2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums Professional Motorsport Racing Discussion (IMSA, DTM, Formula 1, Grand-AM, Le Mans, IRL, WRC, etc..) F1 2022: Canadian GP - Montréal (June 19)
      06-17-2022, 08:49 AM   #89
NYG
NYG's Avatar
Drives: Audi R8
LEC confirmed 10 place grid penalty. 4th turbo installed.
Appreciate 6
irunalot1518.00
GuidoK10852.00
E92inNC1709.50
M5Rick60023.50
      06-17-2022, 09:27 AM   #90
///M Power-Belgium
General
///M Power-Belgium's Avatar
Belgium
63331
Drives: ///M3-E92-DCT Silverstone II
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
Appreciate 6
irunalot1518.00
NYG10728.00
DrFerry6728.50
E92inNC1709.50
M5Rick60023.50
      06-17-2022, 09:38 AM   #91
///M Power-Belgium
General
Belgium
63331
Appreciate 6
NYG10728.00
GuidoK10852.00
DrFerry6728.50
E92inNC1709.50
M5Rick60023.50
      06-17-2022, 10:02 AM   #92
irunalot
Drives: Porsche Carrera S
More information on the rule changes, nice to hear some other drivers other than Merc discuss the new cars. For Alonso to say this is the worst in 20 years says a lot.
Appreciate 5
NYG10728.00
3798j11409.00
DrFerry6728.50
E92inNC1709.50
      06-17-2022, 10:39 AM   #93
scarygary
Drives: M2C
Originally Posted by NYG View Post
Did you guys hear the recent rumors?
Piastri to replace Latifi 2023 at Williams and they're dropping Mercedes engines for Renault.
Hope they leave both the Canadian boys in the country after this weekend lol
Appreciate 5
NYG10728.00
irunalot1518.00
E92inNC1709.50
      06-17-2022, 10:42 AM   #94
scarygary
Drives: M2C
Originally Posted by M3WC View Post
Exactly how I thought this should get addressed.
FIA couldn't just set a minimum ride height, when teams have already spent considerable amount of their budgets on parts specially addressing porpoising.
Agreed. Still think they shouldn't have moved the minimum weight.
NYG10728.00
irunalot1518.00
E92inNC1709.50
      06-17-2022, 11:00 AM   #95
3798j
3798j's Avatar
11409
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
Originally Posted by irunalot View Post
More information on the rule changes...
I'd like to point out the last two videos you've linked (Driver61 & TheRace) are two of the most correct and unbiased F1 information and opinion producers. I subscribe to both and I'm continually impressed by their even and factual delivery....it's nice to see them posted here.
NYG10728.00
irunalot1518.00
      06-17-2022, 11:09 AM   #96
///M Power-Belgium
General
Belgium
63331
Appreciate 6
NYG10728.00
irunalot1518.00
DrFerry6728.50
E92inNC1709.50
M5Rick60023.50
      06-17-2022, 11:15 AM   #97
GuidoK
#buildnotbought
GuidoK's Avatar
10852
Drives: Z4 3.0i ESS TS2+
...there goes my prediction of him winning....
Appreciate 5
NYG10728.00
irunalot1518.00
E92inNC1709.50
M5Rick60023.50
      06-17-2022, 11:25 AM   #98
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
Yep! Perfect rule in my opinion.
It protects drivers and the teams who got their design right.
Merc may argue the TD does not specifically apply to their car issue.
Technical Directive TD039
A metric value is defined as a criterion for the extent of the oscillations. An analysis of how this parameter is determined is ongoing and will continue over the two practice sessions on Friday.
The so-called "Az signal" for the vertical acceleration during the up and down movements is transmitted directly to the FIA ​​control unit. Scrutineers can see at any time how hard the car hits the road at high speeds.
It is still being discussed how the Az signal should be evaluated, whether peak values ​​or average forces should be taken into account. The teams measuring these values ​​for their own setup analysis are invited to share their methodology with the FIA.
The teams still don't know what the rule holders consider an acceptable value. Acceptable value will be determined before 3rd practice.
Test: Teams then need to determine the oscillations over three consecutive laps with DRS disabled at race speed. If there is a suspicion that the driver is deliberately driving slowly, the attempt is considered failed. The same applies when you close the gap on another car.
