05-30-2018, 09:17 PM | #749 |
Rep 2,476
I recently tried the pan route. So far, my best method was to hold it with tongs and sear the edges first, then lay it flat to cook. Turned out really, really good.
05-30-2018, 09:46 PM | #753 |
Rep 700
Seasonings are all up to personal preference.
I have craycort cast iron grates for my Webber charcoal grill. Once the charcoal is ready I load it in the charcoal baskets and keep it to one side of my grill. Open the vents all the way and close the grill and let the grill get hot for about 10 min. Sear each side 3min. Then move the steaks to the opposite side and insert a probe into one of the steaks. I set my probe to 125* and take them out and cover for 10min. Within those 10min it will raises about 10*. |
05-30-2018, 11:13 PM | #754 |
Rep 1,024
Season with salt and Penzey's Chicago Steak.
Sear over hardwood lump charcoal - couple minutes each side diagonal to grill, rotate and repeat to get the nice grill patterns Move to indirect heat and cover until Med-rare. I've tried cast iron and sous vide and will use either in a pinch when winter sundown makes it inconvenient to grill, but can't really beat cooking it over fire. |
floridaorange10175.00 |
05-30-2018, 11:35 PM | #755 |
"Salud"
13892
Rep 4,680
Drives: F01 & F15 / Mineral White
On some type of open flame grill.... Period.
AlpineWhite_SJ1578.00 |
05-31-2018, 06:03 AM | #756 |
Rep 469
Filet, let sit on counter for 30 min before cooking. Salt and pepper, lots. Cast iron pan on grill to 600-700 deg, add grape seed oil then steaks for 2-4 min per side depending on steak, pull, add a good amount of truffle butter (the good kind, I get mine in CA from an online shop) to top, cover loosely with AL foil for 5 min so to rest. Amazing. Been told by numerous people that best steak they’ve ever had.
05-31-2018, 06:06 AM | #757 |
Rep 4,821
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
Banana Hammock3769.00 |
05-31-2018, 06:48 AM | #759 | |
Rep 1,395
Drives: Porsche 993, 2014 MB GLK
MightyMouseTech4337.50 |
05-31-2018, 07:07 AM | #760 |
Rep 1,118
Aged porterhouse cut to 2 1/2” thick.
Sit until room temperature, rub with a bit of olive oil then season with your preferred rub just prior to grilling. On charcoal, BBQ lid open sear for 5 minutes each side. Stand up, bone down for 15 minutes, check with thermometer, Center 125, with lid closed, adjust charcoal height accordingly, then yank it, sit for at least 5. I have my own rub that makes it to perfection... http://www.m3post.com/forums/attachm...1&d=1519336807 Last edited by TomHudson; 05-31-2018 at 07:14 AM.. |
05-31-2018, 10:52 AM | #761 | |
3587
Rep 10,356
Thinner cuts I pan-fry and finish by basting melted butter/garlic/fresh herb (tyme, rosemary, etc).
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
thetastelingers4170.50 |
05-31-2018, 11:09 AM | #762 |
Rep 155
Drives: E92 M3
I'd like to try reverse sear at some point. I think Sous vide is out for me. Seems like a lot of work. I usually come from work and throw something on the grill to feed the wife and kid.
05-31-2018, 11:12 AM | #763 |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
ducasse method.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
06-01-2018, 06:48 AM | #765 |
Rep 4,821
I have a smoker in which I use lump charcoal and wood for slow cooking. But for fast cooking like steaks, burgers, chicken breasts, etc., it is hard to beat the convenience of propane. Cooking on charcoal is great but doing it correctly takes time.
06-01-2018, 12:26 PM | #767 |
Beefcake
3769
Rep 711
That is very true. Charcoal is a bit of work but I can taste the propane on the food when I cook with it.
06-01-2018, 12:29 PM | #768 | |
Rep 6,196
Take steak out of fridge, apply salt, put in oven at 200F. At 200F, it is about 45 min/inch. Then you have a full 45 min or an hour to do everything else for dinner, clean up etc etc etc. When done in the oven, pull it out, sprinkle with seasoning, then either in a really hot pan or BBQ for 30s a side. Serve immediately. Nearly impossible to overcook as well, there is a lot of leeway in how long it stays in the oven, and if you like rare, it can be completely rare from edge to edge. None of this rare in only the middle half, or rare with a cold center. |
06-01-2018, 12:42 PM | #769 | |
Rep 4,821
06-01-2018, 12:45 PM | #770 |
Beefcake
3769
Rep 711
Lighter fluid on charcoal should be punishable by death.
RickFLM410981.00 MightyMouseTech4337.50 Red Bread4463.00 AlpineWhite_SJ1578.00 MKSixer34184.50 bbbbmw2393.50 |
