the brakes myself soon. during a dealer brake job do they typically replace all those parts too? the service guide says to replace the spring and pins if vehicle is over 48 months. my planned purchase parts list: -akebono eur ceramic pads -motul 600 -bleeder kit -stoptech stainless steel lines -anti-squeak brake compound/lube -brake cleaner fluid/spray -various tools: wrench 11mm (for bleeding), caliper/pad spreading tool anything else i may be missing to complete a brake job? |
04-15-2020, 11:16 AM | #2 |
3706
Rep 3,620
You will also need a punch to drive out the guide pins and a means of measuring the brake disc thickness to confirm it is above the minimum spec: https://www.newtis.info/tisv2/a/en/f...rakes/J7O1UV0e
Also bear in mind that with Motul RBF600 you need to bleed once per year to avoid excessive moisture in the brake fluid, as it is aggressively hygroscopic compared with lesser DOT 4 fluids. |
04-15-2020, 11:40 AM | #3 | |
Rep 119
i measured my rotors--the front ones at least, the rear i cannot access due to the shield--and they were still within spec. i don't plan to track my car, do i really need to do a brake flush annually? Last edited by vexingv; 04-15-2020 at 11:47 AM.. |
04-15-2020, 12:22 PM | #4 | |||
Rep 3,505
Castrol SRF has a high boiling point and is non-hygroscopic. That product is generally a better choice for a street car that doesn't see regular/annual brake fluid flushes. Quote:
IIRC, at a maximum of 3% water content your brake fluid is supposed to be changed. You can buy a brake fluid tester and check the moisture content yourself.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 04-15-2020 at 12:37 PM.. |
04-15-2020, 12:30 PM | #5 | |
3706
Rep 3,620
The RBF600 is not the right fluid for general road use if it is not flushed enough, it is a case of the rate that it absorbs moisture that is the problem, it reaches the moisture absorption limit faster than most DOT 4 fluids, at that point brake system corrosion starts. The BMW fluid is good for 2 to 3 years in contrast. Some further info: https://drspower.com/products/motul-rbf-600. As far as I know there is only one very high temperature brake fluid that is not too hygroscopic so can be changed at 2 years or more intervals, that is Castrol React SRF, but I'm not sure if it is low enough viscosity to be used in current BMW brake systems, that call for low viscosity DOT 4 fluids. For that matter RBF600 is not a low viscosity fluid, but probably will work OK overall. |
04-15-2020, 01:42 PM | #6 |
Rep 322
04-15-2020, 02:41 PM | #7 | |
Rep 119
04-16-2020, 08:14 AM | #8 |
Rep 2,877
Good you aren't going with track fluid for this. Factory fluid is very close in terms of boiling point, and also designed to work properly with your ABS - you'll never exceed it's capacities on the street. You also need to cycle the ABS to get all the old fluid out, so it may be cheaper to pay a good indie shop that has the ISTA machine - you can buy code readers that can do this, but if you aren't planning to flush brakes often, the flush kit plus gizmo will cost a lot more than a good service. The pins and springs aren't really stressed parts, but I see them for $12/set thru Zeckhausen, and for that it would probably be worthwhile to replace them (at least get one extra set so that when you drop a pin and lose it you aren't screwed). A heavy flat metal bar works better than a hammer for driving the pins back in due to space issues - if you are superOCD, protect the pin area with some painter tape first (i.e. 1"x1/4"x12-18" steel was what I saw being used very well). If you can find them, the drift pins with a cup-tip are the hot ticket, but not essential. IIRC, you also need to depress the brake a little while doing the line-replacement, or else you drain out the master cylinder, and bleeding that is a real PITA (I had a shop do it as part of my season-opener flush/padswap so not exactly sure).
04-16-2020, 08:25 AM | #9 |
Rep 5,579
I use a fine steel wool to polish the pins.
Also I changed out the pad wear sensor when a dealer parts guy said they definitely should be changed even if not tripped - but I don’t know. When accessing the fender side of the sensor, use good lighting even a magnifier to see how the plug is undone - the tab gets pressed in as I recall, you shouldn’t need to pry off the outer plug but press in the tab on the inner socket - but verify. |
04-16-2020, 11:57 PM | #10 | |
Rep 119
04-17-2020, 12:25 AM | #11 | |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-17-2020, 08:00 AM | #12 | |
Rep 2,877
04-17-2020, 07:50 PM | #13 | |
Rep 445
If you're not tracking, definitely stick with the OEM or Pentosin LV fluids. I use the Pentosin LV for winter use. NONE of the high-temp brake fluids are anywhere near the 'low viscosity' values of the OEM LV fluid. Massive differences. (SRF and RBF 600 are similar viscosity.) And I have no doubt the LV fluids perform better from an ABS cycling perspective. Does it matter? Well... I want top performance out of my ABS and stability control when it's cold and icy. Living in Minnesota, I get a lot of that. So, I take the effort to put LV fluid back in the fall when I put the winter tires on. If you live in the south, it's probably not worth it. |
Maynard3855.50 |
04-24-2020, 11:35 AM | #14 |
Rep 119
Update: Parts have been arriving slowly throughout the week, but i finally got the last shipment yesterday. But there was an issue with one of the ECS Exact Fit line; the metal connector isn't the correct length/distance from the caliper.
I had already prepped my car on jack stands and removed the old pads while i waited for parts to arrive. i guess now i'll only be able to change the pads. beyond loosening the master cylinder cap to allow me to push the pistons back, will i be ok delaying a brake bleed/flush until after i install new brake lines? in regards to stainless steel lines, any recommendations? The ones that i see for sale are from StopTech, Goodridge, Turner Motorsports, and ECS. The Turner and ECS ones look pretty similar (and i was told that StopTech actually is the company that make the ECS lines). |
