04-16-2020, 06:28 PM | #1 |
Rep 6
Crankcase vent pipe leaking
Hello All,
2015 M235 is getting its 60k service today. I just received the following Email from the shop: There is an oil leak from the crankcase ventilation pipe and it has contaminated some of the cooling system hoses. My recommendation is to replace the faulty vent pipe, replace the affected coolant hoses and perform a cooling system flush. I did a search and couldn’t find any info on this. What are your thoughts? |
04-16-2020, 09:13 PM | #2 |
Driver - Autocross
74
Rep 178
The crankcase vent house runs along the top of the valve cover i believe(correct me if i'm wrong) ...Not sure how that would get mixed in with the coolant...Did they maybe say that some oil leaked out of there onto some coolant pipes? Maybe it doesn't even need a coolant flush... I'll let other members chime in here though.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
