04-01-2017, 09:28 AM | #67 | |
Rep 78
Frankly I've not been very impressed with Carly so far. Probably should have bought BimmerCode which seems much more powerful for less than half the price. Does anyone know if the Carly adapter will work with BimmerCode? |
04-01-2017, 09:52 AM | #68 | ||
Rep 5,105
04-02-2017, 03:31 AM | #69 |
Keyboard warrior
16
Rep 66
Hello all
I have Carly and have coded auto start/stop and seatbelt warning off on my 2017 M240. I want to code the digital speedo, but am leery, as when I coded it on my X3, it replaced the dash logo with M550D! Those of you who have coded the digital speedo on a 240 with Carly - is the M240i dash logo retained? Thanks |
04-02-2017, 07:31 AM | #70 | |
Rep 5,105
04-02-2017, 02:50 PM | #71 |
Rep 5,105
Tested 2 of the 3 new features (disable ASD and exhaust valve). Both work as advertised...BUT, you have to redo every time you start the car which is a bummer. Not sure why that is, but that's how it works.
I didn't test the 3rd feature which was support for NBT idrive. Maybe later in the week.
04-02-2017, 04:08 PM | #72 | |
Rep 1,804
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
04-02-2017, 06:26 PM | #73 | ||
Rep 5,105
You're making me think now....maybe I did something wrong. I'll try again Tues or Wed.
04-02-2017, 06:57 PM | #74 |
Keyboard warrior
16
Rep 66
04-09-2017, 05:36 PM | #75 |
Cone Killer
85
Rep 208
I've been playing around with the new update. The ASD update only gave me the option of turning it off or changing to M3/M4 or M5/M6 sounds, no valve options. I turned it off and it seems quieter in the car. It also seems to have saved as it's the same today as it was yesterday.
I also played with the new NBT options. Adding the Sport Display is cool (not sure about accurate) but certainly fun to watch whilst driving. It did cost an additional $15 to 'purchase' the new update. |
04-09-2017, 06:01 PM | #76 | |
Rep 5,105
Also, turning the valve on/off is separate from the asd change just to be clear and yes asd does stay programmed (my mistake in an earlier post) but the exhaust valve on/off does not. that's the one you have to set each time - in fact, you need to leave the app running on the actual screen where you make the valve change. Bizarre.
04-09-2017, 06:39 PM | #77 | ||
Rep 8,364
I also see DRL light switch (ie position when active). I also see rear DRL as welcome light. But, I do not see rear DRL. Based on other available codes, it should be an option.
If your Carly adapter a Vgate Wifi iCar2 OBDII Elm327? Quote:
04-09-2017, 07:52 PM | #78 |
Rep 78
I haven't been able to find anything on the Carly site regarding what can been coded on an NBT iDrive. I only see mention of CIC. Am I missing something?
04-09-2017, 07:55 PM | #79 |
Rep 5,105
Hmm...well, the other way to see what's code able is to connect to the carly bluetooth device and select NBT. Then run the READ option then you'll see the list of what options you van code.
04-09-2017, 08:21 PM | #80 | |
Rep 8,364
At top of page you can select chassis. Then, expand different sections for options. |
04-10-2017, 06:14 AM | #81 | |
Rep 78
I sent an email to Cary support and they acknowledged that their support pages haven't kept up with their latest release. |
04-10-2017, 06:33 AM | #82 |
Rep 5,105
As I said, just plug the obd reader in and scan the ecu's, select the NBT option, then select the "Read" option...you'll see everything that's available to code, which isn't much frankly.
Sleslie40.00 |
04-10-2017, 10:32 AM | #83 |
Cone Killer
85
Rep 208
04-10-2017, 06:34 PM | #84 |
Rep 5,105
It has its own button - top row. It's not even really coding. You can toggle it on/off so long as the obd reader is connected and the carly app is running. It's a new button next to the idrive button. Even has a "NEW" banner running through it.
04-10-2017, 07:13 PM | #85 |
Cone Killer
85
Rep 208
Thanks! I'll take a look tonight.
04-12-2017, 08:55 AM | #86 |
Captain Unsensible
100
Rep 737
Drives: 2016 M240i Coupe - Estoril
I've switched across to Bimmercode as that has far more options for coding out of the box and allows expert mode coding.
I've also now setup eSys with the cable, so have all options. The cost of Carly compared to the others and what it offers are not that good. |
04-12-2017, 09:50 AM | #87 |
Cone Killer
85
Rep 208
04-12-2017, 07:40 PM | #88 |
Rep 78
Where you able to use the Carly OBD adapter with BimmerCode?
