09-30-2015, 08:52 AM | #1 |
Bimmer Candidate
92
Rep 308
Ordered my winter tires, but what about TPMS?!
Hey folks,
I ordered my winter tire/wheel package a couple nights ago through TireRack, and when I was checking out on the site, they gave me an add-on option to have them install tire pressure monitoring sensors (TPMS) before they're shipped. I think it costed something like $265, which I opted not to do. But now I'm wondering if I should have. What's the more common thing to do with winter tires: take the TPMS from your summer tires and put them in the winter tires, or buy a separate set and have those in your winter tires? My concern is that transferring TPMS from set to set every winter/summer means take the tires off the wheels (I think) regularly, which isn't good to do. Should I go without TPMS over the winter, buy new TPMS and have my dealer install those in the winter tires, or transfer my TPMS from the summer tires to winter tires and keep trading back and forth? |
09-30-2015, 09:09 AM | #2 |
Rep 3,331
Buy a separate set. Transferring them is not appropriate, you will have to pay ~$160 each time to unmount and remount all 8 tires. The TPMS also has mounting hardware to help properly seal against the wheel and that hardware is meant to be replaced everytime they are removed, otherwise it can leak.
Do not pull them off your summer wheels. Either leave them and don't run TPMS (you will get the error everytime and have no protection if the tires go low) or just spend the money now to buy the TPMS sensors and have them installed.
Current: '20 X5, '18 M3 ZCP
09-30-2015, 09:28 AM | #4 | |
Bimmer Candidate
92
Rep 308
09-30-2015, 09:37 AM | #5 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
When I had my winter setup I just used them without TPMS...you will get a small check light in the dash but in the 135i it was barely noticeable, and you can save yourself $300.
09-30-2015, 10:19 AM | #8 |
Rep 143
Drives: '15 M235i
I'm leaning toward leaving them off for winter tires also. If nothing else, the dash warning is a good reminder to get the winter tires off as soon as possible!
2015 M235i |
09-30-2015, 10:26 AM | #9 |
Bimmer Candidate
92
Rep 308
Interesting. The collective tide has turned since the original answer. Amazing how much your comments can influence my thought process.
As Michael Scott once mused, "Well, well, well. How the turntables........" |
09-30-2015, 10:30 AM | #10 |
Rep 886
Get the TPMS sensors, unless you plan to do all the mounting / unmounting yourself.
The NHTSA is enforcing rules against leaving TPMS sensors out against individual tire shops. reputable ones won't deal with your tires if you don't have them. It's also a foolish economy.
09-30-2015, 12:20 PM | #13 |
Rep 886
One more thing to note. If you're using RunFlat winter tires, running them without TPMS is stupidity on stilts. You likely won't notice if the tire is low on air when you get into the car, and the first sign you have a problem may well be when the sidewall comes apart after extended driving on an uninflated tire.
Seriously, someone who's going to spend ~$1100 dollars to put winter tires on a $45,000+ car is going to kick about an extra $265 one-time charge for the first season? If you're going to do winter tires, do it right.
09-30-2015, 12:21 PM | #14 |
Rep 886
Yes, mounting and balancing is free at TR is you buy the wheels and tires together.
09-30-2015, 12:32 PM | #15 | |
Rep 3,331
Tire shops charge $X to mount and balance a tire. If you have 2 sets of wheels - Summer (A) + Winter (B): If you want to take the TPMS sensors off in the fall: Remove 4 tires from Set A = 4X Remove TPMS from set A Install TPMS and mount tires on Set B = 4X Come spring, you will need to reverse the process Remove tires and TPMS from Set B = 4X Install TPMS and tires on Set A = 4X That means over the course of 1 season you are spending at least 16 X Cost of mounting to switch TPMS. That doesn't include the hardware cost if they rebuild the TPMS gaskets. So if your shop charges $10 a tire (mine charges $20 to mount and balance) you're anywhere from $160-$320++ to swap. Yes, you can save $260 and not run TPMS sensors. But you could also save a lot more by not driving a BMW. TMPS sensors have saved my ass many times - it has nothing to do with being anal about your tire pressures. 2 months ago I left a friends house late at night, and was about to get on the freeway. 2 blocks from the freeway the TPMS alert went on and it turned out I had run over a nail along the way and my rear tire was now completely flat. With low profile tires, and especially if you have RFT's you get very little in the way of indication that the tires are low. I could have easily driven home and gotten stranded on the freeway in the middle of the night but the TPMS made it easy enough for me to turn around, park the car for the night and deal with it in the AM. Personally I like the fact that I can get an exact temperature and pressure readout on every tire in real time rather than trying to check my pressures in the 10 degree weather once a week. You don't need TPMS sensors, we all survived without them for years - but they are nice to have when you do need them, and IMO that's worth what is not a big cost in the grand scheme of owning a $40k+ car.
09-30-2015, 12:40 PM | #16 |
Rep 6,033
DEFINITELY get TPMS.
If I had to, I could/would change a tire on a nice, warm spring or summer day, when my three-season tires were on board. I would hate to be surprised after a day at work with a winter tire flat on a cold, dark night. That alone makes TPMS worthwhile to get an early warning in time to take earlier action. I want TPMS all the time, but if I had to prioritize, most critically in winter!
09-30-2015, 01:09 PM | #17 | |
Rep 1,048
Of course if you're not running TPMS for the winter setup, it doesn't matter. Personally though I wouldn't go without them; but to those who are, I think JB4 allows disabling of the CEL for TPMS Malfunction errors. |
09-30-2015, 01:14 PM | #19 |
Rep 1,048
Also, the "Preferred (winter) Package" for my 2015 M235i on TireRack:
17" Package Tires: Bridgestone Blizzak WS80 Wheels: ALUTEC Grip (4) TPMS Sensors Sub-total: $1,376.00 |
09-30-2015, 01:33 PM | #20 | |
Rep 886
Yes, they mount to the rims, and are not changed when the tires are changed (the valve core seals should be changed at that time, at perhaps $3 per sensor). Expected life of the sensors is 7 - 10 years.
09-30-2015, 01:35 PM | #21 |
Rep 886
09-30-2015, 03:24 PM | #22 | |
Rep 831
The graphite wheels are on back order already and I won't see mine arrive until mid October.
Hoc Lapidem Non Vi Sed Saepe Cadendo!
