12-28-2023, 04:32 PM | #507 |
Rep 1,498
12-29-2023, 02:49 PM | #509 | |
Rep 9
I've installed a ton of front & rear main seals with such method and similar. I've never had one leak after. I actually use a caliper and measure the depth all around to make sure it's evenly tapped in. I'm sure you, like most of us, used this method at some point as well when in need. Is it better and more precise with a proper tool? Absolutely, but those tools are everything but affordable and specific to one engine, and since I'm not an active shop, it'd probably be a one-time use which makes it not worth it. However, I do buy such tools when they are not grossly overpriced and I know I'll use them, like the rear main seal tool for the M54. Regarding the measurements, you have to remember that I took apart a good working engine that didn't need to be rebuilt in the first place. I didn't mix the crank or the bedplate or the block. I didn't reuse a different crank like you said. I did make all the necessary measurements to make sure it was good to be put back together. I measured the crankshaft, all perfect and within spec. I purposely didn't want to have it polished as it was in perfect condition and I don't trust machine shops which, given my track record with them, you can probably understand. For the mains, I ordered one upper and lower new G bearing (stamped on the block and the crank) from the dealer and measured and compared with King Race main bearings, and they were within tolerance. King Race bearings come in one size, so this plus plastigauge is more than sufficient to know you are safe to use them. If I were mixing and matching a different crank/bedplate/block, then for sure, proper measurements with tools are highly recommendable, but this wasn't my case. With the rod bearings and BE bearings, there's really no point in doing anything if the rod journals measure within given spec which they did. I measured the block myself and so did the machine shop after honing. Weigh and balance for what reason? I reused all good parts from the same engine that was assembled by the factory. The only new component was the Mahle MS pistons which I did weigh, and they are the same weight or within 1 gram compared to the stock pistons. Nothing to be unbalanced. How did I not pressurize the oil system? I cranked the engine without fuel or ignition for a lot longer than what I showed on the video, to the point that the battery actually got weak. The cylinder heads were overhauled by a machine shop that I trust and specializes in this area. Besides a standard head overhaul, they ported the exhaust side and done a multi angle valve job. It's not something I can do myself. I asked if they could record the process, but given how busy they are, they couldn't and it was too far to drive there myself and film. I later installed Schrick titanium retainers, springs and keepers. It's actually pretty easy and I've done it many times. This makes you sound like you've never done it yourself if you think that's difficult. Double sealing the O-rings — it's not a paste. Reinzoplast is a permanently liquid sealing compound, high viscosity, for highly stressed sealing joints. Operating temp ranging from -50°C to 250°C. It cannot cause any problems if you later need to replace the O-rings again, you simply wipe it off. It's not like standard RTV where excess silicone can end up in your oil pickup. On Alpina, I had a brand-new oil cooler, brand-new O-rings and the connection would leak despite replacing it twice, all correctly installed without damaging the O-rings. I then used a bit of Reinzoplast and it sealed immediately. Look it up, it is a wonderful invention and something you'll want to have in your tool chest. In my opinion, it's a brilliant idea to use it on the weak points of the ultimate oil leaking machine. We all know, despite everything being brand new, it doesn't take long for them to develop an oil leak. I also see you are banging around about torque plate not being used when honing the block. Okay, it is a topic where opinions will be divided, but you must know that it's not necessary to use one on a street engine. H2Motors has honed hundreds of these blocks without using one and they all run without any issues. The honing guy drives his engine on the Nürburgring regularly. You also said how H2Motors is assembling the engine properly, unlike me, which makes me question your experience and knowledge among other things you are writing, but whatever. If you actually saw their S65 assembly video, like you claim, you'd see that they do it differently and don't always follow TIS in order to save time. By your standards this should be heavily wrong as many steps are skipped, and yet you said you'd let them assemble your engine?! In reality, it's not wrong, it just a different approach where their engine builder manages to save time and still build it successfully. If we are being realistic, you are just purposely nitpicking and there are no big NO NOs here. By no means am I saying I'm flawless. I'm self-taught and have no professional training or experience. I've done everything I could within my means and knowledge to build a good engine that will last. I don't cut corners and I always try to do everything as correctly as I can. You say this wasn't a proper or correct engine rebuild. Fine, your opinion and I wholeheartedly disagree. There are far worse engine rebuilds done by professional shops, where everything is torqued with an impact and nothing is measured. Since you didn't see the Alpina series, that was my first engine rebuild, and unlike most of us here, I've done that with the whole world watching. In short, the machine shop that sleeved the block got the wrong piston-to-wall clearance. Alpina pistons are forged alloy which expand more than standard BMW pistons. Having