07-06-2022, 04:57 PM | #4621 |
Rep 77
Installed a long time project. DIY OLED info screen. It integrates to cluster powered state and infotainment brightness so it matches nicely what other digital elements of the car are doing. It sniffs PT-CAN (coolant temp, oil temp and so on) and is also able to request a bunch of data from the OBD interface (boost, fuel pressure, oil pressure etc).
The case is 3D printed. The controller is a Teensy 3.2, located near the GWS unit.
Previous cars: E90 320ix, F30 320ix, E89 Z4 35i
dradernh4391.00 MLJR235116.50 zoro200122.50 PeanuKeeyes365.50 Cos270608.50 ggggbmw432.50 SW111282.00 freakystyly2983.50 M_Postr37.50 hlm2c289.50 |
07-06-2022, 06:02 PM | #4622 | |
Rep 243
'15 235i - Moddedededed
07-06-2022, 06:14 PM | #4623 | |
I like biscuits
164
Rep 250
SW111282.00 |
07-07-2022, 03:07 AM | #4624 |
Rep 77
I'll probably make a thread about this in the DIY section one day. I am thinking about making a proper PCB for this to sell as a kit for other DIYers. That would make it much easier for others to replicate this setup.
07-08-2022, 03:27 PM | #4626 | |
Rep 43
07-09-2022, 12:32 AM | #4627 |
Rep 43
Installed a FTP Charge Pipe… Have a feeling the lower connection is not properly fitted. Also saw some type of slight oily residue in the OEM one that was removed. Is this normal?
07-09-2022, 12:42 PM | #4628 |
I like biscuits
164
Rep 250
What makes you think the lower part isnt fully connected? There is a 'Locking tang' that has to fit in the corresponding notch on the IC. Did you make sure those were lined up? Some oil residue is normal as apparently Turbo BMW's are bad with blow-by.
07-09-2022, 01:55 PM | #4629 | |
Rep 43
I also just replaced my Fuel Tank Breather Valve because i had a P0446 code and my car would do that hesitation idle after filling up with gas |
07-10-2022, 02:48 PM | #4630 |
Rep 28
Another install of the MN Lasercutting wheel button kit.
Being able to change the drive modes without removing a hand from the wheel is slick. I'm not crazy about the blue buttons, but it appears that with a slight modification to the stock blanks, they could easily be turned into functional buttons for a total incognito look. That may be my next step for this project... |
07-11-2022, 06:14 PM | #4631 |
Rep 3,496
I put gas in the car. Prices have gone up a fair amount since I last bought gas on 10 April.
GasBuddy shows that Shell V-Power is running between $5.15 and $6.00 in the Cincinnati region. Topping my tank up with a bit under 12 gallons cost $66.40. Yikes!
07-11-2022, 06:24 PM | #4632 |
I like biscuits
164
Rep 250
I feel that, just spent $55 for 11.091 gallons here in Texas for 93. About $4.95/gal. Ouch, indeed-this is my only daily. Good thing I have a short commute to work! Get about 3-5 days on a tank depending on my behavior.
07-11-2022, 07:41 PM | #4633 | |
Rep 3,496
Bottom line: the world has changed. As an optimist, I continue to believe that it changes, in fits and starts, for the better.
lateapex'er123.00 |
07-11-2022, 09:00 PM | #4634 |
Rep 536
Old guy as well. Remember rolling pennies to buy gas in High School.
Got my M240 in November 20, first fill up was $2.53 / G First fill up in 21 was 2.79/G mid 21 was $3.45/G. First fill in 22 was $3.55/G by March 22 it was $4.35/G it peaked at $5.25/ in mid June and went down to $5.19/g first of July. Same gas at the same station. |
07-12-2022, 12:34 AM | #4636 |
3621
Rep 3,590
Getting pricey for fuel these days for a track day. 290km trailering the car to the track I most commonly go to, 300km around the track and 290km back again consumes 150 litres of Shell 91, currently costing CAD$2.29 per litre. A total fuel bill of $350 (USD$270) compared with the track day cost of around $250.
07-12-2022, 11:38 AM | #4637 | |
Rep 1,182
The prices are about the same here in MN for Shell V power. I think I have paid about 5.50 per gallon for 93 octane. I also put in a couple gallons of E85 into each fill up. But....I have to go like 8 miles in the opposite direction of the shell station to get E85, put some in a gas can, trek over to the shell station, pour the gas can in my car, then top off with 93 octane. Did this yesterday and it was a 45 minute project from leaving until I got home. My wife doesn't get it and she won't give me the time to explain why I'm doing it. It is a bit silly when you think about it.
2024 M2
2019 M240i- Sold |
07-12-2022, 01:46 PM | #4638 | |
Rep 3,496
Is buying a barrel of E85 and keeping it at home an option for you?
07-12-2022, 03:12 PM | #4639 | |
Rep 1,182
I should get a barrel of E85. I need to find a gas station that has both E85 and 93 octane at the same pump so there is only 1 stop. But shell v power is supposed to be the best. In the colder months I will tune down to a less aggressive map and won't be using any ethanol so this is really only a summer months logistical pain.
2024 M2
2019 M240i- Sold |
07-12-2022, 05:45 PM | #4640 |
Rep 3,496
I finally got around to installing the Dinan CAI I bought in 2019.
07-12-2022, 07:14 PM | #4641 |
Rep 913
I grazed my knuckles installing mine back in 2018, but I like it.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
dradernh4391.00 |
