2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning JB4 MAP 6
      04-15-2020, 06:08 PM   #1
OneslowM235
Drives: BMW M235I
JB4 MAP 6
Hello everyone,
I have a 16 M235I 6MT
I did some logs on MAP 5 and also messed around with MAP 6 settings and logged the car as well. Does anything look off?
MAP 5 LOG 1
https://docs.google.com/spreadsheets...it?usp=sharing
MAP 5 LOG 2
MAP 6 LOG
MAP 6 SETTINGS ATTACHED
The car runs fine but sometimes it will throw the below codes (usually top of 3rd gear), car still drives normal no changes when codes appear.
102A22 MAF, air mass too high
104302 Absolute pressure sensor, intake manifold, plausibility, caster: pressure too low
104301 Absolute pressure sensor, intake manifold, plausibility, caster: pressure too high
I am new to all the numbers and was wondering if someone can point me the right way.
Mods on the car:
VRSF CHARGE PIPE
VRSF DOWNPIPE
MUFFLER DELETE
EWG CONNECTOR
JB4
STOCK INTAKE
STOCK FMIC (WILL UPGRADE TO VRSF HD FMIC)
10 GAL of Shell 93 / 3.5 GAL of E-85 (Tested)
Thank you
      04-15-2020, 11:43 PM   #2
The_otherM235i
Driver - Autocross
The_otherM235i's Avatar
Drives: BMW M235i
Sounds like your iat temps are getting so high the dme is not only pulling timing but sending codes for air mass to high. Car will go into limo mode and flash an engine malfunction if it gets even hotter. Get yourself an intercooler and for the time being dial back your tune.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
      04-16-2020, 10:53 AM   #3
OneslowM235
Drives: BMW M235I
okay sounds good, for now ill switch back to MAP 5 until i install the intercooler. Would you know if you can change fuel trims with the JB4?
      04-16-2020, 10:55 AM   #4
The_otherM235i
Driver - Autocross
Drives: BMW M235i
I'm not entirely sure as I'm team MHD, I believe any OTS tune can't be modified unless you're a WiZaRD. And even then I wouldn't do that. What kind of intercooler are you going with?
      04-16-2020, 11:23 AM   #5
OneslowM235
Drives: BMW M235I
i see.. i wanted to go with BM3/MHD but i decided to purchase an extended factory warranty from BMW since i purchased the car with 70k miles.. I know with JB4 you can set to MAP 0 and they can still cover the car without any issues. I was looking at purchasing https://www.vr-speed.com/vrsf-interc...i-n20-n55.html
I heard good reviews about it and the price seems fair.
      04-16-2020, 11:25 AM   #6
The_otherM235i
Driver - Autocross
Drives: BMW M235i
i see.. i wanted to go with BM3/MHD but i decided to purchase an extended factory warranty from BMW since i purchased the car with 70k miles.. I know with JB4 you can set to MAP 0 and they can still cover the car without any issues. I was looking at purchasing https://www.vr-speed.com/vrsf-intercooler-fmic-upgrade-kit-12-16-f20-f30-228i-m235i-328i-335i-428i-435i-n20-n55.html
VRSF sells some great stuff, that Intercooler should work great. My buddy just had his new 7" VRSF intercooler put on and it's beastly.
      04-16-2020, 12:23 PM   #7
OneslowM235
Drives: BMW M235I
sounds good. Ill post more logs after install. Im going to pull the trigger and buy it today. Hopefully they can ship it out asap with everything going on...
      04-16-2020, 12:35 PM   #8
The_otherM235i
Driver - Autocross
Drives: BMW M235i
I got my Wagner EVO II intercooler In one week when i ordered from ECS Tuning. Great team they got there!
      04-17-2020, 12:07 PM   #9
OneslowM235
Drives: BMW M235I
VRSF did a good job as well. They sent me the tracking number and the Intercooler will be arriving on Monday!
      04-17-2020, 12:56 PM   #10
The_otherM235i
Driver - Autocross
Drives: BMW M235i
Fantastic! It's gonna make a world of difference, post about it once it comes in!
      04-21-2020, 05:25 PM   #11
OneslowM235
Drives: BMW M235I
log after IC install. I used the same fuel as my previous logs...
NO CEL light btw..
      04-21-2020, 05:27 PM   #12
The_otherM235i
Driver - Autocross
Drives: BMW M235i
NO CEL light btw..
https://docs.google.com/spreadsheets/d/1pSo-VFws82TiMKy2_QzQOtU1UpG4fQSisxBOf6Ic7Jk/edit?usp=sharing
Can you datazap it for me?
      04-21-2020, 05:36 PM   #13
OneslowM235
Drives: BMW M235I
Let me know if that works.. first time using Datazap lol..
https://datazap.me/u/oneslowm235i/ma...25-26-27-28-29
      04-21-2020, 05:43 PM   #14
The_otherM235i
Driver - Autocross
Drives: BMW M235i
So you just logged one third gear pull? Can't tell to much off that log but from what i can tell it looks good, little bit of boost creep over a few hundred RPM's but that's fine. Your boost was right under your target through the entire gear, can't seem to see if you have any timing corrections but for the most part that looks good.
Try logging a 2 to 7th pull on the highway or something.
can you tell me your mods and fuel used for these pulls?
      04-21-2020, 05:47 PM   #15
OneslowM235
Drives: BMW M235I
yea i installed it quickly and had to return to work lol... I will do more logs later tonight. I have a 6MT it was 3rd gear pull. The fuel used 10 GAL of Shell 93 / 3.5 GAL of E-85 (Tested)
      04-21-2020, 05:48 PM   #16
The_otherM235i
Driver - Autocross
Drives: BMW M235i
Lucky you have E85. Yeah longer pulls will be better for me to read, lmk when you get a good pull in
      04-22-2020, 05:43 PM   #17
OneslowM235
Drives: BMW M235I
this a log i did with 4 gal of E-85 and the rest 93.
2/3/4th gear.
https://datazap.me/u/oneslowm235i/ma...-29&solo=20-27
      04-22-2020, 05:50 PM   #18
The_otherM235i
Driver - Autocross
Drives: BMW M235i
2/3/4th gear.
your boost is kinda slow to hit it's target but i can't see that being a problem as your boost stays pretty consistent with it's target all the way through.
hows the car drive?
      04-22-2020, 06:17 PM   #19
OneslowM235
Drives: BMW M235I
hows the car drive?
Is there any options I can change to hit the target? The car feels great I was cooking during those pulls 2nd gear it was a little squirrelly 3rd gear pulled really good, 4th gear I hit around 140..and let off.
Can you send me one of your logs so I can see how yours look like?
      04-22-2020, 06:19 PM   #20
The_otherM235i
Driver - Autocross
Drives: BMW M235i
hows the car drive?
Yeah sure, I'll go record one tonight. I Alsace the auto 8 speed AWD but it should be good.
