06-09-2022, 02:51 PM | #1 |
Rep 558
Flash ECU to replace A/T shift lever?
TIA for anyone that can shed light on this for me.
Background: My ECU is MHD flashed and TCU is xHP flashed. I have a 3rd party extended warranty, purchased from my BMW dealer. The LED lights on my A/T shifter stopped working. The dealer would replace the shifter under warranty. Dilemma: However, they know the car is flashed and said that to replace the shifter, they'd have to update the software version on the car, which would re-flash and lock the ECU. And, because it's the latest software, I wouldn't be able to re-flash the MHD ECU software. So, they gave me a choice. I told them to wait and I'll bring it back to them after MHD cracks the new software. Question: Do they really have to update the software to replace the shifter? It's just an electronic joystick. Isn't the replacement "plug-n-play"? Or, do they actually need to "code" it for the car?
06-09-2022, 05:08 PM | #3 | |
Rep 558
I hope MHD cracks the new software before my extended warranty expires.
06-10-2022, 05:58 PM | #4 |
Rep 558
I email MHD to see if they had any news about unlocking the latest BMW software. Unfortunately, they didn't. However they did a a suggestion I thought was worth posting, in case it might help someone else.
They responded: "If BMW updates your software, you will need Bench Unlock. we recommend hiring indy/shop to program/code only GWS. you can check with https://www.bimecu.com, they can do it even remotely"
