04-16-2020, 11:44 AM | #1 |
Rep 12
Should I use cooler spark plugs on BM3 Stage 2?
I have a '16 Auto RWD with AFE drop in filter, Evolution Racewerks CP, Intercooler, TIC, Active Autowerks Catted Downpipe and just got my BM3 license for a Stage 2 tune. Will be having a custom tune done in the future but going go off the shelf for now. Should I be changing my spark plugs?
Logging also seems pretty important, do I need to setup my logs or is everything logged automatically? I have OBD Wifi agent.
‘16 Estoril Blue M235i - Auto RWD - M Performance: Exhaust, LSD - Evolution Racewerks: CP, FMIC, TIC - MST: Air Intake
Mods waiting to be installed : Active Autowerke Catted DP - BM3 Stg2 OTC |
04-16-2020, 08:50 PM | #2 |
Driver - Autocross
74
Rep 178
NGK reccomends that anytime you add 70 to 100hp you should go one step colder on your heat range. I'm currently FBO on my stage 2+ M235i and i run the NGK SILZKBR8 plugs found in the S55. They are one step colder. Depending on how high you're going with boost( Say you get a custom tune) I would say go two steps colder. The N26 engine plugs.
depending on how many Miles are on your plugs i would change them. I had 50,xxxKM on my stock plugs and they were fine. Switched them out for just recently to those NGK, Probably go 2 steps next change.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
04-17-2020, 08:36 AM | #3 |
Rep 699
The trick with a boosted engine is you want the hottest plug appropriate for the compression/boost you're running. Not the "coldest"...
What I mean is to say that just because you've bumped your boost a few PSI and one step "colder" plug helps prevent "pre-ignition" (knock), it does not mean that a two-step colder plug will work better... And again, it's all in the scans, you can play with temp rating and gap to find the sweet spot! Good luck! |
04-22-2020, 10:56 AM | #4 |
Rep 190,150
I always upgrade my spark plugs when getting my car tuned
04-23-2020, 10:42 AM | #5 |
Rep 12
What do you recommend or should I wait until I have logged some pulls? What should I check in the logs to get an idea of how things are doing?
04-23-2020, 11:30 AM | #6 | |
Rep 190,150
Check for misfires
