2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack TPMS faults at 49%
      10-17-2016, 06:48 PM   #1
Moondog
Moondog's Avatar
20
Drives: 2015 M235i
2012 135i  [0.00]
TPMS faults at 49%
I just picked up a set of BMW OEM M624 style wheels for my 2015 M235i. When I run the TPMS reset, the percentage complete runs up to 49% then stops and gives me a "TPMS Malfunction" warning. I've researched online and have discovered many possible causes from the tire pressure not being sufficient to active sensors to info regarding a change to the TPMS frequency in late 2014. Anyone else experienced a similar issue?
Live to drive...
E39 2000 528i*
E32 1994 740il*
*retired
Stunad115.50
      10-17-2016, 10:47 PM   #2
Pparana
Drives: 2015 m235i
My guess is one of the sensors is bad, could have them checked, or swap wheels until you find the bad sensor.
      11-13-2016, 08:52 AM   #3
Stunad
Stunad's Avatar
Belgium
116
Drives: Bimmer
I have the same issue after having my tire guy put on winter tires on my rims.
So sensors are still the same but something got messed up.
I did also buy new rims for my summer tire with new sensors which he programmed with a device based on first scanning the sensors on my OEM rims.
Maybe he messed up the sensors by scanning them or damaged them while replacing tires, I dunno.
Did you find out anything yet?
Moondog19.50
      11-13-2016, 10:17 AM   #4
Moondog
Moondog's Avatar
20
Drives: 2015 M235i
2012 135i  [0.00]
Ordered new sensors from the tire rack- less $$$ than OEM - having Goodyear install this week. Will let you know.
Live to drive...
E39 2000 528i*
E32 1994 740il*
*retired
Stunad115.50
      11-13-2016, 11:01 AM   #5
Stunad
Stunad's Avatar
Belgium
116
Drives: Bimmer
Cool thanks.
I'll probably have my dealer check it out tomorrow.
Will let you know as well.
      11-13-2016, 01:02 PM   #6
Moondog
Moondog's Avatar
20
Drives: 2015 M235i
2012 135i  [0.00]
Originally Posted by Stunad View Post
Cool thanks.
A few more details. I took my 2er into Goodyear so they could test the sensors to ensure they were all functioning and all 433mhz (no charge for this test.) Results showed they were the correct frequency but only 2 of the sensors were reading. I ordered two new sensors from tirerack.com knowing the ones they sell are compatible with a '15 F22 (purchased my winter wheel/tire package from them last year.) Had an appointment this past Friday to have the two new sensors installed and they discovered a third sensor was no longer registering. Frustrated and done with screwing around, I ordered two additional sensors and plan to have them all replaced this week. Goodyear gave me a price of $119.00 per wheel for OEM sensors, installed. Tire rack is $54 per sensor (free shipping) + GY install of about $15 per wheel.
Live to drive...
E39 2000 528i*
E32 1994 740il*
*retired
Stunad115.50
      11-14-2016, 05:26 AM   #7
Stunad
Stunad's Avatar
Belgium
116
Drives: Bimmer
My problem has been resolved.
My sensors were ok. Dealer said it was a faulty valve stem on 1 wheel. Replaced the valve, after that everything was ok again.
Was under warranty, so no charge.
Hope you get yours fixed soon too.
      04-24-2017, 08:55 AM   #8
edmundotg
Drives: 2016 228xi M package
I just got a set of BMW OEM 436M wheels with MPSS tires and TPMS from a 2014 M235 but after the TPMS reset I keep getting an error saying there is a malfunction, dealer says sensors are OK but not compatible with my car, is that true?
Of course they wanted to sell me the correct ones for $600.
      04-25-2017, 09:28 AM   #9
moldcad
moldcad's Avatar
Poland
262
Interestingly, although my car never gave any error message, when I reset my sensors the progress stops at exactly 49% for a longer while... A first sign of malfunction?
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive
my AWD beater: 2015 Golf R mk7 DSG
my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD
BM235iW97.00
      04-26-2017, 02:13 PM   #10
crabu2
Drives: Truck and ...
It is highly likely you're being told the truth. BMW did change the senors a few times in different series in the last 10 years.
You can get them from tire rack way cheaper.
'20 240ix convertible
      04-26-2017, 03:52 PM   #11
pz619
Drives: F87 M2C 6MT, Tesla 3
You don't need the $600 sensors. One of mine broke and I had it replace by discount tire for about $20ish.
I had the exact same TMPS malfunction.
      04-27-2017, 12:13 PM   #12
beMtroubleYou
beMtroubleYou's Avatar
67
Drives: M2C '18
2018 M2C  [0.00]
You can check what sensor is not functioning in the hidden menu. It will give you a CC code for the exact sensor.
Like this. You need to sum up your last numbers of your vin and thats your "code".
PS: I am not that guy making the video btw, I just stole his nick sort of.
