2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Will 18x8 ET32 18x9 ET35 fit??
      07-17-2017, 10:01 PM   #1
CFF
Drives: F22 220D
I currently have M3 LCAs in the front, and full adjustability of camber and toe in the rear, now I know the front should clear since I am running 18x8.5 ET35 right now, what about the rear ?
My current set up for the rear is -2.3 camber with 18x9.5 on coilovers with 265/40/18
Thanx in advance!!
      07-18-2017, 09:32 AM   #2
FakeM2
Drives: Manual M235
A little off topic but what size tires are you running up front?
      07-18-2017, 11:24 AM   #3
CFF
Drives: F22 220D
      07-18-2017, 11:25 AM   #4
CFF
Drives: F22 220D
https://www.flickr.com/photos/36296510@N00/35444108242/
      07-18-2017, 10:18 PM   #5
CFF
Drives: F22 220D
No ONE?????
      07-19-2017, 08:39 PM   #6
MrEnthusiast88
Drives: jet black 228i
CFF what is your current offset in the rear? Nice pictures btw
      07-20-2017, 12:30 AM   #7
CFF
Drives: F22 220D
Currently running 18x9.5 ET45
      07-20-2017, 02:42 AM   #8
m3driver999
Drives: 2011 E90 335d
Not sure, but your 265 40 17 has 20.5 mm more sidewall height than stock..and with your ET35 18x9 it would sit 10mm further out than current ET45..and if it is lowered maybe more difficult.. stock is ET58
..also tire..square shoulder?
I am running 17 x 9.5 et35 with 235 40 17..but the RS-RR runs wide...and that has not much margin for poke..
One plus is that when mounted on 9" vs 9.5 you will loose some effective width...but maybe not enough to counter the 10mm further poke..
      07-20-2017, 02:53 AM   #9
CFF
Drives: F22 220D
m3driver999
265/40/18 is just for testing purposes, I am running it for the time being.
would 255/40/18 be better for the 18X9 ET35?
btw the rear camber sits at -2.3
      07-26-2017, 02:03 AM   #10
m3driver999
Originally Posted by CFF View Post
m3driver999
Are you planning any higher performance, or stance?
The 35ET in the rear increased the rear track, while front track stayed same, so handling decreased, more understeer, I found, and also was using 235 rear - ie no traction..!
The 255/40 better matches the 225 45 front tire diameter, almost positive on that.
Also the 265/40 has a more sidewall , looks 'meaty', but more sidewall flex
With coilovers and lowered the 265 40 rubs? or ok? probably has some poke.. if no, then 255 should be even better for no rub. (not sure how much help w/ -2.3camber but should be of help) (255 for sure better than 265 for fitment..less width..less sidewall ht)
235/40f 265/35 rear are good sizes diameter wise,
(not sure 255 40 18 is common? 255 35 more common)
Me currently, 235 40 18 fr 255 35 18 x 9.5 et 58 rear...though going for grip and handling...may go 265 35 18 et 58 for more rear traction..
...also 255 w 9" rim...probably better match to rim...tire bead to rim width fitment
...stance wise..looks...very dependent on rim, ride ht, sidewall proportions..etc.
      07-26-2017, 09:52 AM   #11
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Thanx in advance!!
Should fit.
m3driver999
255/35/18 would be better.
      07-26-2017, 10:00 AM   #12
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Not more understeer. Not a decrease in handling.
Increased stability in the rear is all.
      08-08-2017, 03:44 PM   #13
Lew Carrum
Wales
32
Drives: M 240
Just tried my old z4 wheels and tyres on my 240. Fronts 225/40-18 et35 no problem. Rears 255/40-18 et35 rubbing straight away only drove 10 yards did not fit. Standard wheels going back on tomorrow.
      08-10-2017, 12:57 AM   #14
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Lee
What width offset are the ex z4 rear wheels ?
Rear tire (255/40/18) is too tall -255/35/18 might work better
      08-16-2017, 02:02 AM   #15
Lew Carrum
Wales
32
Drives: M 240
Originally Posted by Bee Pee View Post
Lee
They are 18x8.5" and et35 offset, I have put them up for sale now, I need wheels that are at least et45 on this car. Thanks.
      03-18-2021, 12:02 PM   #16
Zell_F22
Drives: 2014 m235i
Thanx in advance!!
Any pics?
