06-03-2018, 05:41 PM | #1 |
Rep 328
Drifting/Doing Donuts with Xdrive, is it bad for Car?
How bad is it for an Xdrive car to drift or do donuts on dry pavement besides tires, if any? I mean significant wear on things aside from tires, like transfer case, front/rear diff, transmission?
I've been drifting in the snow but I am afraid of doing the same on asphalt because I heard that the multiplate clutch located in the gearbox for Xdrive cars are pretty fragile. |
06-03-2018, 07:16 PM | #2 |
Rep 779
This will almost certainly be considered abuse by your dealer and BMW so you'll end up on the hook for $10000 dollars or more (mere clutch replacement cost me $4800). IMHO there are less expensive ways to have fun unless you don't mind paying Ferrari prices for BMW parts & labour.
06-03-2018, 07:58 PM | #3 | |
3626
Rep 3,592
This includes clutch disc, pressure plate, release bearing, and miscellaneous hardware as required, but not the flywheel. Any flywheel replacement would only be needed if the clutch has been abused or the flywheel is faulty (which would then be a warranty repair if the car is in warranty). The most obvious signs of abuse are blue marks or uneven hard spots on the steel surface caused by excessive slipping of the clutch that causes overheating. |
06-03-2018, 10:44 PM | #4 | |
Rep 328
06-03-2018, 11:13 PM | #5 | |
Rep 1,241
CP911
06-04-2018, 03:06 AM | #6 |
388
Rep 889
Let's turn our attention back to the important question of how bad it is to do donuts "aside from tires, like transfer case, front/rear diff, transmission". I think we should go through the other car components and see what we think. I'll start us off.
I believe with good reason that doing donuts will not have any bad effects at all on your entertainment system. It will not likely do any damage to your seats, unless you scare your passengers too much. This applies to most of the car's interior. What else, folks? |
06-04-2018, 05:47 AM | #7 |
Rep 1,219
Drives: 2015 M235ix
I confine my donuts to Dunkin's.
For thrills, I do wheelies on a bicycle without a helmet. Much more dangerous if thrills are what you are after. But I am a very thrifty fellow. |
Preciseyyc160.00 |
06-04-2018, 07:44 AM | #8 | |
Rep 2,873
And to continue the thread, I'm worried about possibly shaking loose some of the ///M badges, so you probably want to add as many as possible right before you do all those donuts - just so everybody knows you are not just in a cool car, but the ULTIMATE DRIVING MACHINE. Otherwise you will likely be mistaken for a Mustang. |
06-04-2018, 08:12 AM | #9 | |
Rep 1,154
06-04-2018, 08:25 AM | #10 | |
Rep 970
If you have any doubts, ask your dealer/service manager. |
06-04-2018, 08:29 AM | #11 |
Rep 1,247
Can you even do donuts on dry pavement with xDrive?
You'd look like an idiot b/c as soon as you give it gas you're going to snap back into traction. I don't see how you'd even break traction in the first place. |
06-04-2018, 01:36 PM | #13 |
Rep 2,214
I don't see the point in an x-drive car, you'll end up doing axis spins as opposed to donuts, and you'd need some speed + a lot more power to powerslide an x-drive car, properly, for any extended period of time. Drifing and AWD don't usually go together in the same sentance
If you want to drift an M series car, with a robust all wheel drive-train, pony up and buy an M5. Just my $.02
Poochie9104.50 |
06-04-2018, 01:47 PM | #14 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Sport+, hold traction control button, put the shifter in S mode, cut wheel to either direction at a stop, and stomp the accelerator. Works every time and scares the shit out of people around you. You will definitely be mistaken for a mustang and no you don’t snap back into traction.
06-04-2018, 06:07 PM | #15 | |
Rep 328
06-05-2018, 11:21 AM | #16 | |
Rep 2,873
to summarize: surely damage: tires dignity financial security/warranty probably damage: drivetrain/tranny BMW reputation unlikely to damage: upholstery anybody else's chances at being Drift King |
06-05-2018, 12:54 PM | #17 | |
Rep 1,247
You can break traction enough for a drift, I wasn't questioning that. I'm questioning being able to do donuts, which I doubt you'd be able to keep the car going in circles like that constantly. I do, however, question your judgement in this situation and I don't think you've thought this through. |
06-06-2018, 12:51 PM | #19 |
Rep 525
Unless you absolutely thrash your car beyond a reasonable point, you'll be fine with drifting and doing donuts here and there. Things break when you suddenly catch traction or apply excessive force abruptly and constantly. To make it easier on your drivetrain, you can also put on some crappy tires for the hooning or throw some water on the ground. Have fun and post vids.
06-06-2018, 06:41 PM | #20 |
Rep 314
Under warranty, and if it has an M badge, drive it like you stole it. It's supposed to be the ultimate driving machine for a reason. I've had a few warranty issues with my M240Xi, and the dealer has been more than apologetic. They have even mentioned that my car should be able to take much more abuse than I have given it without having any issues.
06-06-2018, 09:51 PM | #21 | |
Rep 328
06-07-2018, 06:16 AM | #22 |
Rep 1,219
Drives: 2015 M235ix
OP: the consensus is that a gentleman does not drift or do donuts (except at Dunkin' or, in Canada, Tim Horton's), and especially not in an AWD car, which is built specifically to make both difficult.
