10-07-2024, 08:11 AM | #23 |
Rep 89
Just wanted to give a quick update after the weekend...
check the rear suspension components but couldn't find anything obvious...did increase the rear tire air pressure to 36psi as suggested by leftoverture and it seemed to help some. I'll need to make time this week and drive back out to the road where the symptom appeared to be pronounced and see. As a side note, I'm really starting to hate these RFTs...was planning to wait till next spring but I'll pbly change the tires out to regular non-RFTs soon. |
10-09-2024, 11:52 AM | #24 |
Rep 385
what exactly did you check when you say you checked the suspension? I'd have the rear of the car in the air and try to twist and pulll on each of the arms and visually inspect the bushings as well.
What mode are you driving in btw? |
10-09-2024, 03:58 PM | #25 | |
Rep 89
I'm usually in sport mode after the car warms up. |
10-09-2024, 04:46 PM | #26 |
Smart Enough to Scan for Codes First
57
Rep 125
Oh....
Run flats? Interesting twist. Id be interested to see if that is playing a part in this or not...what is the age on them??? |
10-10-2024, 09:42 AM | #28 |
Rep 89
10-10-2024, 09:43 AM | #29 |
Rep 89
10-10-2024, 01:20 PM | #30 |
Rep 1,252
Drives: 2015 M235ix
RFTs are a convenient scapegoat for many ills. But they are a blessing when you get to be as old as I am.
10-10-2024, 01:42 PM | #31 |
57
Rep 125
I didnt say it was, i just have experience with older rfts that looked healthy, but turned harder than normal and lost performance quicker than anticipated.
Some people who only drive a couple thousand a year think their tires will last 10 years. I didnt assume it its the smoking gun, just part of the equation that hadnt been defined... and wondered their age. Im no expert beyond old rft arent ideal. Carry on the scientific analysis, interested to hear what you find out! |
10-10-2024, 04:59 PM | #32 |
Rep 5,562
RFT tires are trash and get worse with age. Most tires are degraded by year 3 and start to get slick/hard.
A few questions: 1) What is the car in questions and how long have you owned it? 2) Did this issue pop up with a change to cooler weather? 3) What are your power modifications, if any? 4) When this issue happens, are you driving aggressively? 5) If driving aggressively, are you shifting when in a turn? 6) RWD or xdrive and if RWD, is it equipped with an LSD? FYI, driving aggressively while in a turn and abruptly letting off the gas will often result in the rear end stepping out or the car feeling loose. Same goes for if you're adding power through a turn. When driving aggressively in a turn, you hold your speed or lift slightly or add a tiny bit of braking if you feel the car getting out of control. At the surface, this sounds to me like you may be driving a bit too aggressive for a RWD-biased car assuming you are talking about a real 2 series (i.e., not that front wheel drive crap current gen M235).
10-11-2024, 07:32 AM | #33 |
Rep 10
Hi all. First post!
I just picked up a 2017 F23 MT convertible. I've been experiencing a similar issue. However, in my case, the traction control light comes on when I'm in a sweeper corner, or turning aggressively. It took me a while to realize what was happening, but the stability system is trying to correct and keep the vehicle from going out of control. When this happens, it feels as if the car is sliding on ice, just on the verge of going out of control, but doesn't. It's very un-nerving. If I put the part in Sport + mode, then it drives normal. I'm dropping the car off at my local bimmer shop today. I'm assuming that I have a yaw sensor, or something similar, that's bad. Have you tried to turn off traction control to see if it helps? I'll update with findings. |
10-11-2024, 07:32 AM | #34 |
Rep 701
10-11-2024, 07:36 AM | #35 |
Rep 701
Now that's a very subjective opinion not based on fact. If you don't like RFT's that's understandable, but they are not trash. I've been very happy with mine.
10-11-2024, 08:54 AM | #36 | |
Rep 89
10-11-2024, 08:59 AM | #37 |
Rep 89
The RFTs performed fine (till this recent issue, which may not be the RFTs). I just don't like the ride...my dislike may be due to the fact that I regularly drive on less than ideal road surfaces (potholes, across train tracks, etc). It's been decades since I've had a flat tire so loss in ride comfort doesn't feel worth it to me (knock knock).
10-11-2024, 09:03 AM | #38 | |
Rep 89
10-11-2024, 09:06 AM | #39 | |
Rep 89
BringBackButtons57.00 |
10-11-2024, 12:20 PM | #40 | |
Rep 5,562
They ride worse/harder than a standard tire. They are louder than a standard tire. They wear faster than a standard tire. Did I mention the sidewall blow outs?
10-11-2024, 12:45 PM | #41 | |
Rep 701
10-11-2024, 12:48 PM | #42 | |
Rep 701
10-11-2024, 01:59 PM | #43 | |
57
Rep 125
How it plays out from here to be fixed and get us up to back and running confidently is all i care about! Im an diy mechanic that has had his fair share of upkeep on a much heavier awd platform than the f2x platform, so if i see something I can further provide constructive input on, ill supply. |
10-28-2024, 08:01 PM | #44 | |
Rep 10
Findings
Nothing is wrong with the traction control system. There are two primary issues. The first is that the alignment was out by a degree in both rear wheels. The tow in rear was also out so that both rears were thrusting to one side. Alignment fixed 75% of the problem. HOwever, I still get the TCS light when driving "spirited" in sweepers. But in conditions that should not be producing significant tire slip. So that leads me to my next conclusion, which issue is that the car is on the Pirelli run-flats. This was my original suspicion since I've only had a one set prior, and did not enjoy those. I've reduced air pressure and that bought me a bit more control. I plan on changing, but need to do some more thinking on ideal set: square versus staggard tire set, as I'm just learning this chassis and it's characteristics.... I'm not after looks with wheel/tire, just trying to improve balance and feel. |