Once the FIA ​​has determined a "safe set-up" for each individual vehicle, the ride height, spring rates and damper settings, and aerodynamic configuration may no longer be changed. Exceptions include weather changes, adjustments to cooling needs, tire pressures, front wing adjustment.
If a competitor wishes to return to a previously used setup, they must first demonstrate to the FIA ​​that these adjustments meet safety criteria. All parameters such as vehicle height, suspension travel and the aerodynamic configuration must be submitted to the FIA ​​in the voting sheets after the third practice session, together with the corresponding oscillation values.
If a competitor is not able to reach the FIA ​​required limits and thus a safe setup, he must use the setup that is closest to the limits and then increase the rear ground clearance by another ten millimeters without changing the suspension travel or the aerodynamic configuration.
NYG10728.00
irunalot1518.00
M5Rick60023.50
      06-17-2022, 12:02 PM   #99
///M Power-Belgium
General
Belgium
63331
They discovered it Wednesday at Marinello that Charlie's PU was completely lost ..
But Ferrari is still groping in the dark what the cause of the blown PU and Turbo was ..
This means that another blue smoke moment can happen at any time !
Appreciate 4
NYG10728.00
irunalot1518.00
DrFerry6728.50
M5Rick60023.50
      06-17-2022, 12:15 PM   #100
///M Power-Belgium
General
Belgium
63331
Appreciate 4
NYG10728.00
irunalot1518.00
DrFerry6728.50
M5Rick60023.50
      06-17-2022, 12:52 PM   #101
NYG
NYG's Avatar
Drives: Audi R8
Who's watching FP1
Appreciate 6
irunalot1518.00
3798j11409.00
DrFerry6728.50
GuidoK10852.00
M5Rick60023.50
      06-17-2022, 01:10 PM   #102
NYG
NYG's Avatar
Drives: Audi R8
Max is a f'ing rocket right now.
DrFerry6728.50
M5Rick60023.50
      06-17-2022, 01:11 PM   #103
///M Power-Belgium
General
Belgium
63331
Who's watching FP1
NYG10728.00
DrFerry6728.50
M5Rick60023.50
      06-17-2022, 01:14 PM   #104
irunalot
Who's watching FP1
Thanks for the reminder I totally forgot about it.
Appreciate 4
NYG10728.00
DrFerry6728.50
M5Rick60023.50
      06-17-2022, 01:22 PM   #105
irunalot
Those two channels are great, and have some really good content. Try Peter Windsor as well he always has some good information, and although he is a Ham fan he gives him a hard time when needed.
NYG10728.00
M5Rick60023.50
      06-17-2022, 01:32 PM   #106
NYG
NYG's Avatar
Drives: Audi R8
Part of Max's strength is understanding the components of his car. He immediately diagnosed the front roll bar over a curb. I don't think a lot of drivers know their cars as well as he does.
Appreciate 4
Todd0131379.50
irunalot1518.00
DrFerry6728.50
M5Rick60023.50
      06-17-2022, 01:50 PM   #107
///M Power-Belgium
General
Belgium
63331
Appreciate 4
DrFerry6728.50
NYG10728.00
irunalot1518.00
M5Rick60023.50
      06-17-2022, 01:53 PM   #108
GuidoK
#buildnotbought
GuidoK's Avatar
10852
Where do those beavers come from?
(or whatever kind of critters they are?)
I wonder if one will be a deciding factor on sunday....
NYG10728.00
irunalot1518.00
      06-17-2022, 02:06 PM   #109
GuidoK
#buildnotbought
GuidoK's Avatar
10852
Longrun from VER looked very good.
He's gonna win.
My new prediction:
1.VER
2.PER
3.LEC
4.SAI
(rest unchanged)
NYG10728.00
irunalot1518.00
M5Rick60023.50
      06-17-2022, 02:09 PM   #110
NYG
NYG's Avatar
Drives: Audi R8
He's gonna win.
My new prediction:
1.VER
2.PER
3.LEC
4.SAI
(rest unchanged)
Ouch, you think LEC is going to gap Carlos after starting that far back?
M5Rick60023.50
