FS: 2020 M2 Competition suspension as new, switch out at 9 miles. |
09-09-2019, 01:41 PM | #2 |
Rep 2,108
That's a very good deal, goodluck with the sale!
I'd be interested in the stock M2C brake kit if you are considering selling those.
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
omasou2089.00 |
09-10-2019, 08:57 AM | #4 |
Rep 3,006
I would expect these to work fine on a 2 series. You may need to use realoem.com to confirm any additional parts needed, e.g. gaskets, bolts, etc. Try contacting Brain at Sun Motors BMW, he can provide you a comprehensive list of additional parts that you should purchase.
Though my car only had 9 miles, I purchased and replaced the following from Brian... 2 x 33 50 6 866 038 gasket 2 x 31 30 7 854 446 gasket 10 x 31 30 7 855 400 hexagon screw with flange M8X33 10.9 ZNS3 4 x 33 32 6 768 884 hexagon nut with collar M10-10 ZNS3 2 x 33 32 6 760 668 nut, self-locking collar M12X1,5-10 ZNS3 1 x 34 33 9 806 226 nut, self-locking M14X1,5-05 ZNS3 2 x 07 11 9 905 418 hex bolt with washer M10X80-U1-10.9 2 x 07 11 9 905 610 hex bolt with washer M12X125-10 ZNS3 2 x 33 52 7 850 600 12-point nut M14X1,5 ZNNIVSI |
09-11-2019, 10:26 PM | #5 | |
Rep 555
The M2 uses the M3/M4 suspension, and subframes IIRC, which means that shocks/springs are not going to be transferable to any F22... at least not easily....
09-12-2019, 12:31 PM | #7 |
Rep 3,006
It appears that some folk are swapping M3/M4 suspension part on to F2x/F3x cars.
https://f30.bimmerpost.com/forums/sh....php?t=1090804 The only references I have found related to shock and springs showing cross fitment are... https://mtstechnik.com/en/products/c...upe-28435.html https://www.bimmerworld.com/Suspensi...amper-Set.html Looking at realoem the 1, 2 and 3 series do share a lot parts. You'd need to figure out how many and if it's worth it. Last edited by omasou; 09-12-2019 at 12:37 PM.. |
09-13-2019, 08:37 PM | #8 | |
Rep 555
12-14-2019, 07:13 PM | #9 |
Rep 176
Im assuming this should fit on a 2016 M2 just fine? I have 50k miles. This might be a nice refresh for tired shocks, etc. Wondering if will fit directly or require any modifications.
Also, still for sale? |
12-18-2019, 08:31 PM | #11 |
Rep 555
Yes it should pretty much fit older M2s no problem. Outside of some suspension tuning here and there, I do not believe there were any drastic changes in how things are mounted.