not known better back then, I trusted that the machine shop knew what they were doing and assembled it like that, only to watch it die after 100 km as the rear pistons #4 & #8 expanded and naturally destroyed the cylinders. That was my first biggest learning experience that cost me dearly as I lost all that money and time putting that engine together. The machine shop never reimbursed me for the damages. But, from mistakes we learn and I acquired invaluable knowledge from that, and the 2nd engine that I built for that car was successful, without involving machine shops. That's the experience I'll never forget and one I promised myself never to let happen again. No, I don't do this to maximize YT views and engagement, and you shouldn't just assume something like that after briefly watching a couple of videos. I started off from literally nothing, I didn't know how to change the oil when I bought my first car. When I moved to Germany, I worked with cheap tools that were in the plastic box in the back of my M5. I worked in parking lots, driveways and even got poisoning after changing the front struts on my M5 in an underground parking lot while having "friendly" neighbors nagging all the time. I hold a college degree in computer science and after YT thing took off out of nowhere, I managed to quit my day job and get to where I am today. I wake up smiling and make a living by doing something that I Iove. That's something we all strive for. You see 99% positive comments because 99% of them are genuinely positive from the people who follow the channel. I don't understand how something like that can make you sad. That's a bit weird and concerning. There's a small number of offensive and hateful comments too that only I get to see cause YT algorithm blocks them. Stuff where people swear and threaten me for no apparent reason, stuff that no one wants to see, but such is the world we live in. I assume that people enjoy watching cause I fix things the right way (as much as I can), and restore cars back to their original condition while having fun and goofing around. They learn something and I don't try to bullshit them or sell them VPNs, hair products and other stuff that most channels have to do in order to survive. I strictly work only with companies that relate to what I do, that help me restore cars and have products I can stand behind. With YT revenue, Patreon and selling some of the cars in the end, I'm fortunate to be able to stay true to what I believe. I can't imagine bringing myself to filming an ad spot for say a ball shaving product. But again, not everyone is able to do that. I learned a long time ago it's impossible to please everyone, YT is simply too big and it's easy for people to hide behind the keyboard, get angry and carried away over nothing. I hope I added some clarity for you since you made some ill assumptions. Thanks for watching the video. Cheers! Last edited by Sreten; 12-30-2023 at 02:26 PM.. |
14
PixelVogue28.00 wyshyvanuk462.00 B58 parts484.00 Almuliman511.50 Mani5913596.00 celsdogg329.00 CSBM52756.00 murderspice697.50 0-60Motorsports793.50 DubaiRich127.50 KevinC3173.00 Bruuuce349.00 Malteser_wfj48.50 sergbaja5t61.50 |
12-29-2023, 02:57 PM | #510 |
Rep 264
@Sreten you will get the haters and the so called mechanics everywhere who you everything and do nothing!
If I see Carvertical on your channel...keyboard warrior mode ON Thanks for the vids, keep up the good work! |
Mani5913596.00 |
12-29-2023, 03:59 PM | #511 |
Rep 641
Sreten great detailed response! 99.99% of us admire your work and your entertaining videos! Keep up the great work (and more V10 sounds like in your last video!
12-29-2023, 04:16 PM | #512 |
Rep 8,185
It's Zn or Fe and 5g per piece so not that much on older alloy wheel and a heavy tyre...
12-31-2023, 11:27 AM | #514 | |
Rep 3,994
Sreten, keep doing you, alot of people enjoy what you do and bring to the community.
Lets see him create a video of his claimed S85s builds from end to end so we can pick apart also, I doubt he ever will.
DrFerry6731.50 |
12-31-2023, 02:43 PM | #515 |
Rep 175
12-31-2023, 03:56 PM | #516 | |
Rep 3,217
Jbrown74032654.00 |
01-02-2024, 02:57 PM | #518 |
E4 Mafia
329
Rep 418
I can hear the inflection in your voice as I read this, haha
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k) | '04 E46 330xi MT (198k) | '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
01-02-2024, 03:13 PM | #519 |
Rep 8,185
As I was perusing ISTA to find repair manuals for my car, I thought that it's wild how much free (but illegal) information there is for us enthusiasts from BMW AG. Sure, one can pay a lot of money to access official ETK and TIS, but my and everyone else's software is really just pirated from somewhere in Russia... as are realOEM and all the other online versions of BMW ETK which was unfortunately pulled from BMW.de in 2020.
There's not a lot of brands around with this much free knowledge. Where else would Sreten and us here find torque sequences for the valve covers? One of the reasons BMW is an enthusiast brand. Let's hope it stays that way.
tdott3956.00 |
01-07-2024, 06:52 PM | #521 | |
Rep 264
B58 parts484.00 |
01-08-2024, 02:23 PM | #523 |
BMW Miniature Collector!
13596
Rep 7,995
I think he mentioned in one of the videos that there was a delay in the delivery of it to the new owner (customs / export paperwork delay I think).
01-08-2024, 05:42 PM | #525 | |
Rep 3,916
https://www.liqui-moly.com/en/gb/whe...0408.html#4058 |
Almuliman511.50 |
01-19-2024, 09:57 AM | #526 |
13596
Rep 7,995
Part 8 of Project Frankfurt (E92 M3) is now up and sounds absolutely glorious!
01-19-2024, 01:38 PM | #527 |
Rep 1,498
I enjoyed that episode, so glad the engine is at the moment seems trouble free.
Now the VIXEN unit I'd love one till I goggled the price at 20K to 30K is crazy. |
